Wheel balancing--no local place can do it
Ted in Tallahassee
Ted in Tallahassee is offline
PostPosted: Thu Sep 20, 2007 11:26 pm    Post subject: Wheel balancing--no local place can do it Reply with quote
I just bought new tires and it turns out that the place I bought them from, and every other place in town, can't balance them because the center "hole" of the Thing wheels are too large for any of the adapters those high-speed balancing machines use.
Does anyone know where I can get some sort of adapter to allow a Thing wheel to fit a high-speed balancing machine?
Thanks.
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Thu Sep 20, 2007 11:42 pm    Post subject: Reply with quote
Hey Ted, get one of these: http://www.thesamba.com/vw/classifieds/detail.php?id=373915
They're worth every penny! Cool
- Scott
1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009
Towel Rail
PostPosted: Thu Sep 20, 2007 11:47 pm    Post subject: Reply with quote
Also, it pays to have your wheels checked for straightness before mounting tires on them. I had to find out the hard way that a couple of my wheels were unusable, *after* sanding, primering, painting, and having tires mounted on them. Sad
Ted in Tallahassee
PostPosted: Thu Sep 20, 2007 11:50 pm    Post subject: Reply with quote
Thanks--right after I posted I used the "search" feature and found that same ad. I also found a ton of stuff on my headlight hi/lo beam issues.
The next time I have a question I'll use the search function FIRST. What a great resource that is.
One thing I found out was that the lower circle should be clicked right before the search is run, not the default upper one. I got good hits when I tried the lower circle option (I forgot what parameters it says it is), but the upper one seemed to pull up a lot of posts that were not on point.
Towel Rail
PostPosted: Fri Sep 21, 2007 12:02 am    Post subject: Reply with quote
Isn't this place awesome? Cool
sam_w
sam_w is offline
PostPosted: Fri Sep 21, 2007 5:14 am    Post subject: Reply with quote
The wheel balancing machines are being replaced and the new ones do not have the wide adapters, In San Jose Ca, there is one wheelworks place on Prospect road that will do 'old' VW wheel balancing, even if you did not buy the tires there! They have to look around for the adapter but if you are patient and persistent, they will find it.
63 singlecab
73 thingster
74 Thing
74 Thing
74 Thing is offline
PostPosted: Fri Sep 21, 2007 2:57 pm    Post subject: Reply with quote
You can also get a used drum and clean out the grease, remove the bearings and races and then bring it down and have the person chuck it up on their balancing machine and balance the drum with adhesive weights. Then you can use the drum as an adapter in the future.
Pinky
Samba Ass Bandit
Pinky is offline
PostPosted: Fri Sep 21, 2007 3:16 pm    Post subject: Reply with quote
Just get a static ("bubble") balancer and do it yourself- Wink
They're cheap- you can get a decent one for well under $100. I've used them plenty of times and never had a problem-
ztnoo
ztnoo is offline
PostPosted: Fri Sep 21, 2007 3:49 pm    Post subject: TimGud where are you? Reply with quote
Post some pics of your Thing drum adapter set up.
Slick!!!
Idea
"Here we don't have a single clock in the shop- time doesn't matter." ----Jake Raby
"The government cannot give to anyone anything that it does not first take from someone else."
When you put the 2 words "The" and "IRS" together it spells "Theirs"
* Don't worry about the world coming to an end today. It's already tomorrow in Australia !
xeno
xeno is offline
PostPosted: Sat Sep 22, 2007 5:25 am    Post subject: Reply with quote
Just go to a place that does on vehicle wheel balancing. It's much better & is preferred for lug-centric wheels anyhow.
X
TimGud
TimGud is offline
PostPosted: Sat Sep 22, 2007 7:46 am    Post subject: Reply with quote
I used a 69 bus drum as it had the largest outer bearing size I could find. Had the side of the drum turned off, then had it chucked back up and the rear side of it turned flush with the front. Removed a bit of the inner race area to clear the balancer. Works perfect, and very durable. I cant see this one warping or stripping out the threads.
thinghunter
thinghunter is offline
PostPosted: Tue Oct 02, 2007 7:11 pm    Post subject: Reply with quote
My tire shop guy who used to rebuild wrecked VWs in the 70s and 80s balanced mine by setting up the machine to balance dual wheels. While every tire shop might not know this will work if you mention it to them they might be willing to try it and they should all know how to balance dual wheels.
ronnie braden
ronnie braden is offline
PostPosted: Thu Mar 27, 2008 10:50 am    Post subject: Reply with quote
thanks for your reply may check into this ron
blsthng
blsthng is offline
PostPosted: Sat Mar 29, 2008 8:08 am    Post subject: Balance wheels Reply with quote
I went to an RV service station. They were able to balance with no problem.
chris914x181
chris914x181 is offline
PostPosted: Sat Mar 29, 2008 9:53 am    Post subject: Reply with quote
I bought a lifetime alignment plan from Sears in the 80’s. They have always been able to balance my tires when I bought new ones from them.
1972 2.0L Porsche 914 Autocrosser
1973 2017 VW Thing
1974 2.0L Porsche 914
1986 Skateboard
2004 7.4L Roadtrek Versatile
http://www.cassidy-online.com
hamrendan
hamrendan is offline
PostPosted: Wed Jul 17, 2013 11:12 am    Post subject: Ballancing Beads Reply with quote
http://www.innovativebalancing.com/index.php
Dyna beads, or similar ceramic beads
I have used these on my motorcycles for years. Cheap to buy, easy to use...work flawlessly in tubes or in tubeless.
Bashr52
Bashr52 is offline
PostPosted: Wed Jul 17, 2013 12:16 pm    Post subject: Re: Ballancing Beads Reply with quote
A friend runs something similar in his truck with 50" tires. No one could balance the things being so big, so he went to a truck place and had something like this added to them. Ran smoooooth, but he would have an issue when slowing down to quick, the beads would all drop to the bottom and give it a hell of a wobble for a few revolutions. This was 8 or so years ago though, so I'm sure this technology has improved greatly over the years. Laughing This would also help with getting rid if those ugly ass wheel weights on the outside of the rims
citroen
citroen is offline
PostPosted: Wed Jul 17, 2013 2:26 pm    Post subject: Reply with quote
her is is what the factory one looks like that the domeck brothers use
cecil
cecil is offline
PostPosted: Wed Jul 17, 2013 9:32 pm    Post subject: Reply with quote
At least here in the Big Valley, America's Tire and Discount Tire have the adapters. I think they are nation wide.
I may not be that funny or athletic or good looking or smart or talented....I forgot where I was going with this
I have this wierd desease called "must tear everything up and put it back together when there's nothing wrong with it...Itus."
Bashr52
Bashr52 is offline
PostPosted: Thu Jul 18, 2013 5:36 am    Post subject: Reply with quote
I've got an old school wide 5 adapter for a bubble beam balancer hanging in my garage. My great grandfather gave it to me years ago, said he used to use it for his bug.
