1960 double door panel
Page: Previous  1, 2, 3, 4, 5
Z
Z is offline
PostPosted: Sun Aug 05, 2018 10:01 am    Post subject: Re: 1960 double door panel Reply with quote
Love the bus, missed the thread the first time around.
I added the extra ground wire to mine and it works great. That seems to be what many have done to improve the weak original grounds.
JoelH
JoelH is offline
PostPosted: Sun Aug 05, 2018 10:10 am    Post subject: Re: 1960 double door panel Reply with quote
Good to know. Thanks
RED RIVER VW CLUB---www.redrivervwclub.com
WIDEFIVE.NET
'60 DD SWR Panel
http://www.thesamba.com/vw/forum/viewtopic.php?p=2522353#2522353
'62 Gulf Blue Ragtop Bug
http://www.thesamba.com/vw/forum/viewtopic.php?t=420720&highlight=
'60 Black RHD Beetle
http://www.thesamba.com/vw/forum/viewtopic.php?p=6478591#6478591
1965 Sea Sand L568 Notchback
http://www.thesamba.com/vw/forum/viewtopic.php?p=8307805#8307805
Z
Z is offline
PostPosted: Sun Aug 05, 2018 10:14 am    Post subject: Re: 1960 double door panel Reply with quote
FTR, I was referring to the taillights...the original grounds there are not good at all. I didnít have to add grounds to the headlights, but it def sounds like you have iffy connections up there. I think the FAQ thread on light improvements covers this.
ToolBox
ToolBox is offline
PostPosted: Mon Aug 06, 2018 9:18 am    Post subject: Re: 1960 double door panel Reply with quote
I have added real grounds to both the rear housings and headlights. The rear housings I just used a zip screw with a ring terminal to a known good ground. The headlamps received a ground wire going to a known good ground and I also added relays and the light output is greatly improved.
JoelH
JoelH is offline
PostPosted: Mon Aug 06, 2018 9:27 am    Post subject: Re: 1960 double door panel Reply with quote
Could you guys provide any pictures of this improvement for me to go off of please?
WIDEFIVE.NET
'60 DD SWR Panel
Z
Z is offline
PostPosted: Mon Aug 06, 2018 10:36 am    Post subject: Re: 1960 double door panel Reply with quote
There is some discussion in this thread but the only pics I saw at a glance are of grounds on reverse light housings. Same idea, tho.
JoelH
JoelH is offline
PostPosted: Fri Oct 19, 2018 9:29 pm    Post subject: Re: 1960 double door panel Reply with quote
Frustrating night in the shop. I've known the rear drivers side axle has had a leak for a couple months. I dont drive it much, so I didnt think a whole lot about it. I finally tore it all apart tonight and found that the bottom 2 bolts in the axle cap had completely backed out and the top two were loose. Wth? Also, for the lowered guys out there, do your swing plates dig into your shocks like mine do?
I can honestly say this thing may be going back to stock. This is really starting to suck...
WIDEFIVE.NET
'60 DD SWR Panel
cdennisg
cdennisg is offline
PostPosted: Sat Oct 20, 2018 8:00 am    Post subject: Re: 1960 double door panel Reply with quote
I have seen offset spring plates do that before. Modified plates with lengthened axle tubes don't have that clearance issue. As I recall, some folks cut the dust cap off the top half of the shock absorber for clearance.
Those axle bearing cap bolts didn't come loose for no reason. They were likely not torqued properly. Start fresh, get everything bolted back together, and drive on.
Going back to stock height won't lessen complication. Have you ever rebuilt a reduction box? Much more going on in there than your straight axle, and the seals can still leak.
Escalators can never break down... they can only become stairs... sorry for the convenience
-Mitch Hedberg
JoelH
JoelH is offline
PostPosted: Sat Oct 20, 2018 8:06 am    Post subject: Re: 1960 double door panel Reply with quote
Yea, it's possible I just didn't torque them down. I'll pull the other side off today too make sure that side is good too. Better now then on the side of the road
WIDEFIVE.NET
'60 DD SWR Panel
VWsArent4Hippies
VWsArent4Hippies is offline
PostPosted: Sat Oct 20, 2018 8:09 am    Post subject: Re: 1960 double door panel Reply with quote
Yes, just cut those dust guards off the shocks to work with those spring plates. Thatís why some offset plates have a lower shock mount built in
aeromech wrote:
in my opinion you don't know shit
Page 5 of 5
