andy52 Samba Member
Joined: December 17, 2019 Posts: 77 Location: Barcelona
Posted: Mon Jan 18, 2021 3:46 am Post subject: Re: What did YOU do to your van today? |
is that a cooler? or a little fridge? |
82westyrabbit Samba Member
Posted: Mon Jan 18, 2021 4:59 am Post subject: Re: What did YOU do to your van today? |
I don’t think you want to eat what is stored in that box 😀 |
old_man Samba Member
Joined: June 19, 2018 Posts: 1102 Location: Newfoundland
Posted: Mon Jan 18, 2021 5:00 am Post subject: Re: What did YOU do to your van today? |
andy52 wrote: |
It looks like a toilet with appropriate reading material beside it. |
andy52 Samba Member
Posted: Mon Jan 18, 2021 8:13 am Post subject: Re: What did YOU do to your van today? |
ahhahahaha true ahahahahahah |
AceTaylor Samba Member
Joined: July 15, 2009 Posts: 74 Location: PERKASIE, PA
Posted: Fri Jan 22, 2021 12:13 pm Post subject: Re: What did YOU do to your van today? |
I finally got around to installing a resistor on my brake light circuit so that the cruise control would work with the LED stop lamps. |
bobbyblack  Samba Member
Joined: May 21, 2015 Posts: 2954 Location: United States, Iowa
Posted: Sun Jan 24, 2021 1:07 pm Post subject: Re: What did YOU do to your van today? |
Made a custom TV hanger out of some bar stock.
EDIT:
Got to work this AM and as usual, sniffed my vents. Sniffed gasoline up my vents! Ugh, not again.. Mid Winter, every Winter... So, after a good nap on noon break, I popped the hatch, and took a look. I primed the fuel line for 1 second with the key, and took a good gander. Sure enough, 2 leaks. Not bad, but enough to smell. So, I got out my tools and tightened all of the fuel rail clamps, and the all 3 on the center T. Went back and turned the key on for 3 seconds 4 times and took another look. All good now. Whew! _________________ '87 Westy 'Flossie','83.5 Vanagon L 'ZoomBus','74 Karmann Ghia, '63 Notch |
TurtsMcSlow Samba Member
Joined: August 07, 2015 Posts: 64 Location: Derby City, Cantuckee
Posted: Wed Jan 27, 2021 11:27 am Post subject: Re: What did YOU do to your van today? |
New spark plugs and wires, distributor cap and rotor, battery(old one was 14 years old!), AFM harness from Van Cafe, and replaced the cig lighter receptacle with a dual USB socket. |
Posted: Thu Jan 28, 2021 2:03 pm Post subject: Re: What did YOU do to your van today? |
Balmy 20F over lunch spurred me to get at my variable voltage regulator module and turn it down to a more sane (and recommended) 14.3V, and re-calibrate my DC-DC charger to put out 14.65V to my LiFePO4 house battery. _________________ '87 Westy 'Flossie','83.5 Vanagon L 'ZoomBus','74 Karmann Ghia, '63 Notch |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7000 Location: NE MN (http://g.co/maps/zt72q)
Posted: Thu Jan 28, 2021 4:36 pm Post subject: Re: What did YOU do to your van today? |
Dang Bobby, you do keep yourself busy, don't cha?
All I've done recently is order myself a quality affordable fuel pre-filter...should be here Monday:
https://smile.amazon.com/gp/product/B075XKFLXB/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Open box deal, only $21... ...although I'll spend another ten or so for the 1/2"
barb fittings I'll pick up once I have it in hand to determine spec on the threads...
I won't get to install until March or so...Move on winter, I'm done with you!
- Dave _________________ 86 White Westy Weekender
"The WonderVan"
Posted: Tue Feb 02, 2021 9:04 am Post subject: Re: What did YOU do to your van today? |
Pre Trip Inspection last PM revealed a splitting coolant hose at the top of the thermostat housing. Had to figure out how to loose the least coolant while cutting back the hose about 3cm to get past the spot. Looks like I must have gouged it with a screw driver that slipped off the clamp. That'll teach me to use a socket next time. Otherwise the hoses all are supple and in decent shape. After hooking it all back together, I filled up the pressure tank, and ran it till 'warm' and the fan cycled twice. Then I backed it up on a good incline and bleed the radiator. Temp needle seems to be in its usual ranges and they match my digital temp readout that has its probe sitting above/between #3 and #4 on the engine case, heater outputs all good, no more drip.
Leaving sometime tomorrow mid day for Denver. Looking like I can sneak under the weather if I arrive by 3 AM Thursday.. Lets cross fingers on that! Iowa has forecast of ~5 inches of snow after freezing drizzle forecast for Thursday! Around 2K miles round trip.
-bobby _________________ '87 Westy 'Flossie','83.5 Vanagon L 'ZoomBus','74 Karmann Ghia, '63 Notch |
jlrftype7 Samba Member
Posted: Tue Feb 02, 2021 9:03 pm Post subject: Re: What did YOU do to your van today? |
dhaavers wrote: |
- Dave |
. That looks like the prefilter from Mansispeed.
Same, or copy?  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
'67 Type 3 Fastback, my 2nd car- also long gone
'69 Semi-Auto Stick Shift Beetle, my wife's first car= yep. still long gone....
‘84 Tin Top - Hilga....Auto |
Posted: Wed Feb 03, 2021 5:17 am Post subject: Re: What did YOU do to your van today? |
Now that you mention, it does seem pretty much identical... <shrug>
"The WonderVan"
Posted: Wed Feb 03, 2021 4:22 pm Post subject: Re: What did YOU do to your van today? |
Installed the Mansi injectors. Passenger side was a piece of cake but the drivers side was a pain to get old rail off. |
Posted: Thu Feb 04, 2021 8:45 pm Post subject: Re: What did YOU do to your van today? |
Finally got around to replacing the coolant hose off the end of cyl.1 that feeds the heater cores. Went with the silicone version from Van Cafe.
I was pleasantly surprised to find no real corrosion hiding on the hose fitting once the old hose was off the head....
So, no epoxy tricks or rebuilding needed, just install the new hose and bled air from the system.
Still need to install 10cc’s Heater Valve kit, but the hose had been a more pressing matter...  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Fri Feb 05, 2021 1:02 pm Post subject: Re: What did YOU do to your van today? |
Picked up 4 of these CLK/Toliman wheels. Gonna clean them up and figure out what to do with 'em.
BCE56 Samba Member
Posted: Sat Feb 06, 2021 11:20 am Post subject: Re: What did YOU do to your van today? |
[quote] Gonna clean them up and figure out what to do with 'em.
You might consider powder coating to prevent future corrosion and inevitable dulling of finish. Savings in Mother's and elbow grease a side benefit...
A two-tone or color match scheme would set them apart from the crowd. _________________ =BCE56=
'86 Syncro tintop
OBD II Frankenmotor
Early SC adapter plate conversion
SC header, 3-way cat, VW muff.
stock springs, OME shocks*
VC, rear locker**
215-75 BFG AT/TAs on Rhein rims
*OMEs a bit too stiff in front, OK in rear or on heavier vans. Will try Bilsteins. Someday.
**PO installed taller top gear before Subie install. Not recommended. |
Posted: Sat Feb 06, 2021 6:26 pm Post subject: Re: What did YOU do to your van today? |
BCE56 wrote: |
A two-tone or color match scheme would set them apart from the crowd. |
More than likely what I'll do. Cleaned all of the mud off of them with a little soap and water. Looks a lot better after a bath.
dabaron Samba Member
Joined: June 21, 2018 Posts: 1664 Location: Philly, yo.
Posted: Sat Feb 06, 2021 8:47 pm Post subject: Re: What did YOU do to your van today? |
built in library. the perfect reader too. _________________ 1991 Vanagon GL Camper
150Ah LiFePo (driver well)/Renogy DCC50S/100W mono panel
*witty quote about Vanagon* |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 1894 Location: North Carolina
Posted: Sun Feb 07, 2021 6:59 am Post subject: Re: What did YOU do to your van today? |
TurtsMcSlow wrote: |
BCE56 wrote: |
Oven cleaner is the ticket for cleaning those suckers. Great find! _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie"
In an abundance of water, the fool is thirsty. |
SteveW45 Samba Member
Joined: January 24, 2021 Posts: 2 Location: British Columbia
Posted: Mon Feb 08, 2021 7:30 pm Post subject: Re: What did YOU do to your van today? |
I removed the rear window wiper and discovered that it works when hot wired on the bench but not in the vehicle. Checked the fuses, all good. Gotta be switch on the column or a broken wire.
Any thoughts?
Other thing, the washer pump runs ( I can hear it) but no washer fluid comes out. Full reservoir. |
