andy52 Samba Member
Joined: December 17, 2019 Posts: 98 Location: Barcelona
Posted: Mon Mar 08, 2021 6:48 am Post subject: Re: What did YOU do to your van today? |
campism wrote: |
I used those interlocking foam mats from the hardware store with the seams foil-taped on the backside so it can be removed as a unit for cleaning.
also thought about that
thanks! |
shadetreemech Samba Member
Joined: October 05, 2005 Posts: 777 Location: Claremont, CA
Posted: Thu Mar 11, 2021 7:18 am Post subject: Re: What did YOU do to your van today? |
Finally addressed my non-op E-Brake issue.
Did a "Title Only" search for "Emergency Brake" and found what I was looking for:
Turns out I had the adjusting rods on both rear wheels inside out. I flipped both rods and, Voila!, E-Brake works now.
Happy Trails & Be Safe
Dan _________________ '84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "MZDRTHY" |
d_walküre Samba Member
Joined: October 09, 2008 Posts: 72 Location: Tulsa, OK
Posted: Fri Mar 12, 2021 1:26 pm Post subject: Re: What did YOU do to your van today? |
I received my radiator fan resistor from Vancafe today and got the slow speed to finally work. The quality of this resistor is top notch! Factory style plug made fitment a breeze.
_________________ JesusV
1987 Vanagon GL Syncro SVX NAHT "Valkyrie"
1993 Eurovan Weekender "Camper van Beethoven"
1959 Bug |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32432 Location: Reading Pennsylvania
jlrftype7 Samba Member
Posted: Sat Mar 13, 2021 3:14 pm Post subject: Re: What did YOU do to your van today? |
djkeev wrote: |
I drove it!
For the first time ever!
Dave |
. Still running hot or have you solved that issue??? _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4332 Location: United States, Iowa
Posted: Sat Mar 13, 2021 8:41 pm Post subject: Re: What did YOU do to your van today? |
Well, Not sure it was me doing something, or just time something would be happening. Anyway, backstory on this one: Had to visit the Northern Kingdom (MLPS/STPaul, Mrs. Black's Keep) and since it was such an incredible day, drove the Westy! Rolled 218K on the northbound leg, and all was going well until we finished all the errands, junk yard visits, second hand stores, and a pawn shop, found a nice Bass to replace the one I gave my son for my birthday last week!
Anyway, I-35 southbound to I-35E through St Paul I noticed the flashing coolant-low light. Pulled off in South St Paul on Concord, and found a spot to take a look. Area was pretty sketch, sort of by the air freight terminal. Looked, coolant overflow empty. Pulled the hatch, expansion tank half full. Probe had done its job to tell me the coolant was too low, thanks!
Filled up with 50/50 coolant/water and started engine. No obvious drips. Headed towards Rochester on US52 South. In another 20 miles again, the coolant blinker. This time after I filled the expansion tank again, I decided to not tighten it all the way so it would not pressurize the system, maybe I'd get a bit further before tossing in the towel for the day.. Got another 40 miles, Well past Rochester, and had to stop to top it off again seeing the the blink again. Another 30 miles later I took another look, not having spotted the red blinkey light yet, but not wanting to push it. Topped it up again, then made it the rest of the way home, I guess another 40 miles.
All told, I lost just under a gallon of coolant over roughly 150 miles.. I suspect the oil cooler, or something within about 6 inches...
Here's a few shots from underneath, when I got her in the garage on arrival home.
_________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
4Gears4Tires Samba Member
Posted: Sat Mar 13, 2021 8:46 pm Post subject: Re: What did YOU do to your van today? |
How's your oil looking? Hopefully it's not dumping coolant into your oil. _________________ '87 Syncro
Posted: Sat Mar 13, 2021 9:01 pm Post subject: Re: What did YOU do to your van today? |
Oil was normal looking. At least it was in ST Paul, figured right away the reason I wasn't seeing a drip was if it was going into the oil... Later, I started seeing an obvious area of coolant leak evidence near the thermostat housing area. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Sat Mar 13, 2021 9:24 pm Post subject: Re: What did YOU do to your van today? |
bobbyblack wrote: |
Oil was normal looking. At least it was in ST Paul, figured right away the reason I wasn't seeing a drip was if it was going into the oil... Later, I started seeing an obvious area of coolant leak evidence near the thermostat housing area. |
That last picture shows what looks to be a cracked hose at the clamped connection, the smaller hose in the picture. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Sat Mar 13, 2021 9:29 pm Post subject: Re: What did YOU do to your van today? |
jlrftype7 wrote: |
That last picture shows what looks to be a cracked hose at the clamped connection, the smaller hose in the picture. |
Indeed, and there's a drip there too. I've got to clean this all up to even start looking... Living on a 2 mile dirt/gravel road sure sucks ... that oil filter was changed less than 2000 miles ago. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Sun Mar 14, 2021 6:41 am Post subject: Re: What did YOU do to your van today? |
djkeev wrote: |
It was an air pocket.
Dave |
Ah hah....Finally read your thread update- congratulations. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
andy52 Samba Member
Posted: Sun Mar 14, 2021 1:32 pm Post subject: Re: What did YOU do to your van today? |
fire extinguisher
reverse light
rear window protection
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6798 Location: Fort Lauderdale, Fl.
Posted: Sun Mar 14, 2021 6:15 pm Post subject: Re: What did YOU do to your van today? |
Another VW night.
Replacing the TPS. _________________ This free advice is worth exactly what you paid for it.
SlalomVan Samba Member
Joined: March 28, 2006 Posts: 127 Location: Seattle, WA
Posted: Mon Mar 15, 2021 8:51 am Post subject: Re: What did YOU do to your van today? |
Changed my fuel filter! Amazed that it still worked with all the crud that came out of the inlet side when emptied.
_________________ 1989 Vanagon GL - 2.1 (White - "Northlake" Totaled/Gone)
1988 Vanagon GL Wolfsburg (Orly Blue - "Poulsbo" - Sold)
1989 Vanagon G - 2.1 (White - "Kingston") - Full rebuild underway - Last on the road in 1997 |
Posted: Mon Mar 15, 2021 12:52 pm Post subject: Re: What did YOU do to your van today? |
SlalomVan wrote: |
. Whoa. Any idea how old your tank is.... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Mon Mar 15, 2021 1:07 pm Post subject: Re: What did YOU do to your van today? |
[/quote]. Whoa. Any idea how old your tank is.... [/quote]
My tanks is original to the van - 1988. I pulled the tank almost exactly a year ago to change the cross-over vent hoses and put in a new fuel gage sending unit. At the time, I flushed it out with some gasoline and it looked nice and clean inside with no visible areas of rust. I also replaced the filter at that time. So this is filth has accumulated in the filter over the last year and about 6,000 miles. I was shocked to see this much crud, considering that it was running just fine. I am going to check it in another 3 months. Hopefully it won't look anything like this! _________________ 1989 Vanagon GL - 2.1 (White - "Northlake" Totaled/Gone)
Posted: Mon Mar 15, 2021 1:52 pm Post subject: Re: What did YOU do to your van today? |
Ethanol, by chance? _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Mon Mar 15, 2021 7:05 pm Post subject: Re: What did YOU do to your van today? |
bobbyblack wrote: |
Ethanol, by chance? |
Yes. Here in Washington State the gas available is labeled as having up to 10% Ethanol. _________________ 1989 Vanagon GL - 2.1 (White - "Northlake" Totaled/Gone)
