What did YOU do to your van today?
Page: Previous  1, 2, 3 ... 545, 546, 547, 548, 549  Next
shadetreemech
shadetreemech is offline
PostPosted: Sun Sep 20, 2020 1:02 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Asked VanagonDwellers on Etsy to make me a stripe based on a design I found on an Ancestral Puebloan pottery sherd. I like their work, just couldn't see it on the Van. This morning I found the place:
Dan
'84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "Miss Dorothy"
Jake de Villiers
Jake de Villiers is offline
PostPosted: Mon Sep 21, 2020 7:07 am    Post subject: Re: What did YOU do to your van today? Reply with quote
That looks really good, Dan!
'84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com
andy52
andy52 is offline
PostPosted: Mon Sep 21, 2020 8:35 am    Post subject: Re: What did YOU do to your van today? Reply with quote
11BC2 wrote:
One cool aspect of owning a previous Bundeswehr Doka is repainting it!
A quick rub down with a scotch brite pad and thinner, a few beers later ...VOILA!!!...finished.
cool!
andy52
andy52 is offline
PostPosted: Mon Sep 21, 2020 8:47 am    Post subject: Re: What did YOU do to your van today? Reply with quote
got the windows tinted
here in europe cant tint all of them but still looks ok
vino de vano
vino de vano is offline
PostPosted: Mon Sep 21, 2020 9:03 am    Post subject: Re: What did YOU do to your van today? Reply with quote
I think you have achieved the ultimate level of black out. Looks fabulous, but for gods sake never paint that aluminum rim, it's just the right amount of flash.
what a long strange trip it's been
andy52
andy52 is offline
PostPosted: Tue Sep 22, 2020 12:40 am    Post subject: Re: What did YOU do to your van today? Reply with quote
i agree! it even matches with the front lights hahaha
UngaWunga
UngaWunga is offline
PostPosted: Tue Sep 29, 2020 9:29 am    Post subject: Re: What did YOU do to your van today? Reply with quote
Not today... but the Syncro works well, even with the front VC slipping
jlrftype7
jlrftype7 is offline
PostPosted: Wed Sep 30, 2020 4:40 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Performed tuneup tonight. Spark Plugs, cap, rotor and new fuel filter. Sprayed out the Aux Air Valve for good measure while I had the Air Filter housing off.
I only had 2 Yrs of usage on these parts, but it was time.
Air filter had already been replaced.
Idle , which wasn’t bad before, was very smooth with the new parts.
Checked tire pressure and drove home from work.
Still need to install a hose I ordered a few weeks ago , and 10cents heater valve heat.
'67 Type 3 Fastback, my 2nd car- also long gone
'69 Semi-Auto Stick Shift Beetle, my wife's first car= yep. still long gone....
‘84 Tin Top - Hilga....Auto
dhaavers
dhaavers is offline
PostPosted: Sat Oct 03, 2020 7:55 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Installed GW DRL module...relatively simple & effective. I plan to follow up with LED bulbs from SuperBrightLED's...
Cool
- Dave
86 White Westy Weekender
"The WonderVan"
fxr
fxr is offline
PostPosted: Sat Oct 03, 2020 8:04 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
The pop-top all-around seal (GW, 5 years ago) decided one part would stick to the van, the other to the pop-top.
Fixed the back with ABS cement as an experiment - not hopeful - and the sides with DAP contact cement. This is after several months of the top not being opened, and very high daytime temps.
Verdict on the glues tomorrow...
Jim Crowther
Vespa GTS 300
4mymalamute
4mymalamute is offline
PostPosted: Sun Oct 04, 2020 9:01 am    Post subject: Re: What did YOU do to your van today? Reply with quote
Put in the T3 Swaybar and end links, changed the oil and put in new rubber matts all throughout. Now to wash the beast.
1989 Sally the Syncro.....she is a work in progress.
rontv
rontv is offline
PostPosted: Sun Oct 04, 2020 2:22 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Installed my new kitchen cabinet and electrical setup.
the latter with a 100Ah lifepo4 and 160W solar
dhaavers
dhaavers is offline
PostPosted: Sun Oct 04, 2020 7:42 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
^^^ LOVE the look of all that...very nice! Cool
- Dave
"The WonderVan"
OldSpice
OldSpice is offline
PostPosted: Mon Oct 05, 2020 11:24 am    Post subject: Re: What did YOU do to your van today? Reply with quote
is that under the drivers seat? above the rail?
rontv
rontv is offline
PostPosted: Mon Oct 05, 2020 12:57 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Yes its under the driver seat.
first i put some insulattion on the body and the a wooden board.
the chair fist fine but as i already had a swivel unit i left it there too. I like the increased seatring height.
the swivelling itself wont work anymore ar the battery fits in the cabinet length and width wise but is protruding slightly in height. (need to make a new cover)
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Wed Oct 07, 2020 6:14 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Strange that my A/C not working in October would bug me, but it did.. I got the hatch open, found a Very Loose belt, which I replaced only 4k miles ago. So, replaced it, and then checked the pressure of the refrigerant. Low! Ya, I've got leaky lines. Set up fans and 'installed' another "12A replacement" environmentally safe refrigerant.. 312K miles, on my known to be inaccurately low#'s odo.
Will report back Smile
'87 Westy 'Flossie','83.5 Vanagon L 'ZoomBus','74 Karmann Ghia, '63 Notch
radar5667
radar5667 is offline
PostPosted: Wed Oct 07, 2020 6:34 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Joined the Blazecut club
‘62 Heinkel Tourist, ‘70 Beetle, ‘86 Syncro Tintop, ‘87 Syncro Westy, ‘91 964 Coupe
campism
campism is offline
PostPosted: Wed Oct 07, 2020 7:41 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Apologized to it for remarks I've made about the difficulty working in its engine compartment. I've been trying to replace the head gaskets in our big Dodge highroof and the Vanagon is practically a breeze by comparison.
'87 Westy in Wolfram Grey Metallic
4Gears4Tires
4Gears4Tires is offline
PostPosted: Wed Oct 07, 2020 8:15 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
With an engine the size of potato, of course it's easy to access.
'87 Syncro with lightweight rust modification
dhaavers
dhaavers is offline
PostPosted: Wed Oct 07, 2020 8:25 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
radar5667 wrote:
Hmmm...why all the tubing above the AFM? Just curious...
- Dave
"The WonderVan"
Page 546 of 549
