Sigurd Samba Member
Joined: April 18, 2006 Posts: 2639 Location: Rockford, IL
Posted: Wed Sep 26, 2007 7:52 pm Post subject: Should this have a thermostat? |
Like the subject says, should there be a thermostat here? I took off one of the lower tin pieces on the passenger side, and I only see an unused stud. This picture was shot looking up with my head pointing toward the front of the car.
And I know that my engine is very oily. It's getting rebuilt this winter. Why is there oil on the cylinder fins? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76947 Location: Sneaking up behind you
Sigurd Samba Member
Posted: Fri Sep 28, 2007 5:25 pm Post subject: |
So then can I assume that the PO wired the flaps open? Are there even flaps at all? I can't see any sort of linkage at all. |
darkdune Samba Member
Posted: Fri Sep 28, 2007 5:33 pm Post subject: |
on the back of the fan shroud there should be a linkage
if it's there you'll know..
if not locate one and install it and the thermostat. _________________ 60 percent of the time it works every time. |
Sigurd Samba Member
Posted: Fri Sep 28, 2007 7:06 pm Post subject: |
Ok, I'll check it out tomorrow. Don't you have to have the shroud off to do that? |
Posted: Sat Sep 29, 2007 10:33 am Post subject: |
no it's on the back of the shroud, not inside it _________________ 60 percent of the time it works every time. |
Glenn Mr. 010
Posted: Sat Sep 29, 2007 11:43 am Post subject: |
darkdune wrote: |
no it's on the back of the shroud, not inside it |
No it's on the "front" of the shroud.
_________________ Glenn
Member #1009
#BlueSquare |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Sat Sep 29, 2007 1:51 pm Post subject: Re: Should this have a thermostat? |
Sigurd wrote: |
Because your jugs are leaking at the base, or a head stud isn't properly sealed. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Posted: Sat Sep 29, 2007 2:59 pm Post subject: |
Glenn wrote: |
darkdune wrote: |
thats the back to me _________________ 60 percent of the time it works every time. |
Banzai KG Samba Member
Joined: April 10, 2004 Posts: 2992 Location: Sunnyvale, CA
Posted: Sat Sep 29, 2007 5:20 pm Post subject: Re: Should this have a thermostat? |
miniman82 wrote: |
Sigurd wrote: |
Because your jugs are leaking at the base, or a head stud isn't properly sealed. |
Also a punctured pushrod tube or worn/broken pushrod tube seals could also cause the oiling on the cylinder fins. _________________ Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/ |
Sigurd Samba Member
Posted: Tue Nov 13, 2007 3:33 pm Post subject: |
Thought I'd follow this up. The flaps were in place, but there was no return spring. Turns out that the flaps were stuck closed. I confirmed this by feeling the sudden extra blast of hot air under the car when I opened them. I can also touch the dipstick, and I don't get a face-full of hot air when I open the lid.
Which means that I did indeed take a roadtrip to Freeport, IL (about 60 mile round trip) in mid-August (about 90 degrees) with the flaps shut. So that would explain the oil light at idle. Testament to VW engineering or mental note to never assume anything when buying a car? |
Matthew Samba Member
Joined: January 29, 2004 Posts: 1760 Location: Eastern Tennessee
Posted: Tue Nov 13, 2007 7:00 pm Post subject: |
It would be interesting to see a data log of those cylinder head and oil temps. _________________ 1965 Beetle sedan
Click to view image |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Tue Nov 13, 2007 8:51 pm Post subject: |
darkdune wrote: |
thats the back to me |
Do you drive backwards, too?
wcfvw69 Samba Purist
Posted: Tue Nov 13, 2007 8:55 pm Post subject: |
Sigurd wrote: |
Humm...i wouldn't trust that engine if you overheated it that bad. If the engine doesn't have case savers installed you probably pulled a few cylinder studs loose which is causing your oil leak. Personally, I would tear it apart sooner than later. _________________ Contact me at [email protected]
The Samba member since 2004.
Sigurd Samba Member
Posted: Tue Nov 13, 2007 9:16 pm Post subject: |
wcfvw69 wrote: |
Sigurd wrote: |
Humm...i wouldn't trust that engine if you overheated it that bad. If the engine doesn't have case savers installed you probably pulled a few cylinder studs loose which is causing your oil leak. Personally, I would tear it apart sooner than later. |
The crank had about an 1/8 inch of play when I got it. I knew I was on borrowed time anyway. Whoops. That knocking upon cold start-up can't be good either...
I'm planning a ground-up 1915 as we speak. DRD 40 x 37, FK-8, 40 Dells, full doghouse tin and more. To be constructed while the car is out to pasture this winter. |
Sigurd Samba Member
Posted: Tue Nov 13, 2007 9:17 pm Post subject: |
KTPhil wrote: |
darkdune wrote: |
What if his engine is mid-mounted? |
Jody '71 Samba Member
Joined: July 16, 2005 Posts: 2842 Location: Manassas VA
Posted: Wed Nov 14, 2007 7:53 am Post subject: |
Sigurd,
The flap assemblies you have will interchange with a doghouse fanshroud. DO get yourself an original German fanshroud, aftermarket ones will not have the holes for the flap assemblies to be bolted in. You will only need a doghouse linkage bar, return spring, thermostat mounting bracket, thermostat rod, and thermostat, and do make sure there is a Hoover bit installed on your oil cooler. I'd start looking for these parts now!! Classifieds usually has what you need. _________________ '66 Beetle
2011 Hyundai Elantra Touring |
Sigurd Samba Member
Posted: Wed Nov 14, 2007 5:20 pm Post subject: |
Jody '71 wrote: |
Sigurd,
The flap assemblies you have will interchange with a doghouse fanshroud. DO get yourself an original German fanshroud, aftermarket ones will not have the holes for the flap assemblies to be bolted in. You will only need a doghouse linkage bar, return spring, thermostat mounting bracket, thermostat rod, and thermostat, and do make sure there is a Hoover bit installed on your oil cooler. I'd start looking for these parts now!! Classifieds usually has what you need. |
Yup, already doin it. I have a shroud (free), firewall tin (cheap), flaps+linkage (free), and 2-piece exhaust tin (in the mail). So I think I just need the cooler, seals, and Hoover bit.
Is this Hoover repro any good?
http://www.thesamba.com/vw/classifieds/detail.php?id=320200 |
Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Wed Nov 14, 2007 5:56 pm Post subject: |
I think so, (I might be biased though )
Check out my feedback. _________________ www.zwerks.ca |
