dillon schuh Samba Member
Joined: July 21, 2003 Posts: 343 Location: Sacramento
Posted: Mon Oct 22, 2007 6:07 pm Post subject: I am having a problem starting |
Alright I got my bus 2+weeks ago and i can't get it to start
It turns over once and thats it
We put in a new battery and the same
Try and jump it the same
Bought a new positive cable and ground and a new trans ground strap
and still the same
Put in a new starter The same
bypassed the starter the same
We havent got any where this past 2 weeks what is going on |
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Mon Oct 22, 2007 6:23 pm Post subject: |
fire, fuel and compression....start by checking these first then post questions later |
Posted: Mon Oct 22, 2007 6:24 pm Post subject: |
it push startes just fine and runs |
Ian Samba Moderator
Posted: Mon Oct 22, 2007 6:33 pm Post subject: |
starter bushing?? _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012 |
codeMechanic Samba Member
Joined: April 13, 2007 Posts: 876 Location: Bellevue , NE
Posted: Mon Oct 22, 2007 6:52 pm Post subject: |
Ian wrote: |
starter bushing?? |
x2 |
Posted: Mon Oct 22, 2007 7:06 pm Post subject: |
what is that? |
60freak Samba Member
Joined: October 08, 2002 Posts: 861 Location: Indiana
Posted: Mon Oct 22, 2007 7:14 pm Post subject: |
It's the bushing that the shaft with the gear on it pushes into in the trans bellhousing. You have to remove the starter, look with a flashlight into the hole where the starter goes and then look for a hole big enough for a pencil to go in about 3-4 inches back, there should be bronze'ish colored ring around the small hole's inside area, that is the bushing, get a ez-out that is just slightly smaller than the hole and use it remove the bushing, pop in a new one and it should be good. Just don't let the bushings drop into your bellhousing/flywheel area.
ricekooker Samba Member
Joined: April 09, 2006 Posts: 1788 Location: Winter Park, FL
It's the little ring that is in the bell housing that the starter slides into. Make sure you have the right one too. I had the same problem using a 12v starter with a 6v tranny.
Lohe Samba Member
Joined: June 26, 2007 Posts: 662 Location: Chandler, Az
Ian Samba Moderator
Posted: Mon Oct 22, 2007 9:29 pm Post subject: |
No, it's actually in the transmission bellhousing. _________________ All your Buses are belong to us.
