shadetreemech Samba Member
Joined: October 05, 2005 Posts: 777 Location: Claremont, CA
Posted: Wed Mar 25, 2020 11:28 am Post subject: Re: What did YOU do to your van today? |
Cleaned out the engine compartment after blasting through a huge mud puddle out in Chaco.
Dan _________________ '84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "MZDRTHY" |
dsdunbar Samba Member
Joined: December 19, 2014 Posts: 564 Location: Crozet VA
Posted: Mon Mar 30, 2020 6:15 am Post subject: Re: What did YOU do to your van today? |
I installed Frank Condelli's rear head rest kit. Was surprised at how easy it was.
_________________ '89 2WD Westy "Grey Goose" - Manual 4spd
Crozet VA
Vanaru EJ25, Peloquin |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Tue Mar 31, 2020 8:02 pm Post subject: Re: What did YOU do to your van today? |
Delightful sunny afternoon!!!
Alt belt started chirping when cold, so I wanted to tighten things up a bit. Well, I remembered the spark plugs I got and needed to do, and while I was doing that, I spotted 2 CV bolts that came loose. So, Sparks, belts, and CV bolts all back in spec!
These look gnarly!!
_________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
ezmass Samba Member
Joined: August 26, 2019 Posts: 13 Location: Fort Collins, CO
Posted: Tue Mar 31, 2020 11:17 pm Post subject: Re: What did YOU do to your van today? |
Installed a Rockville 8" subwoofer under my passenger seat, perfect fit and sounds awesome - especially for under $90.
_________________ 1990 Multivan |
stevets Samba Member
Joined: August 07, 2015 Posts: 49 Location: Minnesota
Posted: Fri Apr 03, 2020 6:01 am Post subject: Re: What did YOU do to your van today? |
I exercised some electrical demons.
The fuse position for the heater blower and wipers was fried and someone had installed a blade type fuse holder work around. The fuse would immediately fry when powered up and the rear wipers would not shut off. I'd seen evidence of mice and George ( pronounced Horhey) had been idle for some years. My guess was mouse nest in the blower so it could not turn resulting in overload and thus blown fuses.
I was right!
You can see the little f2435er top right in this photo.
Dash out, heater box out, blower removed, de-louse the whole thing and an opportunity to take a real close look at all the wiring. Fixed a few things, re-grounded everything including ground trees, a few drops of oil in the blower bearing and back together. It all works and I'm feeling a bit heroic. If I can do this so can you.
ezmass - thanks for sharing. I have a 10 incher of these in my other van and was hoping the 8 would work in the spot you've chosen. Time for some music in this little buggy
[/img] |
Posted: Fri Apr 03, 2020 8:15 am Post subject: Re: What did YOU do to your van today? |
Completed a 4 day cycle of Ospho on all my seams, and chips. Soaked the Opsho into the seams repeatedly each afternoon. All of this followed up with 2 coats of 3M Mar-Hyde, which is curing at home right now. (Drove the Tundra to work today.) Hope the 'treatment' gets me another year to find my alternative Westy while the Kitchen Rot on Flossie is remedied. Full removal of Westy interior will be necessary, and I don't want to be without a spare, yes, I am a bit nuts. ONE Westy SHOULD be enough for anyone. But, for some reason, I want two for myself and one for each of my kids.
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
BCE56 Samba Member
Posted: Sun Apr 05, 2020 5:09 pm Post subject: Re: What did YOU do to your van today? |
Finished (I hope) cooling system upgrades. New stainless pipes, rear heater bypass, thermostat, and expansion tank. Cleaned and reused the level sensor. Hoses, clamps etc replaced where necessary.
A leaking hose and corroded fitting under the intake manifold were replaced. This may have been a source of the odd temp. fluctuations noted previously.
New coolant and bled system. Thanks, Adrian!
A short test drive discovered nothing unusual. Temp gage is now steady just under the LED.
So far, so good.
On to the next fiasco! _________________ =BCE56=
'86 Syncro tintop
EJ22, OBD II early SC adapter plate conversion
Side project: '69 Frankenbug "It's alive!" |
AceTaylor Samba Member
Joined: July 15, 2009 Posts: 139 Location: PERKASIE, PA
Posted: Mon Apr 06, 2020 10:46 am Post subject: Re: What did YOU do to your van today? |
I fixed the cruise control. Well maybe not fixed as it turns out it wasn't broken. It was driving me nuts. I checked and rechecked every step in the Bentley. Followed the wiring diagram. Turns out it was the LED stop lights. Put the old incandescent bulbs back in and it magically works again. I don't understand it, but it wasn't coincidence. Put the LED's back in, no cruise control. Put the incandescent bulbs back all is well. |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Mon Apr 06, 2020 12:35 pm Post subject: Re: What did YOU do to your van today? |
AceTaylor wrote: |
Without the low resistance of the incandescent bulbs, the brake signal going to the cruise control doesn't get properly grounded, but 'floats'. So the cruise won't work as it relies on that signal (among others) to know it's OK to engage.
You could add a parallel resistor to the LEDs to emulate the resistance of the OEM bulbs. _________________ Jim Crowther
Vespa GTS 300 |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Mon Apr 06, 2020 11:01 pm Post subject: Re: What did YOU do to your van today? |
I did a 0 to 100 km/h (a 0 to 60 in medieval English )
(drumroll)
22.5 seconds! WOOHOOOO ! Fast and Furious !
Stock 1990 Westy, 2.1 auto, driver plus some stuff.
Is there a thread for these? I'm sure this is one of the best results. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Abscate Samba Member
Joined: October 05, 2014 Posts: 22665 Location: NYC/Upstate/ROW
Posted: Tue Apr 07, 2020 4:10 am Post subject: Re: What did YOU do to your van today? |
Yuck. Drowning a sentient creature? Make it quick and painless please _________________ .ssS! |
teej Samba Member
Joined: November 26, 2010 Posts: 897 Location: Seattle
Posted: Tue Apr 07, 2020 4:37 pm Post subject: Re: What did YOU do to your van today? |
Took the rusty dirty engine carrier bar to a buddy's metal shop for a sandblast cleaning. This is my first time, really amazed at the quick good results.
After a short bit of work:
As a bonus find, there is a faint VW logo and date stamp on the underside of the bar near the center. Matches the year of this rig.
After 10 years of ownership I still enjoy these little discoveries. _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
sillymofo Samba Member
Joined: February 07, 2016 Posts: 5 Location: Vancouver, BC
Posted: Tue Apr 07, 2020 9:19 pm Post subject: Re: What did YOU do to your van today? |
Front end work. GoWesty full bushing kit. New Stabilizer, Moog 5660 front springs, Rancho RS9000XL adjustable shocks front and rear
BCE56 Samba Member
Posted: Sun Apr 12, 2020 12:30 pm Post subject: Re: What did YOU do to your van today? |
Yesterday- replaced a tail light bulb, then ran some errands in the van.
Last night- neighbor advised me lights were still on.
They were. Dimly.
This morning- deployed battery charger.
Reviewed recent posts at "Official Lazy Person's Stupid Questions" thread. _________________ =BCE56=
'86 Syncro tintop
khughes Samba Member
Joined: July 13, 2013 Posts: 747 Location: Phoenix AZ
Posted: Sun Apr 12, 2020 3:27 pm Post subject: Re: What did YOU do to your van today? |
sillymofo wrote: |
Front end work. GoWesty full bushing kit. New Stabilizer, Moog 5660 front springs, Rancho RS9000XL adjustable shocks front and rear |
What are the part numbers on the shocks you used? Rancho doesn't list VWs on their site. _________________ '86 Westy FAS GenV Turbo (Marvin) |
Posted: Sun Apr 12, 2020 3:55 pm Post subject: Re: What did YOU do to your van today? |
khughes wrote: |
sillymofo wrote: |
What are the part numbers on the shocks you used? Rancho doesn't list VWs on their site. |
Googled "Rancho RS9000XL" for you:
https://www.google.com/search?client=firefox-b-1-d&q=Rancho+RS9000XL
Happy Easter!
'01 Volvo V70 T5
brocski Samba Member
Joined: August 30, 2015 Posts: 13 Location: South San Francisco CA
Posted: Sun Apr 12, 2020 4:11 pm Post subject: Re: What did YOU do to your van today? |
I missed out on posting lots of stuff I banged out while being out of work due to the quarantine! Darn it.
Wrapped up the install of the video rear view/dash cam setup in the van the other day though. Pretty stoked I can drive with the curtains closed and still have visibility out the back/see what I'm backing into. Fittings included with this model allow you to replace the factory rear view, rather than clamp a screen to it which would have deterred me from doing this. I did have to modify the bracket a little bit, but all in all it looks pretty seamless. It fits PERFECTLY between the sun visors now too.
[/img] |
Posted: Sun Apr 12, 2020 4:16 pm Post subject: Re: What did YOU do to your van today? |
shadetreemech wrote: |
khughes wrote: |
sillymofo wrote: |
Happy Easter!
Dan |
Well thanks, but since there are many options, I wanted to see which option the OP used and how they worked out with the spring he installed. I have the *old* Van-Cafe 1.5" lift springs, and I think our ride heights are likely similar.
Happy Easter to you as well! _________________ '86 Westy FAS GenV Turbo (Marvin) |
Posted: Sun Apr 12, 2020 4:31 pm Post subject: Re: What did YOU do to your van today? |
...and just for the sake of sharing, two weeks post-install. The bixenon retrofit into sealed beam housings upgrade. The light output and distribution over my stock, relayed headlights is incredible. Driving with high beams on through country roads is awesome! I need to adjust the passenger side projector housing ever so slightly to make it perfectly level, but since I opted for bolting the projectors in (instead of epoxy) it's easy to handle small tweaks like this. Going to black out the chrome sealed beam bezels when I tackle that job too.
I yanked out all my AC components too if anyone around the Bay Area has a need for a full system? Condenser is coming out when I work on the headlights again soon.
