Can a broken float be fixed? -Brass float on Kadron
risk
risk is offline
PostPosted: Mon Oct 08, 2007 7:40 am    Post subject: Can a broken float be fixed? -Brass float on Kadron Reply with quote
A float broke this morning on one of my kadrons while I was on the freeway. Can it be fixed?
It's the brass type - the top bracket broke off clean at the point where it was brazed on at the factory. I just ordered a new pair but they won't be in for another week or two. I was thinking it could be brazed back, or maybe just jb welded temporarily til I get the new ones Confused
Dale M.
Dale M. is offline
PostPosted: Mon Oct 08, 2007 7:55 am    Post subject: Re: Can a broken float be fixed? -Brass float on Kadron Reply with quote
Possibly...You say brazed?... Usually a float is soldered (lead/tin base) if you use low heat and solder you may be able to fix it, if you can't, you can't. Fair danger of destroying it if your skills aren't good. Brazing takes a higher heat as it is based on melting brass and it require "red" heat which is a in temperature range that you can possibly melt float before you are able to bond bracket to float body.
I would say its ok to try soldering, but brazing will probably be a disaster...
Dale
SRP1
SRP1 is offline
PostPosted: Mon Oct 08, 2007 8:32 am    Post subject: Reply with quote
If you have a good radiator shop in your area they could probably fix it for you. They solder and braze brass all day.
The Noof
The Noof is offline
PostPosted: Mon Oct 08, 2007 8:54 am    Post subject: Reply with quote
It should solder easily.Not too much solder, or your "float" may "sink"...Don't use Jb weld inside the carb.
volksterii
volksterii is offline
PostPosted: Mon Oct 08, 2007 11:16 am    Post subject: Reply with quote
You can get new floats from AJ at Low Budget. They are not very expensive.
71 Westy Hardtop, 1915
2005 Touareg V8 air susp.
