tmitoraj Samba Member
Posted: Sat Oct 06, 2007 3:21 pm Post subject: torsion arm ends |
Hey Guys, I have lost two of my torsion arm ends during my front end rebuild. What can I use to plug the holes? I think someone suggested before a freeze plug? K-mann hasn't found a good fix. How about grinding down a dollar of half dollar coin? Does it matter if I don't plug it. Thanks. Tom |
kubelmann Samba Member
Posted: Sat Oct 06, 2007 7:39 pm Post subject: |
Up to now there is no off the shelf solution. I am still open to any suggestion. Freeze plugs, knock outs etc. None have worked. I currently have three Thing front ends that have this issue with no solution. Open ears asn mind in Colorado, K-mann |
emersonbiggins Samba Member
Joined: February 18, 2003 Posts: 1681 Location: Nebraska
Posted: Sat Oct 06, 2007 8:21 pm Post subject: |
Find a washer that fits and weld the hole shut. |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Mon Oct 08, 2007 9:07 pm Post subject: |
I'm missing one.
My FLAPS suggested to just put a blob of grease on it and ignore it - king pin front ends leave the springs exposed. However, I want it capped.
I'm thinking of getting a disk that's close and putting it on my neighbors lathe to cut it down so it's just a hair too big. Set it on some dry ice for a few minutes, then push or hammer it into place. _________________ VW-181 shirts and stickers.
http://ian.epperson.com/vw |
Posted: Mon Oct 08, 2007 10:02 pm Post subject: |
If yoru idea works please share the wealth. I have greased up open ends that I still yearn to cap.. |
Posted: Tue Oct 09, 2007 8:03 am Post subject: |
Sounds like we need 6 here. I wonder if we could make a stamp and cut them out of aluminum and sell them for $4 each. I'm sure others have this problem too.
emersonbiggins wrote: |
Closing in on 1000 helpful posts. |
But I guess a few of them weren't helpful _________________ VW-181 shirts and stickers.
Posted: Tue Oct 09, 2007 8:27 am Post subject: torsion arms |
Now your talking!! I like the way you think. |
twoVWs Samba Member
Posted: Mon Jun 22, 2015 7:09 pm Post subject: torsion hole plug |
Use a 1 inch knock out plug from metal conduit box.. use expoxy after test fitting. Also a 16 mm washer works too but try to find one.. |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Mon Jun 22, 2015 7:33 pm Post subject: |
I lost one of those a couple years ago.
I cut a disc from a sheet of steel, and formed it into a cup shape on a block of wood with a ball pein hammer.
With a little careful fitting, I was able to make it just fit into the opening in the torsion arm.
With the disc in place, I flattened it slightly to increase the diameter so it fit tightly into the groove in the torsion arm. Sealed with some clear silicone, it's still there.
Hope that helps, Mondshine
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Tue Jun 23, 2015 9:56 am Post subject: |
I have used a domed freeze out plug that was bigger and filed down to fit. I have not found a direct to fit plug. Beetle is the same if you can find arms with some and knock them out from the back. |
74 Thing Samba Member
Posted: Tue Jun 23, 2015 11:30 am Post subject: |
I used 50 cent pieces and a hammer. |
waxhead Samba Member
Joined: January 19, 2004 Posts: 946 Location: Philly 'burbs
emilyfberry Samba Member
Joined: October 17, 2013 Posts: 28 Location: Nashville, TN
Posted: Sun Jul 05, 2015 6:19 pm Post subject: |
I also used 50 cent pieces. And because I'm a nerd, they're all from 1973. _________________ '73 Thing-ish |
