Who's Slammed Bus has the nicest looking tubs?
Page: Previous  1, 2, 3 ... 14, 15, 16, 17, 18  Next
50ate
50ate is offline
PostPosted: Mon Apr 15, 2013 8:44 am    Post subject: Reply with quote
Clara's got it all figured out... It's all about the spokes
cru62
cru62 is offline
PostPosted: Mon Apr 15, 2013 1:41 pm    Post subject: Reply with quote
Where can I buy a ticket to THAT show? Clara all gansta-leaning in her fly hoopty. The only thing better would be if it were re-DONK-ulous.
"My biggest worry is that when I die, my wife will sell all my parts for what I told her I paid for them"-Jon
Jokes about German sausage are the wurst.
cage66
cage66 is offline
PostPosted: Mon Apr 15, 2013 5:47 pm    Post subject: Reply with quote
50ate wrote:
cage66 wrote:
Looks real good spit nolan.
I like how you used another section of tubs to extend it.
I am starting to wish I just did mine the same way I did them last time.
If I can find some spare tubs I think I still will. Only cut one side out so far.
The same pedestal that was removed was reused.. All the other pieces we made by hand... We just pretty much cut it out and raised it using filler pieces...
Yeah I know.
I was talking to "Split Nolan"
Laughing Laughing
I do like the work that went into yours also. I cant do that because mine has a 5" (close enough) narrowed beam so I have to run raised flat tubs.
How narrow is your beam?
joe56vw
joe56vw is offline
PostPosted: Mon Apr 15, 2013 6:11 pm    Post subject: Reply with quote
you should have been at pir show a few years back when greg and clara were posing for pics in sled's bagged '61 kombi
'60 15 window walkthrough
why is there no sarcasism button on here?
cru62
cru62 is offline
PostPosted: Tue Apr 16, 2013 8:28 am    Post subject: Reply with quote
Greg almost looks like he likes it-
Either Greg is a giant or sled's tubs raise the seat about a mile!
spit nolan
spit nolan is offline
PostPosted: Tue Apr 16, 2013 2:06 pm    Post subject: Reply with quote
Cheers Cage, I'll get some more pics up once I've finally got round to finishing them off.
And once the seat is done, haven't had to modify the backrest at all and it still sits level with the bulkhead, the base is still in progress at the mo, but once the covers on should look like it has always been that way. I hope anyway Smile
kerbkrawler
kerbkrawler is offline
PostPosted: Sat Apr 20, 2013 2:10 am    Post subject: Reply with quote
Here's my tubs...
jordiando
jordiando is offline
PostPosted: Sat Apr 20, 2013 3:46 am    Post subject: Reply with quote
Not as cool as air, but this will get me as low as I can legally go (lowest point = 10cm or 4" off the ground. Thanks to Das Resto Haus.
joe56vw
joe56vw is offline
PostPosted: Sat Apr 20, 2013 8:13 am    Post subject: Reply with quote
greg is like 6'something and i think the tubs in sleds bus were 4"
SiMedlicott
SiMedlicott is offline
PostPosted: Wed Aug 07, 2013 10:49 am    Post subject: Reply with quote
mandraks
mandraks is offline
PostPosted: Wed Aug 07, 2013 11:32 am    Post subject: Reply with quote
looks nice, like the subtle profile in the tub.
regards
Uli
pineapple_express
pineapple_express is offline
PostPosted: Mon Aug 12, 2013 9:41 am    Post subject: Reply with quote
Quick question for you tubbed guys. Right now I got some 16x7fronts 16x8 rears Porsche Fuchs in 911 offsets.
Is it required to tub if I wanna run 18x7 fronts and 18x8 rears.
[Fiddy Whip]
joe56vw
joe56vw is offline
PostPosted: Mon Aug 12, 2013 10:04 am    Post subject: Reply with quote
how low do you want to go? how narrow is your beam? disc brakes? l/p or b/j? what profile tires?
lot of info need to answer that question most tubs are needed because they want to go real low
if you are just going down 3"' or 4" with a 4" narrow l/p beam without disc brakes then you might be fine without tubs
or you are going lower then that the possibility of tubs needed goes up
with those rims you might have to tub the rear also if it is a pre-'62 bus
pineapple_express
PostPosted: Mon Aug 12, 2013 10:46 am    Post subject: Reply with quote
4in drop spindles, 4in adjustable narrow beam. Porsche 944 disc brakes all around. Adjustable spring plates.
Current setup 16x7 165/40 & 16x8 195/40.
I'm thinking around the same width and ratio of the tires or whatever the smallest tires I can go with, without stretching the tires to the max. I wanna go low as possible without tubbing. If I have to tub then I'll just go with 17s. Thanks for your input Joe56vw
[Fiddy Whip]
spit nolan
PostPosted: Sat Aug 17, 2013 6:13 am    Post subject: Reply with quote
Some more upto date pics of mine now that the seats back in etc.
Modified the original seat frame first.
Then cut the springs to suit. It has been built so it is 3/4" higher than stock, even though the tubs are 1.5" higher. Works well for my bad back and knees.
Refitted the original seat cover and the seat fits back into the stock location, back rest is completely unmodified.
Then after some work with the mango paint think the tubs have a factory unnoticeable look to them.....
I'm happy with them, not the tidiest but in my tatty old bus they suit it....
Cheers
cage66
cage66 is offline
PostPosted: Fri Oct 18, 2013 6:11 pm    Post subject: Reply with quote
Looks real good I like the seat frame.
Is the seat hard?
spit nolan
PostPosted: Sun Oct 27, 2013 1:12 am    Post subject: Reply with quote
Is the seat hard?
It is bit harder but to be honest it is still comfortable. I wanted it quite specific, the tubs are raised 1.5" but the seat is only 3/4" raised. So although a lot of springs have to be cut to suit the new shape it's only actually lost 3/4" out of the main length of them.
I suffer from a bad back and knees, so with the combination of the seat being higher that little bit and the steering raise too, I've never been more comfortable in it Smile
cage66
cage66 is offline
PostPosted: Sun Dec 29, 2013 1:09 pm    Post subject: Reply with quote
My new ones I am working on.
Still a crude work in progress till I figure out exactly what I want to do. These are a flat 1.5" raise and I am trying to keep the original contour on the bottom. It will be pretty close, should match up to the floor pretty good and still have the foot clearance of originals.
You can see the progress from the driver side ones to the pass. side, I decided to ad a lip so I can shrink and stretch to get a nice contour.
I will buy some thicker material and make the real ones. If I can get it "perfect" I may make a few kits if people are interested.
KOMBI NIKO
KOMBI NIKO is offline
PostPosted: Sun Dec 29, 2013 3:25 pm    Post subject: Reply with quote
Was thinking about us aussies and your bus and was going to post a pic of yours Wink
niko.
https://www.facebook.com/vwbuss
mandraks
mandraks is offline
PostPosted: Sun Dec 29, 2013 3:35 pm    Post subject: Reply with quote
Still a crude work in process till I figure out exactly what I want to do. These are a flat 1.5" raise and I am trying to keep the original contour on the bottom. It will be pretty close, should match up to the floor pretty good and still have the foot clearance of originals.
dig these. while i will never need tubs, this is certainly looking "right".
regards
Uli
Page 15 of 18
