busman78 Samba Member
Joined: August 17, 2004 Posts: 4520 Location: Oklahoma City, OK
Posted: Mon Oct 22, 2007 10:20 am Post subject: 73 Fastback is Back! |
Bought this fastback in 1984 from a used car lot in OKC, did the usual 1980's customizing and drove it till 1990 when the bay window bus urge over took me. Gave the fastback to my dad who drove it till 2001, he had some low compression issues on a new engine and no energy to tinker with it so he parked it under a tree. The Fastback has sat with a tarp over it under that tree till last weekend. With his passing away in July I have once again got the 73 Faskback back.
A little worse for wear, got some rust issues now (rockers and under the battery), engine needs gone through although it runs, tires be a little old. Amazing is that the vehicle has never be wrecked.
Although I am still a bus fan, this Fastback has always had a special spot in me, even after 23 years. It is going to be a keeper, already started searching for parts for the rebuild. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon Oct 22, 2007 1:27 pm Post subject: |
Looks like you have the mate to mine.
And sounds like it needs the same repairs. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
COFBack Samba Member
Joined: July 05, 2005 Posts: 2148 Location: Colorado Springs
Posted: Mon Oct 22, 2007 2:50 pm Post subject: |
Sweet, how bout a pic of the engine bay so we can see what you are up against. _________________
iowegian wrote: |
Henceforth he shall be known as "Trameltoe".
Chickengeorge's wife wrote: |
bing chow ching fong fang T.J. fang ching dow fong |
Posted: Mon Oct 22, 2007 4:07 pm Post subject: |
Panama Yellow if memory serve me.
Pictures of the engine will have to be awhile, the vehicle is at my other house, 220 miles South of where I work. Engine is pretty straight forward, nice basically new (<100 miles) 1600cc single port with dual 32PDSIT carbs, bank 1&2 have low compression (suspect the head), discovered the thottle bushings need replaced so they will be sent off to RIMCO.
Would really like to find somebody in a 500 mile radius of Albuquerque that can replace rocker panels on a Type 3, I am okay welding floor pans, but my work is best when no one can see it. I have a set of panels, new, made by a company in Holland. Anybody? |
Posted: Tue Oct 23, 2007 6:46 am Post subject: |
http://www.motorworksrestorations.com
Call Jeremy at Motorworks Restorations. He and Gary are skilled body and paint guys. Same guys doing RTKing's Notch
He's busy though.
"Oilspot" is another guy to try. He's south of ALBQ.
good luck _________________
iowegian wrote: |
Posted: Tue Oct 23, 2007 7:00 am Post subject: |
Thanks, I will check in with both of them. |
Posted: Tue Oct 23, 2007 7:32 am Post subject: |
busman78 wrote: |
Texas Yellow if it is a 73. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
