larrytrk Samba Member
Joined: July 22, 2007 Posts: 377 Location: Central NJ & MA
Posted: Mon Oct 15, 2007 3:12 pm Post subject: oil pressure high pressure sensor |
In trouble shooting my light and buzzer for oil pressure, I have continuity to the 14 pin cable on the high and low sides, so the dynamic logic board looks bad. In the mean time when I test continuity to the High pressure sensor, normally open untill I start engine and there is immediate continuity at idle which stays the same when I goose it to 4K RPM and over. Is this normal or is it supposed to close at higher pressure? Is the sensor also bad?
I know this had been talked to death, but I am about to order parts! _________________ It's all in your mind.
I Hate BAMBI!
87 Westy full camper "Bluie" aka-"busturd"
JUST SOLD HER, WESTYLESS!
Good by cruel world! |
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3342 Location: Talos IV, Piedmont Arizona
Posted: Mon Oct 15, 2007 4:17 pm Post subject: |
Class, please turn to page 17.7 in your Bentley manual:engine lubrication system.
Study 17.7 thru 17.10 and follow all lab tests to resolve the problem.
Oil pressure tester and test lamp required.
This will be on the final exam. _________________ LEARN TO SELF RESCUE
.....................All Current....................... |
weinerwagen Samba Member
Joined: May 10, 2004 Posts: 1548 Location: Monterey, CA -Laguna Seca--Coats, Kansas
Posted: Mon Oct 15, 2007 5:18 pm Post subject: |
Bill W wrote: |
This will be on the final exam. |
LOL!
Where are my glasses.... |
Posted: Mon Oct 15, 2007 5:23 pm Post subject: |
Bill W wrote: |
Thanks for the Bentley reference.
I realize that if I have to take it out to check, it I might as well replace it,
My question was, is it normal to have the switch Closed at idle, rather than at higher RPM. I was surprised that it closed so early, at idle and wondered if that was correct! _________________ It's all in your mind.
I Hate BAMBI!
