dillon schuh Samba Member
Joined: July 21, 2003 Posts: 343 Location: Sacramento
Posted: Sun Oct 07, 2007 5:21 pm Post subject: engine won't start |
Ok I have finally bought my bus Yay And it is having trouble starting.
It will run if pushed it will not start if the starter is used and if i put it on the power then it still wont start it turns over once then it stops turning is there something with the wireing What is going on !! |
codeMechanic Samba Member
Joined: April 13, 2007 Posts: 876 Location: Bellevue , NE
Posted: Sun Oct 07, 2007 5:26 pm Post subject: |
just a guess, replace the battery |
Posted: Sun Oct 07, 2007 5:29 pm Post subject: |
tryed it didnt work |
LittleThunder Samba Member
Posted: Sun Oct 07, 2007 5:50 pm Post subject: |
If it's a new bus for you, you should probably go through all of the basic stuff. Check all of the battery cable connections, on the starter and also the ground strap from the transaxle to the frame. These are under the car and a bit of a hassle but that's why they're always dirty. Disconnect them and go after them with a wire brush. Check basic tune-up stuff, points, plugs, timing. You want to eliminate as many variables that are easy to do first, it will help narrow down your search for the problem and on a new purchase, should be done anyway. How does it run once you get it started? When you turn the key does the engine actually spin over? Your battery might have enough juice to run the engine but not enough to make it through the bad connections. |
Posted: Sun Oct 07, 2007 6:01 pm Post subject: |
when we push start it. It runs good but it idles high i know how to fix that so that isnt a big deal. The previous owner had just put in the engine and trans so that is all new. It is so much fun to drive i love it. |
mintonman Samba Member
Joined: October 20, 2003 Posts: 4245 Location: between Trenton NJ. & Philly Pa.
Posted: Sun Oct 07, 2007 7:09 pm Post subject: |
If everything was just put in, you might want to check the nuts on the starter to be sure they are tight. If they are the least bit loose the starter will cock alittle & the gears won't mesh. I experienced this bench starting a motor with a tranny bell housing and a starter I had lying around. I couldn't figure out why it wasn't turning the motor more then once if that when I touched the wires to start it & bot that starter was hot. I finally noticed the starter moving alittle each time I tried to start the motor, so I tighten up the nuts & it turned rite over. Just a shot in the dark, but might be worth checking while your under there checking wires. _________________ Hoockd on fonicks werkt for mee?
under the influance "DUH" |
Posted: Sun Oct 07, 2007 7:14 pm Post subject: |
will try thanks |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24765 Location: Olympia Wash Rinse & Repeat
Posted: Sun Oct 07, 2007 7:43 pm Post subject: |
First thing do a complete tune up. Then check for voltage drops in the wiring and fix them. For that see:
http://www.thesamba.com/vw/forum/viewtopic.php?t=257577
You can also have the battery and starter checked at your FLAPS. Check that the carb accelerator nozzle is not partly clogged. _________________ In Stereo, Where Available! |
Buckly Samba Member
Joined: September 14, 2004 Posts: 1030 Location: Spokane, WA
Posted: Sun Oct 07, 2007 8:26 pm Post subject: |
diagnose your VD. _________________ Cool runnins,
_______________________
Bucky |
60vwnewengland Twin #2
Joined: June 25, 2003 Posts: 1784 Location: District of Columbia & Cape Cod
Posted: Sun Oct 07, 2007 9:23 pm Post subject: |
my experience with this issue is starter connections being filled with crap and need to be cleaned off, or the battery being dead. but good luck, push starting a bus is no fun, it to big and to heavy, not like push starting a beetle. _________________ 77 Westy - Cape Cod Sage
LLAP |
Posted: Mon Oct 08, 2007 6:32 am Post subject: |
could also be as simple as your battery does not have the required cranking amps |
Posted: Mon Oct 08, 2007 7:44 pm Post subject: |
Ok today i took of the starter and put in a new one
The starter wire was messed up so we fixed that
I put it back on tight and turned it over at first it was good then the same thing
I noticed today that there are no wires coming of the alternator and i do not know which ones should be on there help
can there be to much compression in the engine |
Buckly Samba Member
Posted: Mon Oct 08, 2007 7:52 pm Post subject: |
Just go buy a whole bunch of other parts, when you run out of money go back up to the link eric and barb posted and read it. _________________ Cool runnins,
Bucky |
Posted: Tue Oct 09, 2007 6:53 am Post subject: |
dillon schuh wrote: |
Which alternator??
There is a two wire one that has an internal regulator and the three wire ones that have an external regulator.
Are you charging up the battery with a battery charger???
If not and the alternator is not connected the battery is just getting drained and to go much below 10.5 volts will damage it. Plus that would cause your starting problems. _________________ In Stereo, Where Available! |
