Coil discussion
Suboval
Suboval is offline
PostPosted: Thu Sep 05, 2013 4:00 pm    Post subject: Reply with quote
lzamora wrote:
I have 3 coils.... One is a TE6B1, second is a TE6A3 and the third is a star coil TL 6/1. Im trying to figure out which one is correct for a January 53 Zwitter and a May 56 oval? Any help
TL 6/1 was used before November 1, 1950
TE 6 A3 was used after November 1, 1950
TE6B1 was used on August 14, 1956 starting with chassis 1261493
See Progressive Refinements, Volume 1, Electrical TAB, E-14
http://www.thesamba.com/vw/archives/manuals/progressive_refinements/
It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history.
tasb
The Distributor Distributor
tasb is offline
PostPosted: Sun Apr 10, 2016 4:11 am    Post subject: Re: Coil discussion Reply with quote
I'm not seeing any mention of the fact that most Bosch parts, including coils have a date stamp on them. The code listing is in the Split Beetle FAQ's.
Roads Scholar &
tasb
tasb is offline
PostPosted: Mon Apr 25, 2016 2:09 pm    Post subject: Re: Coil discussion Reply with quote
I've just finished a group of coil testing/restorations. Two of them are curious abberations perhaps?
They are wide diameter TK 6 A 3's. according to the Bosch documentation that Andy (Glutamodo) and I were able to uncover these were used from 1947-1951. That's all fine except these coils have odd date stamps One is a bit vague but appears to be 2Q which is February 1961 or it could be 2 G but the G would have to be a lower case "g" which I have never seen on a Bosch part. The other coil is 5 S which is May 1959.
Andy and I would like to turn the question over to the collective consciousness: Would Bosch have manufactured these old large outdated design coils clear into the early 1960's?
I do know from my distributor restoration exprience that they continued some distributor designs and of course tune up parts for several years after they were no longer being installed on VW's.
Roads Scholar &
tasb
tasb is offline
PostPosted: Sun Oct 02, 2016 1:35 pm    Post subject: Re: Coil discussion Reply with quote
Here's an interesting coil that needs some sluething. It was removed from a split window Beetle many moons ago according to the seller.
It is 62.7 mm wide and 120.9 mm long not including the bakelite cap. Besides the 1 and 15 terminal markings the bakelite has a symbol that looks like a early Bosch "B" inside the circle with two horizontal lines. The clamp though has a five pointed star with what looks like "AVP" inside it. The bracket is original to the coil and is marked TL to the left of the star and 6/1 to the right.
It has 0.O4hms resistance from secondary to secondary and 6.6K ohms from secondary to primary. It appears very primitive with a rough lap joint to the jacket.
I know that before WW II Bosch had to partner with other firms located outside the Axis Powers in order to produce items in quantity and this may account for the odd maker marks. Any thoughts welcomed and appreciated.
I've searched pretty thuroughly for a date stamp but the housing and clamp are pretty rough so I may have missed it.
Roads Scholar &
janerick3
janerick3 is offline
PostPosted: Sun Oct 02, 2016 3:29 pm    Post subject: Re: Coil discussion Reply with quote
TK6A3 coils were used on 6-volt 356s through Dec 1963, when Bosch revamped their entire product line, to include new part numbering and date-coding systems. The "2Q" coil is Feb 1959 and the "5S" coil is May 1961.
Thanks,
Jan K.
johnshenry Premium Member
johnshenry is offline
PostPosted: Thu Oct 06, 2016 7:12 pm    Post subject: Re: Coil discussion Reply with quote
To bolster the argument that the TL 6/1 was used before November 1, 1950; I have 5 of these coils, the date codes are:
12D Dec 1948
2F Feb 1950
5F May 1950
7F July 1950
8F Aug 1950
John Henry
'57 Deluxe
'56 Single Cab
Brad Ripley
Brad Ripley is offline
PostPosted: Thu Oct 06, 2016 9:55 pm    Post subject: Re: Coil discussion Reply with quote
Here are relevant pages from Bosch catalogs, dated Oct 1950 and Jan 1962 . Hope it helps with the discussion.
PostPosted: Fri Oct 07, 2016 7:53 am    Post subject: Re: Coil discussion Reply with quote
Is the TE6A3 the fat star coil with the lipped bottom? A link to a pic of one earlier in this thread is dead.
John Henry
'57 Deluxe
'56 Single Cab
Suboval
Suboval is offline
PostPosted: Mon Oct 10, 2016 1:47 pm    Post subject: Re: Coil discussion Reply with quote
It is a thin coil with no star.
Early:
Late:
Suboval
Suboval is offline
PostPosted: Mon Oct 10, 2016 1:52 pm    Post subject: Re: Coil discussion Reply with quote
Does anyone have anything else to add? Needs to be changed?
1946-1948: TL 6/1 moon (non star)
1949: ?
1950: TL 6/1 (star)
1951-1953: TK 6/3 (TK 6 A 3), TE 6/3 Zwitter?
1954-08/13/1956: TE 6 A 3 (Early on bakelite, later on the end of the coil)
08/14/1956-07/1960: TE 6 B 1
08/1960-1963: TE 6 B 4
TL 6/1 moon coil
eurodub wrote:
Hello,
i got this skinny coil thinking of using it for my split.. but further checking show that this is not even close to being ok for mine...
date stamp 1B (jan 1946? )
non star coil butt.. but the rest of the details are there. (click on the pics for bigger version. a lot bigger actually )
Is this correct for a 1946 VW ? i will not need it so it might end up in the classifieds, but i don't want to represent something that's not. I won't mind getting a real price range for it.
Thank you.
http://www.thesamba.com/vw/forum/viewtopic.php?t=548781&highlight=coil+moon
TL 6/1 star coil
HeSa wrote:
Rollo Tomasi wrote:
Tk 6/3 is early porsche 356(1950-53) , split bug is TE 6/3
http://www.thesamba.com/vw/forum/viewtopic.php?t=281148&highlight=tk6
Here are some captures from the "Bosch Blue Book" from 1952.
1951 Bug should have TE 6A3 (round pressing).
Bus section of the same catalog says the change from TL 6/1 (skinny star) to TE 6A3 (round pressing) took place on November 1st 1950 (1.11.1950).
Which IMHO means the star coil is incorrect for the majority of us split owners.
http://www.thesamba.com/vw/forum/viewtopic.php?t=396320&highlight=tl
TK 6/3 star coil
Gustav Petri wrote:
Could these be used on a split, what would they be correct for kübel swim , borgward, porsche, vw.
What would be the value on a NOS TK 6/3 today.
Thanks
http://www.thesamba.com/vw/forum/viewtopic.php?t=396320&highlight=nos+star+coils
spooky wrote:
My service manual shows the following:
Note the from jan 54 TE6A3. Indicating TK6/3 for 53
However, threads such as the following indicate differently...
http://www.thesamba.com/vw/forum/viewtopic.php?t=2...p;start=20
Question
http://www.thesamba.com/vw/forum/viewtopic.php?t=439802&highlight=tk6
TK 6 A 3
splitpartsunlimited wrote:
dimensions seems similar to the fat star coil , dia 6.5 , body lenght 11.5 ....
asking because a would be german customer asked me for a repro of this one ....
any clue about this ??
i am also including a picture of a technical manual .......
thank you !!!
Ricardo
TE 6 A 3
Early:
Late:
[/quote]
TE 6/3
Zwitter?
http://www.thesamba.com/vw/forum/viewtopic.php?t=439802&highlight=zwitter+te6
TE6B1
PostPosted: Mon Jul 24, 2017 3:52 pm    Post subject: Re: Coil discussion Reply with quote
To add, I picked up a "fatty"in Hessisch that is date coded 5F, May 1950, so they were making both kinds in the same month!?? And I have another skinny one with no date code. I have glass beaded it and looked at it with a magnifying glass, and there is no date code there....
12D Dec 1948
2F Feb 1950
5F May 1950
7F July 1950
8F Aug 1950
John Henry
'57 Deluxe
'56 Single Cab
Suboval
Suboval is offline
PostPosted: Tue Jul 25, 2017 5:21 pm    Post subject: Re: Coil discussion Reply with quote
12D Dec 1948
2F Feb 1950
5F May 1950
7F July 1950
8F Aug 1950
Are your TL 6/1s star or moon (non star) coils?
PostPosted: Tue Jul 25, 2017 7:57 pm    Post subject: Re: Coil discussion Reply with quote
Suboval wrote:
12D Dec 1948
2F Feb 1950
5F May 1950
7F July 1950
8F Aug 1950
My coils are "Allstars" LOL Wink
John Henry
'57 Deluxe
'56 Single Cab
56samba
56samba is offline
PostPosted: Wed Sep 20, 2017 2:49 am    Post subject: Re: Coil discussion Reply with quote
12D Dec 1948
2F Feb 1950
5F May 1950
7F July 1950
8F Aug 1950
Was it the coil being offered by the guy with the heavily modified Barndoor next to the river/pond (I don't know)? I had it in my hand and purchased it, but then I was curious about the diameter and gave it back. Now you're the lucky guy Wink
PostPosted: Wed Sep 20, 2017 7:39 am    Post subject: Re: Coil discussion Reply with quote
56samba wrote:
12D Dec 1948
2F Feb 1950
5F May 1950
7F July 1950
8F Aug 1950
I don't recall, but probably not. I got it from a guy with a whole lot of other parts who had put them all aside for me before I got there and I don't think he ever put them out on his table before then.
John Henry
'57 Deluxe
'56 Single Cab
vintage fiberglass
vintage fiberglass is offline
PostPosted: Fri Nov 17, 2017 7:12 pm    Post subject: Re: Coil discussion Reply with quote
I just picked up a TE6/1 coil that has 3 posts on the top and it came off a 1948 engine?? Does not mean it is correct, but that is where it came from. Looks exactly like the fat coils with a smooth bottom but 3 posts? any ideas?
56samba
56samba is offline
PostPosted: Sat Nov 18, 2017 12:14 pm    Post subject: Re: Coil discussion Reply with quote
I wish I could explain that in English, but my English isn't that good. Try google and look for "Clamp 16" or "Klemme 16", that's standardized.
Last Sunday, I also purchased the same coil as yours, but with a star on the backside. Then I realized, it has 3 posts and directly contacted the seller. He also had a TK 6/3 for me. He could keep the money and I got the right coil, we both were happy Wink
Frederik
Frederik is offline
PostPosted: Fri Mar 08, 2019 4:46 am    Post subject: Re: Coil discussion Reply with quote
1949: ?
1950: TL 6/1 (star)
[b]
I don't think the 1954-1956 is fully correct and I have doubts about the 1951-1953.
This is a june 1953 (date code 6J) TE6A3 coil. The stamping is on the end not bakelite, painted bracket.
Frederik
Frederik is offline
PostPosted: Fri Mar 08, 2019 6:10 am    Post subject: Re: Coil discussion Reply with quote
I don't think the "from january 1954" change in the vw workshop manual refers to the change of coil but the change to "vju" style distributors and because of this should not be taken as a proof of thats when they started using the TE6A3 coil. It also important to remember that the part VW/ Bosch refers to in the old manuals might be what they thought was the correct when that manual was printed, and that is not always what was correct when the car was built.
From the Swedish official VW workshop manual (1952-), but this two papers are printed/updated 1956 and 1958. I think the "TK6/3" is strange as Bosch would have used the TK6A3 "numbering" by then/ at least from 1952. I don't know the exact date for this, but TK6/3 was replaced by TK6A3, TE6/3 -> TE6A3 and so on. I know the pictures are "generic"/ "re-used" but it clearly no TK6/.. coil in any pictures, maybe TK6A.. but I doubt it. This makes me think the "TK6/3" might be a printing error, they (VW) intended to use the TK6/3 or that it might have been correct for a short period when they first printed the book and they just left it there/ didn't uppdate it. I would trust HeSa's 1952 Bosch blue Book more on this. You also have the chassie number 1 261 493 when they changed to the TE6B1 coil.
This is from the Bosch parts Book printed 1958.
And they list the TE6B3 as spare part for all VW and TK6A4 (thats a blue coil) for all Porsche except carrera. With this I just want to highlight that you should take what they list as spare part and what was on from factory as two different things when looking in old books. Even when they are printed in the correct era.
TK6A4 blue coil. Also stamped in the end not bakelite. Date code 12H = december 1952.
noheb
noheb is offline
PostPosted: Mon Mar 18, 2019 12:56 pm    Post subject: Re: Coil discussion Reply with quote
Hi, am I correct that the coil
TE 6A3 (11.1950 to 8.1956) had various designs?
- Star coil
- Lipped upper edge but no star in the top
- Tall coil with loose strap with oval hole
Page 3 of 4
