HamburgerBrad Je suis Napoléon!
Joined: February 21, 2003 Posts: 6957 Location: SoCal
Posted: Wed Oct 24, 2007 3:23 pm Post subject: Balljoint Camber Adjuster help |
While rebuilding my beam, I unfortunately misplaced my thing camber adjusters. I was able to come up with a pair of bug adjusters, but later learned of the fitment issues first hand and confirmed here: http://www.thesamba.com/vw/forum/viewtopic.php?p=2066689#2066689
Does anyone know where I can come up with a pair of thing camber adjusters or where (preferably in southern california) a set of bug adjusters can be machined to fit thing balljoints? _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Wanted: two beat up, ugly, curb rashed 6" phone dial wheels |
mattt Samba Member
Posted: Wed Oct 24, 2007 7:44 pm Post subject: |
Hey Brad, Your best bet locally would be German Motor Works in Garden Grove, CA. I'd think any competent machine shop should be able to machine yours as well, however, having a Thing eccentric for them to model off of would be best.
What do you have with a Thing front end now? |
Posted: Wed Oct 24, 2007 8:12 pm Post subject: |
i called them up. the were really no help. and right now, the thing front end is in parts all over the place. I also went to a couple of machine shops up in Ontario with no results.
it will eventually go under this car:
1970 baja|1953 oval
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Wed Oct 24, 2007 8:20 pm Post subject: |
http://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=12933
Try him. I talked to a little last week and was told he has a lot of stuff and he seemed to know things pretty good. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
mattt Samba Member
Posted: Wed Oct 24, 2007 8:26 pm Post subject: |
GMW didn't have them to sell? Amazing! Did you speak with a man or woman? Thing Shop in AZ? I'm sure Kmann will see this thread and speak up, he always does.
Did you lose the ones that came with the beam? I have one you can borrow if you find someone to machine them. |
Posted: Wed Oct 24, 2007 8:32 pm Post subject: |
mattt wrote: |
I lost them. I'm sure I could find them around here somewhere, but this place is a mess right now. As far as GMW, I spoke with a woman who asked a man so I'm counting that as a loss. I'll call up the place in Arizona tomorrow.
als e-mailed this guy. _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
74 Thing Samba Member
Posted: Thu Oct 25, 2007 9:51 am Post subject: |
There is a place called TC ....
I forgot the name-maybe someone here will chime in. |
mattt Samba Member
Posted: Thu Oct 25, 2007 9:54 am Post subject: |
Oh yeah.....TC's Old VDub Home in Tujunga, CA. Tim is a good guy, he sells every so often at Pomona too. |
kubelmann Samba Member
Posted: Thu Oct 25, 2007 11:24 pm Post subject: |
I went to Verdugo High in the late 60's. I built dune buggies to drive up in
Angeles Nat'l Forest/ TJ made me think of the glory VW daze///
My first one was built from my 61 vert that I bought from my mother who bought it new from the VW that was in Sunland. |
mackaymanx Samba Member
Joined: October 12, 2006 Posts: 479 Location: Australia
Posted: Fri Oct 26, 2007 4:07 am Post subject: |
I made my own from some beetle ones, to get the taper right use the stem from an old balljoint. This will give you the right taper and the marks on the old stem will give you the correct depth for the taper.
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Fri Oct 26, 2007 7:36 am Post subject: |
mackaymanx wrote: |
Nice work!
What tapered reamer did you use? Do you have a pic of it for those who dont know what a tapered reamer looks like? |
Posted: Fri Oct 26, 2007 3:32 pm Post subject: |
I used a lathe not a tapered reamer. |
Posted: Fri Oct 26, 2007 5:07 pm Post subject: |
a lathe? i'm no machinist, but that sounds hard to do with an off-center hole? _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Posted: Fri Oct 26, 2007 7:29 pm Post subject: |
No, it's dead easy. you set it up off the face and the original bore using a 4-jaw chuck. The hard bit is getting the taper right but you have the balljoint stem as a gauge as you enlarge the hole.
p.s. Yes I am a machinist |
Posted: Fri Oct 26, 2007 7:51 pm Post subject: |
If I can't come up with anything then maybe I'll take it to the machinists at work when I go back in a couple of weeks. _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Buckly Samba Member
Joined: September 14, 2004 Posts: 1030 Location: Spokane, WA
Posted: Fri Oct 26, 2007 8:48 pm Post subject: |
I see your trying to build something maybe for off road, but you could get bug ball joints and bug eccentrics, not quit as beefy, but look at all thoughs bug bajhs that kick ass. _________________ Cool runnins,
_______________________
Bucky |
Posted: Fri Oct 26, 2007 8:53 pm Post subject: |
Buckly wrote: |
I see your trying to build something maybe for off road, but you could get bug ball joints and bug eccentrics, not quit as beefy, but look at all thoughs bug bajhs that kick ass. |
where's the fun in that? _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
UncleDirty Samba Member
Joined: July 20, 2005 Posts: 745 Location: Riverside Ca
Posted: Sat Oct 27, 2007 7:26 am Post subject: |
I feel your pain Brad, I went through the same thing went I did my Thing beam, except I tossed my old eccentrics. Yes, I threw away a pair of these hard to find 181 eccentrics, Why, because I had nice new type 1 units That's when I found out they were different, and also how hard they are to find.
Anyway, I ended up buying a couple tappered reams and making the type 1's work.
What a pain in the ass way to learn the difference between type 1 and 181 camber adjusters. |
Posted: Sat Oct 27, 2007 11:11 am Post subject: |
would you, by chance, still have those reamers? _________________ OGST | CU05 | OGJHC
1970 baja|1953 oval
Posted: Sat Oct 27, 2007 7:31 pm Post subject: |
Can you make a set for me to fit the thing ball joints using the bug ones that have more of a camber adjustment? |
