augustwillo Samba Member
Joined: July 09, 2018 Posts: 80 Location: Albany, Oregon
Posted: Thu Aug 27, 2020 11:27 am Post subject: Re: What did YOU do to your van today? |
Well, yesterday was a very special day for us. Woke up at 2am to my wife starting labor with our then unborn son. Packed up the van, and drove like hell, while my wife was on the floor in the back. We made it to the parking lot of the birthing center at 2:28am, jumped out and opened the sliding door and the midwife caught our son at 3am. It was a surreal moment, and so thankful we had a van to allow the space for such a birth.
All is well, both baby and mom are healthy. And we are never selling the van. haha. However, I am now having some transmission issues. I think the gear oil is mixing with my tranny atf. On to the next thread.
August |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Thu Aug 27, 2020 1:38 pm Post subject: Re: What did YOU do to your van today? |
augustwillo wrote: |
August |
Congratulations to all three of you (four of you?) on the successful birth!! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
VicVan Samba Member
Joined: July 01, 2015 Posts: 1845 Location: Vancouver Island, BC
Posted: Thu Aug 27, 2020 1:51 pm Post subject: Re: What did YOU do to your van today? |
August |
Wow!! That is quite the story!
Congratulations _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
BCE56 Samba Member
Posted: Sat Aug 29, 2020 11:46 am Post subject: Re: What did YOU do to your van today? |
Last weekend: replaced (both) brake light switches. Had to do it twice- one was defective and leaked.
Yesterday: Expedient repair of melted dual 20 amp fuse holder behind D-pillar for A/C fans.
Topped off refrigerant w/ can from FLAPS. So far, so good! _________________ =BCE56=
'86 Syncro tintop
EJ22, OBD II early SC adapter plate conversion
Side project: '69 Frankenbug "It's alive!" |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Sun Aug 30, 2020 7:29 pm Post subject: Re: What did YOU do to your van today? |
Oil breather tower oRing had been indicating a problem, removed, cleaned, new oRing and tube to intake boot. 306k mi and spinning up!!
[/img] _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch
jlrftype7 Samba Member
Posted: Mon Aug 31, 2020 6:19 am Post subject: Re: What did YOU do to your van today? |
bobbyblack wrote: |
Oil breather tower oRing had been indicating a problem, removed, cleaned, new oRing and tube to intake boot. 309k mi and spinning up!!
[/img] |
Yep, that O-ring looks a bit past its Sell By Date.... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
shadetreemech Samba Member
Joined: October 05, 2005 Posts: 777 Location: Claremont, CA
Posted: Mon Aug 31, 2020 4:14 pm Post subject: Re: What did YOU do to your van today? |
Pulled the Water Pump Pulley off, extracted the old High Pressure Oil Switch, put anti-sieze on the threads of the new Switch, cleaned up in and around the area behind the Water Pump and installed the Switch. Replaced the wiring to both switches and cleaned up.
Gettin' geared up for a late September Road Trip.
Dan _________________ '84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "MZDRTHY" |
BrownEye02 Samba Member
Posted: Mon Aug 31, 2020 10:34 pm Post subject: Re: What did YOU do to your van today? |
shadetreemech wrote: |
Pulled the Water Pump Pulley off, extracted the old High Pressure Oil Switch, put anti-sieze on the threads of the new Switch, cleaned up in and around the area behind the Water Pump and installed the Switch. Replaced the wiring to both switches and cleaned up. |
Me too!!! I didn't go as far as you did with the clean up part though.
Still chaseing oil pressure issues though. :/ Have a Mann filter and oil pressure releaf spring on the way from Van Cafe. If this doesn't do the trick then I'm probably stairing at low oil pressure after warm up. |
gchristensen Samba Member
Joined: October 09, 2012 Posts: 84 Location: Sacramento Ca.
Posted: Tue Sep 01, 2020 10:56 am Post subject: Re: What did YOU do to your van today? |
well I blew my aaz engine. connecting rod at the oil pump end through the block. nice big hole. stripped that engine down and building up my other long block _________________ Joining now is our new 1982 diesel. This is an ongoing project under construction. |
Posted: Wed Sep 02, 2020 8:37 am Post subject: Re: What did YOU do to your van today? |
gchristensen wrote: |
well I blew my aaz engine. connecting rod at the oil pump end through the block. nice big hole. stripped that engine down and building up my other long block |
Sorry to hear that.
Any warning like a days long , or weeks long slight noise before the rod went flying, or was it totally out of the blue.? _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
VicVan Samba Member
Posted: Wed Sep 02, 2020 8:51 am Post subject: Re: What did YOU do to your van today? |
Lowered the van suspension today. And for dirt cheap!
Before:
After:
Red Konis? GoWesty lowering springs? Low-profile tires on 20" spinners? No sir.
Pro-tip: finetune the Westy Lean adjustment by using a box on the passenger side. Allows you to pour one cup of gravel at a time for a perfectly balanced riding height.
Hauled two loads of asphalt, one of 700 kg and one of 800 kg. I love my van. _________________ '90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH) |
Landojin Samba Member
Joined: July 10, 2017 Posts: 6 Location: Okanagan, B.C., Canada
Posted: Wed Sep 02, 2020 2:16 pm Post subject: Re: What did YOU do to your van today? |
Diagnosed a high idle (2,000 - 2,500 rpm) that showed up while the van was warm and in park. Using the Bentley manual, discovered that the Idle Air Control Valve was causing the problem. Rather than replacing it, I tried cleaning it out as recommended by GoWesty and the problem seems to be solved (for now)! _________________ 1988 Vanagon, 2.1L Automatic |
Posted: Wed Sep 02, 2020 8:11 pm Post subject: Re: What did YOU do to your van today? |
307k mi, oil/filter. Put in 4Q, started, checked dip stick. Showed 1/3 up from lower notch. Added 1/2q, dipstick shows over top mark by a few mm. Confusing. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Thu Sep 03, 2020 4:34 pm Post subject: Re: What did YOU do to your van today? |
no indication was seen just a quick fail. _________________ Joining now is our new 1982 diesel. This is an ongoing project under construction. |
Posted: Thu Sep 03, 2020 4:49 pm Post subject: Re: What did YOU do to your van today? |
Installed the Van Cafe aftermarket oil pressure relief spring.
Besides replacing the oil pump I'm out of options. Gonna get an oil gauge to confirm what everything is pointing to. Anyone able to point me to the nearest oil pressure witch doctor..... |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2797 Location: North Carolina
Posted: Fri Sep 04, 2020 6:04 am Post subject: Re: What did YOU do to your van today? |
BrownEye02 wrote: |
You've probably seen this, but tencentlife's post 6 down in this thread is chapter and verse on oil pressure testing.
https://www.thesamba.com/vw/forum/viewtopic.php?t=251094 _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
Posted: Fri Sep 04, 2020 8:26 am Post subject: Re: What did YOU do to your van today? |
When I bought my '88 Westy it was missing the tin over the pushrod tubes. Bought a set of tencentlife's pushrod tube shields:
https://intrepidoverland.com/shop/pushrod-tube-shields/
Clips hang on the tubes -
Shields bolt to the clips -
Passenger Side
Driver side
Easy peasy.
'01 Volvo V70 T5
175grams Samba Member
Joined: February 10, 2020 Posts: 25 Location: Guatemala
Posted: Mon Sep 07, 2020 3:43 pm Post subject: Re: What did YOU do to your van today? |
Finally finished my DIY tables. Got a few planks of teak to make the tables. Also had a to fashion my own base poles. I think it turned out pretty nice, eh?
jimf909 Samba Member
Posted: Mon Sep 07, 2020 3:59 pm Post subject: Re: What did YOU do to your van today? |
^^^Nice! _________________ - Jim
Abscate wrote: |
erf Samba Member
Posted: Wed Sep 09, 2020 4:10 pm Post subject: Re: What did YOU do to your van today? |
Got my new wheels and tires on, from a Touareg, had to have them bored out to fit. Waiting on axel nut wrengh so I can replace the studs in the real, about a quart inch or so short. Have out side of the poptop claned, next the inside.
