Flat in the back Samba Member
Joined: December 02, 2006 Posts: 50 Location: smell A
Posted: Fri Sep 28, 2007 11:02 am Post subject: I have a rusty gas tank, what do I do..? |
Hi folks,
My bus sat for 5 years or so and the tank was almost half full.. I've drained the bad gas, but I have a feeling that it's rusty as hell inside. I can't really tell because it's a 58 w/o the sending unit, so I'm just going to assume that there's rust in there. I'm curious to see what's the best way of taking care of this.. I've heard of a do it your self kit but not sure how that would work, plus I don't think having it flushed and treated cost all that much.. right? I'm in So Cal Inland area. Does anyone know of a good place to take it to?
Thanks for the help
_________________ 2005 Saab 92x Aero: Flat in the front (for sale)
1970 Porsche 914-6: Flat in the middle
1958 Volkswagen Panel Bus: Flat in the back
1989 Volkswagen Vanagon Bluestar: Flat in the back |
oldeskooloval Samba Member
Posted: Fri Sep 28, 2007 11:04 am Post subject: |
you buy a new tank. |
Stocknazi Samba Member
Posted: Fri Sep 28, 2007 11:16 am Post subject: |
your tank may not be as bad as you think it is. get some strong parts cleaner like simple green/ purple power , and clean the inside well. you can use a length of chain to slosh around and help loosen up the deposits. use a wooden stick to help remove real thick sturborn deposits. the aftermarket tanks out there are thinner and don't fit as well as your og. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2922 Location: San Diego, CA
Posted: Fri Sep 28, 2007 11:19 am Post subject: |
If the tank is in nice shape otherwise, take it to a local shop. Radiator repair shops often will clean out your tank for a reasonable charge. I wouldn't mess with it because of the fumes and chemicals involved. |
Posted: Fri Sep 28, 2007 11:31 am Post subject: |
I've looked into getting a new tank, but I think they all have a hole for the sending unit, I would have to somehow have the hole welded or just install a sending but not using it. Not sure if that's what I would do since I'm going "original" with my bus. But the simple green idea seems like a good weekend project. Not sure what you mean by length of chain.. something like a bicycle chain? the bus gas tank has a pretty long filler neck to it, you think i would have a problem getting it back out? Also what do I do with the water that comes out of it..? Could that just go to the drain..? Perhaps taking it to the radiator shop is a best idea. I just go a quote for $45 to do the job _________________ 2005 Saab 92x Aero: Flat in the front (for sale)
dstefun Samba Member
Joined: February 20, 2002 Posts: 3338 Location: Sacratomato
Posted: Fri Sep 28, 2007 11:49 am Post subject: |
Flat in the back wrote: |
I've looked into getting a new tank, but I think they all have a hole for the sending unit, I would have to somehow have the hole welded or just install a sending but not using it. Not sure if that's what I would do since I'm going "original" with my bus. But the simple green idea seems like a good weekend project. Not sure what you mean by length of chain.. something like a bicycle chain? the bus gas tank has a pretty long filler neck to it, you think i would have a problem getting it back out? Also what do I do with the water that comes out of it..? Could that just go to the drain..? Perhaps taking it to the radiator shop is a best idea. I just go a quote for $45 to do the job |
For $45 I'd let them do it but be sure they aren't going to punch additonal holes in it so it will sink easier in their tank. Some places want to punch a couple of holes in it and then they patch the holes when they're done. Ask them up front if that is what they are going to do. You don't need any more holes in the tank, patched or not. Here's a good do-it-yourself link for a bay tank but it's really a PIA. Let the rad shop do it. http://www.ratwell.com/technical/FuelTankRestoration.html |
67 Florida Deluxe Samba Purist
Joined: June 21, 2005 Posts: 7987 Location: Gainesville and Tampa, Florida
Posted: Fri Sep 28, 2007 4:44 pm Post subject: |
all of my old tanks I have taken to a radiator shop to have steam/pressure cleaned, then lined. They also brazed in a patch by the outlet on one of them where it was paper thin from rust. $50 to $75 and it's done. Otherwise, I have heard POR has a good sealer product. You definately want to seal the inside of the tank if it has had any rust. Just flushing it out, even if you use rocks, chains, BBs (I've heard lots of ideas for abraisives to help knock off the rust) isnt enough. It'll continue to rust and flake, clogging your fuel filter or carb. Sealing it is your best bet. _________________ -Kent (BaT "daleallen")
OG member of the '67 Posse
A few of my toys, past and present
'56 Oval, '66 KG Conv't, '67 21-Window, '67 Bug, '79 SuperVert, '55 Pre-A Continental |
Posted: Fri Sep 28, 2007 4:47 pm Post subject: |
not really a bicycle chain but a few feet of regular chain, fairly heavy if you can find it. keep one end out the filler neck so you can retrieve it. basically you are just trying to loosen up the sludge. try soaking it with simple green for a weekend or longer and flushing it out with hot water.
if your tank really is rusted through you can use a later tank and leave a sender in there unconnected. _________________ WANTED:
Thomas Jefferson |
///Mink Samba Member
Joined: May 03, 2000 Posts: 5051 Location: Fair Oaks, CA
Posted: Fri Sep 28, 2007 10:14 pm Post subject: |
A gallon of muriatic acid from a pool store mixed with 6 or 7 gallons of water will eat all traces of rust away. Read up on the procedure, it's been documented here before. Works well, but getting rid of the solution afterward can be problematic.
Seal the tank afterward, obviously. |
brettsvw Samba Member
Joined: November 22, 2007 Posts: 2145 Location: Florida
Keysar Samba Grammar Tutor
Posted: Thu Jul 08, 2010 9:51 am Post subject: |
If it were my tank, I would put a couple of rocks in there, with some paint thinner... And rattle it around a bit. _________________
Clara wrote: |
...but mainly perfecting my tossing peanuts shells out the window into the air scoops technique. |
Posted: Thu Jul 08, 2010 4:46 pm Post subject: |
WW just introduced a new reproduction tank in their latest newsletter and supposedly this one actually fits. $149 but it's set up for a fuel gauge sender. They will sell you a block off plate separately if you don't need the sender hole.
Quote: |
EARLY 1955-1967 BUS FUEL TANK
Fuel is a precious commodity these days, so why waste a drop? If your current tank is suffering from typical wear and tear, now is the perfect time to replace. Unlike current aftermarket fuel tanks, our version is modeled after the original, which means no haggling and fuss upon installation. For durability, our tanks are constructed from factory-correct gauge steel. To top it off, each tank is generously powder coated in the correct grey/blue color hue. Made by Wolfsburg West. |
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211201055B
If anybody buys one, report back!
Keysar wrote: |
If it were my tank, I would put a couple of rocks in there, with some paint thinner... And rattle it around a bit. |
Keysar, you obviously have never seen a really bad tank!
Soul Built Pimpin' Aint Easy
Posted: Thu Jul 08, 2010 4:49 pm Post subject: |
Keysar wrote: |
That's the way we used to do it. Worked well. |
Augsburg57 Samba Member
Posted: Thu Jul 08, 2010 7:07 pm Post subject: |
dstefun wrote: |
Keysar wrote: |
Keysar, you obviously have never seen a really bad tank! |
X2 !!
Yes, if anyone buys one of the WW gas tanks, please report back. _________________ '67 VW 11-Window Standard Bus, 2027cc Stroker with Dual 40 IDF Webers |
spectre6000 Samba Member
Joined: April 19, 2009 Posts: 2014 Location: Broomfield, CO
Posted: Thu Jul 08, 2010 7:13 pm Post subject: |
If you do the rock thing, beware there are baffles inside the tank that will make it VERY difficult to get them back out. I called around to several radiator shops in the Dallas area, and no one would touch it. They all said they haven't done anything like that in many many years because it was cheaper these days to just buy a new tank (I hate American consumerism...). I seriously doubt it's cheaper, more likely people are just lazy shits. _________________ Jason Hopper
-'58 German Market Deluxe Beetle (in progress)
-'84 M1009 CUCV
-'81 K10
"Buy the best, cry once." -Gene Berg
"A cheap man will always buy the cheapest thing available, and then buys another one hoping for a better result, and then spends the rest of his life in misery complaining about it. A thrifty man will buy a good part once and never think about it again." -RockCrusher
"Don't feed the Shitty Parts Monster!" -Me |
Old Paint Samba Member
Joined: May 29, 2010 Posts: 436 Location: Battle Ground, Washington
Posted: Thu Jul 08, 2010 7:26 pm Post subject: |
Muratic acid!!! Its DIY, if your in the Inland Empire so Im sure you can just storm drain it.......lol _________________ Greg
1961 Ragtop
1961 Single Cab (Old Paint) |
Posted: Thu Jul 08, 2010 7:57 pm Post subject: |
Oh I see! Well, thats what I did with my tank, any way... and it was pretty clean, but yes, your right, I havn't seen a bad tank!
I wounder, how bad, it really is _________________
Clara wrote: |
Snoop Bob Samba Member
Posted: Thu Jul 08, 2010 9:41 pm Post subject: |
Augsburg57 wrote: |
dstefun wrote: |
Keysar wrote: |
X2 !!
Yes, if anyone buys one of the WW gas tanks, please report back. |
x3 I saw the newsletter and was like whoa. _________________
BarryL wrote: |
Put your lips onto the little tit with the hole in it inside and make a good seal. You can suck and blow but with a little resistance. It gets better after it's wet. |
EverettB wrote: |
I would be interested in knowing the sizes of the various shafts. |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Thu Jul 08, 2010 11:22 pm Post subject: |
Snoop Bob wrote: |
Augsburg57 wrote: |
dstefun wrote: |
Keysar wrote: |
X2 !!
x3 I saw the newsletter and was like whoa. |
I'll have one Monday to check out and fit in one of my buses _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
