What did YOU do to your van today?
Page: Previous  1, 2, 3 ... 251, 252, 253 ... 527, 528, 529  Next
joetiger Premium Member
joetiger is offline
PostPosted: Sun Apr 22, 2012 7:53 am    Post subject: Reply with quote
Installed new front bearings, rotors, and pads last night. Added to the new flex lines and last year's rear brake rebuild, I am a stoppin' fool.
The lack of motivation regarding interior and body work has really motivated me to get everything else in order. Pretty soon I'll have no choice.
Joe T.
'86 NAHT Vanagon GL Syncro/ supercharged ABA 2.0
'85 928S
'19 Golf R
'02 Beetle GLS
rlamb
rlamb is offline
PostPosted: Sun Apr 22, 2012 11:01 am    Post subject: Reply with quote
I finally figured out why none of my idiots lights or gauges were working - they were no longer grounded due to a really small break between the grounds (pin 2 and 5) on the 14-pin male connector for the intrument cluster. I did this to fix it, and it worked great:
crazyvwvanman wrote:
The way I would deal with the cluster grounds on 80-84 is to cut both brown wires about 3" from the edge connector. Tie the two short 3" ends together and extend them with a thicker wire to a screw that attaches to the body. Then attach the other 2 long ends to just each other. Done.
There are other ways people might be tempted to do this but danger lurks!
Mark
[/quote]
I also put in a new grease cap and speedo cable, so the speedo and odometer now work for the first time in years. I put on a new OEM antenna, and fixed a broken muffler support bracket.
1984 Westfalia - Ford Cologne 2.8L conversion
2003 Passat GLX Wagon (4Motion)
RCB
RCB is offline
PostPosted: Sun Apr 22, 2012 12:19 pm    Post subject: Reply with quote
Nothing to exciting but since I got new Hankooks last week I thought Madam Helga would like a new set of stainless trim rings and a new set of hub's. Very Happy
DAIZEE
DAIZEE is offline
PostPosted: Sun Apr 22, 2012 12:41 pm    Post subject: Reply with quote
Pics or it didn't happen! Imagine pre digital cameras, oh well then we wouldn't be here even Laughing
'09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold)
Smokey Orange
Smokey Orange is offline
PostPosted: Sun Apr 22, 2012 2:24 pm    Post subject: Reply with quote
I got my badges finished up and installed today... Just in time for friends to drop of the motor!
-Lloyd
DAIZEE
DAIZEE is offline
PostPosted: Sun Apr 22, 2012 2:51 pm    Post subject: Reply with quote
What's that across your lower rear end? I like it.
Smokey Orange
PostPosted: Sun Apr 22, 2012 3:12 pm    Post subject: Reply with quote
Thanks! As for the lower portion it reads 2.3 Turbo. I had to pull the badge from a Saab 900s for the 2.3 and a Volvo 850 for the turbo... They are the same font.
I'm cleaning a Volvo B230FT 2.3l turbo Inline 4 as we speak Smile Going to have to fab everything. Have a Saab APC piggyback electronic knock based setup going into the mix. Projecting mid 200's for the base tune. I'm from the Nissan sports camp... all this is new to me, the engine and van, but it's going to be awesome.
-Lloyd
DAIZEE
DAIZEE is offline
PostPosted: Sun Apr 22, 2012 3:17 pm    Post subject: Reply with quote
oops sorry I meant the grill like arranged on your LOWER rear end under hatch Laughing
Smokey Orange
PostPosted: Sun Apr 22, 2012 3:25 pm    Post subject: Reply with quote
For some reason I knew that's what you meant... but I didn't think so because that's how mine came. It's the sheet metal with the bumper assembly removed. I got her in december and she looked like that (minus rust removal and paint) with a welded on tow bar for a bumper.
I've never seen her other then naked back there. Are they not all like that? Perhaps an add on for GL's with fiberglass bumpers. She's an '88 GL 7-pass.
-Lloyd
Timwhy
Timwhy is offline
PostPosted: Sun Apr 22, 2012 3:26 pm    Post subject: Reply with quote
Made my own one of these that GW sells for $75, my cost $10 in material from Walmart.
http://www.gowesty.com/ec_view_details.php?id=23599&category_id=57&category_parent_id=
The one that I made is a bit different. I usually have my GW slider screen door on the Westy
while we are camping. That big curtain on the out side of the screen door would be pretty
useless, I thought! The material I bought is the same gray color as my curtains but is an
outside canvas with a waterproof back. Instead of using the slide track for the curtain, I
put in snaps above where the screen door snaps in, and I'll be able to easily unsnap or
snap the new curtain in place as needed. It has a nice fit and I won't have to worry about
a curtain getting soaked or blowing in the wind.
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
DAIZEE
DAIZEE is offline
PostPosted: Sun Apr 22, 2012 3:28 pm    Post subject: Reply with quote
mmm now I don't know. Can't remember how my 84 Westy GL Wolfsburg looked. My Vanagon L doesn't look like that nor do I recall ever seeing it. But I have limited exposure.
Timwhy
Timwhy is offline
PostPosted: Sun Apr 22, 2012 3:32 pm    Post subject: Reply with quote
Remove the bumper and see?
'15 Audi A3 Quattro
'87 VW Westy
'91 Tin Top
'90 Cabby
DAIZEE
DAIZEE is offline
PostPosted: Sun Apr 22, 2012 3:34 pm    Post subject: Reply with quote
if I don't remove the bumper and crawl underneath back I should be able to see it right.?
Timwhy
Timwhy is offline
PostPosted: Sun Apr 22, 2012 3:35 pm    Post subject: Reply with quote
Yes
'15 Audi A3 Quattro
'87 VW Westy
'91 Tin Top
'90 Cabby
Smokey Orange
PostPosted: Sun Apr 22, 2012 3:41 pm    Post subject: Reply with quote
Ironically even though mine was jacked up, it's one of my favorite lines on the body, right up there with the tops of the front wheel arches!
Thanks for the photo Timwhy!
-Lloyd
delibessleep
delibessleep is offline
PostPosted: Sun Apr 22, 2012 7:38 pm    Post subject: Reply with quote
Drained/replaced the gearbox oil.
Installed a manual switch for the biscuit fans on my fridge.
Replaced the fan switch on the radiator.
63 Single Cab
87 Westy
12 Tiguan
18 Alltrack
Biology is destiny...choose your mutations carefully
madspaniard
madspaniard is offline
PostPosted: Sun Apr 22, 2012 10:03 pm    Post subject: Reply with quote
Finished installation of Fanchers poptop insulation kit, kit looks great and included great instructions and all parts needed. Very happy with this purchase, good quality. Testing it first weekend of May in Yosemite.
Finally mounted my 135w Kyocera solar panel to my poptop Yakima rack crossbars using SS U bolts and their backing plates. Solid. I was tired of carrying that big panel inside while on the road.
"The only difference between me and a madman is that I'm not mad - Salvador Dali
nelinor
nelinor is offline
PostPosted: Sun Apr 22, 2012 10:35 pm    Post subject: Reply with quote
I mounted up the fiamma f35 pro.
Cant wait to get out and use it.
1983.5 VW Vanagon Westfalia - manual - EJ22
2002 Subaru Impreza Wrx
1990 Nissan 300zx tt
View user's profile Send private message Facebook Twitter Gallery Classifieds Feedback
nelinor
nelinor is offline
PostPosted: Sun Apr 22, 2012 10:46 pm    Post subject: Reply with quote
ohlott
ohlott is offline
PostPosted: Mon Apr 23, 2012 9:00 am    Post subject: Reply with quote
Let's see some pics!
83.5 westy 2.2 subi
Page 252 of 529
