Thermostat Mystery
srbarker
srbarker is offline
PostPosted: Wed Oct 10, 2007 7:02 pm    Post subject: Thermostat Mystery Reply with quote
Ok - I was wondering why my cooling flaps were not moving on my 69 VW Beetle... I thought maybe they were jammed int the "open" position somehow...
When I removed the thermostat bracket though and pulled down on the thermostat they worked fine though - I could hear them moving
With the thermostat pulled all the way down though so the flaps are "closed" the bracket though is about 1/2 inch below the bolt that the bracket bolts onto ... putting the bracket on moves the thermostat to high which opens the flaps..
almost like the thermostat rod or the thermostat are too long???
any idea would be appreciated....
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Oct 10, 2007 7:07 pm    Post subject: Reply with quote
Is the thermostat shot?
When cold it should not compress when you squeeze it.
Glenn
Member #1009
#BlueSquare
Fibersport
Fibersport is offline
PostPosted: Wed Oct 10, 2007 7:11 pm    Post subject: Reply with quote
I think there were different rods through the years but i have no idea which one went with which year. I installed flaps when I got my car and the rod was the wrong length, I seem to recall that mine was too short. Also, are you sure the thermostat is good?
1973 Standard Beetle
srbarker
srbarker is offline
PostPosted: Wed Oct 10, 2007 7:23 pm    Post subject: MY Thermostat Reply with quote
here is a picture of the thermostat
1 1/8 inch compressed
total length = 2 1/8 inch
vw57drvr
vw57drvr is offline
PostPosted: Wed Oct 10, 2007 7:53 pm    Post subject: Reply with quote
I believe that one is shot. It should be totally compressed. It doesnt have to move much to open the flaps. It is doing what it should. Thats the fail safe to make sure the flaps are open.
60 Rock Grey Vert
Mr. 010
Glenn is offline
PostPosted: Wed Oct 10, 2007 7:55 pm    Post subject: Reply with quote
Here's a good one.
Glenn
Member #1009
#BlueSquare
srbarker
srbarker is offline
PostPosted: Wed Oct 10, 2007 8:51 pm    Post subject: Thanks! Reply with quote
Ok thanks for your hellp... looks like I will be ordering a new thermostat soon
Max Welton
Max Welton is offline
PostPosted: Wed Oct 10, 2007 9:33 pm    Post subject: Reply with quote
The one on the right is failed.
Max
1967 Type-3 Fastback
Towel Rail
Horizontally Opposed
Towel Rail is offline
PostPosted: Wed Oct 10, 2007 9:55 pm    Post subject: Reply with quote
If you can squish it tighter with your fingers, it's shot.
1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009
