dhaavers Samba Member
Joined: March 19, 2010 Posts: 7000 Location: NE MN (http://g.co/maps/zt72q)
Posted: Sun Oct 25, 2020 3:57 pm Post subject: Re: What did YOU do to your van today? |
^^^ Already looks less dusty than mine, any day of the year... ([email protected] forest roads...)
- Dave _________________ 86 White Westy Weekender
"The WonderVan"
Vanlife Geek Samba Member
Posted: Sun Oct 25, 2020 5:38 pm Post subject: Re: What did YOU do to your van today? |
I purchased a Verizon 8800L MiFi off eBay which gives me unlimited data with no throttling and no caps (it has special "mojo"!). This gives me the ability to stream video (assuming I have a decent cell signal), so I thought I'd get a Roku unit for my existing TV. While I was at it, since my 12V TV only has one HDMI input, I added a small HDMI switch so I can switch between the RoKu and my laptop by simply pushing a button. Since my existing broadcast antenna and the RoKu both need USB power and the TV only has one USB port, I also added a tiny USB hub which I already had. It's all semi-neatly mounted on the back of the TV and is hidden from view. It worked out really well. The TV speakers suck, as is to be expected, so I've routed the audio to a small Anker speaker, which has way better quality. I have a decent movie collection on an external hard drive for when I don't have cell coverage. I know many of you will question why I want that many entertainment options in a camper when I should be enjoying nature, but I will be moving into the van full-time in January and will want some "home comforts", plus I'm just sort of a geek that way. Although most of my time will be spent hiking through the high mountain forests and desert (depending on time of the year) taking pictures and making videos, I'll still want to keep up with the news and "Netflix & Chill". Plus I'll be uploading videos to YouTube and don't really want to depend on Starbucks, McDonald's, etc. for WiFi, although I do have an external, amplified WiFi antenna and router just in case. Next is probably a cell booster antenna, but that's another post.
Note the MiFi velcro'd next to the cup holder above some charging ports in the above image. The TV is hardwired and is controlled by a switch, which also activates the USB ports, a 12v port and a voltmeter.
_________________ Vanlife Geek
Current:
1986 Syncro Westy
Previous:
1983 Westy
1981 Westy
1972 Bug (Last year you could buy a new one for under $2,000)
1965/66 Bug (2 bugs from a junk yard combined to make 1 functional bug)
1959 Bug (Pre Gas Gauge Era) |
mcarlson_sb Samba Member
Posted: Sun Oct 25, 2020 6:31 pm Post subject: Re: What did YOU do to your van today? |
We finally got the moded closet (almost) back in today.
The doors are still getting a few coats of polyurethane and will follow tomorrow.
The wood for the pantry, backing boards, and new shelves are upcycled from a discarded Ikea dresser our neighbors put on the corner.
Doors are left over birch plywood we've been using to replace panels.
Also, my wife finished the first few denim curtains that go behind the closet.
The rest will follow.
It's nice to have solar hooked back up keeping the batteries topped up.
Cheers,
Matthew |
jlrftype7 Samba Member
Posted: Sun Oct 25, 2020 8:08 pm Post subject: Re: What did YOU do to your van today? |
mcarlson_sb wrote: |
Cheers,
Matthew |
. Very Nice!!!!.....  _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
'67 Type 3 Fastback, my 2nd car- also long gone
'69 Semi-Auto Stick Shift Beetle, my wife's first car= yep. still long gone....
‘84 Tin Top - Hilga....Auto |
Posted: Sun Oct 25, 2020 8:53 pm Post subject: Re: What did YOU do to your van today? |
With doors
andy52 Samba Member
Joined: December 17, 2019 Posts: 77 Location: Barcelona
Posted: Mon Oct 26, 2020 2:16 am Post subject: Re: What did YOU do to your van today? |
fishgo wrote: |
What year is the van and what materials groups are those? Carpet, floor, door panels, etc. Looks sharp! |
the van is a '89 caravelle GL
The dash has a leather trim on top as you can see, that was washed and treated The dash was polished, and repainted to satin black, did it myself
The carpet is nailon material color black, bought it online and glued it with spray glue for the purpose
on top of it I put the rubber floor matts, easy to clean, and it gives a heavy duty look i like
the door cards are synthetic leather, colour black, bought them online, replaced them myself. I added those net storage compartments, love them
the seats are the best part. took them to a really oldschool upholsterer specialist in classic cars. Seats are the original, he made full upholstery in brown for the front and back seats, i've never seen such a good quality job as this one. material is "skay", some type of synthetic leather |
revolution337 Samba Member
Joined: May 23, 2009 Posts: 146 Location: Pennsylvania
Posted: Mon Oct 26, 2020 6:44 am Post subject: Re: What did YOU do to your van today? |
Finally looked into why my high beam indicator was not working in the cluster. Traced it down, found a loose wire on the back of the fuse panel for the left high beam fuse. Snipped off the spade connector and installed a new one. Clipped back onto the fuse panel and checked function, now it works! Don't know why I waited so long to address it, glad it was a simple fix. |
Posted: Tue Oct 27, 2020 8:03 pm Post subject: Re: What did YOU do to your van today? |
Surfer Dude PO had turned the rear overhead lockers into a (poor) soundbox for speakers using a combination of hand saws, screws, duck tape, spray foam, and pure evil.
I've removed the speakers, patched the holes with wood from a salvaged ikea dresser, cut away the extra with a chisel, and used wood filler to cover my mistakes and poor life choices. Currently waiting for the filler to dry so I can sand it.
Then we will add some new contact paper to the inner lockers and spray tool dip for the outer (where shower stuff goes) before mounting a laminated map my wife bought underneath. |
Alluvial Van Samba Member
Joined: November 10, 2012 Posts: 118 Location: San Diego, CA
Posted: Wed Oct 28, 2020 4:29 pm Post subject: Re: What did YOU do to your van today? |
Sent off my odometer/speedometer to get fixed. My odometer hasn't worked in the 8 years I've had the van and excited to be able to track mileage for maintenance purposes instead of guessing based on time. The simple things. |
vanis13 Samba Member
Posted: Wed Oct 28, 2020 7:01 pm Post subject: Re: What did YOU do to your van today? |
Rescreened side screens with conventional channel
Full topic here https://www.thesamba.com/vw/forum/viewtopic.php?p=9491486#9491486
_________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
leecat Samba Member
Joined: September 13, 2012 Posts: 271 Location: Regina
Posted: Wed Oct 28, 2020 7:10 pm Post subject: Re: What did YOU do to your van today? |
FINALLY found a full used skylight setup in great shape, and the final single 14" factory alloy to complete my set. Need to sand down and repaint the alloy (L091 paint, according to the good ol' Samba knowledge base) before clearcoating it. So much fun stuff to work on over the winter - Spring is coming!!!  |
Posted: Wed Oct 28, 2020 8:26 pm Post subject: Re: What did YOU do to your van today? |
Though thousands of miles passed over decades with the golf umbrella staying where it should, a recent post reiterated that possible issue of it sliding back preventing the door from opening so printed this....a little color bling until I get back back in the printer
_________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace |
Posted: Sat Oct 31, 2020 3:57 pm Post subject: Re: What did YOU do to your van today? |
I really need to take out the window, remove the rust, use a converting primer, and repaint.
But, that's not a possibility right now. So instead I tried to cut, polish, and wax to see if I can at least protect what is currently there and make it look not quite so bad.
Now, to do the rest of the van. |
4Gears4Tires Samba Member
Posted: Sun Nov 01, 2020 10:37 am Post subject: Re: What did YOU do to your van today? |
I would paint some rust converter on top of the rust in the mean time. It'll slow the rusts roll somewhat. Mar-Hyde, Ospho, etc, even just paint will do something. _________________ '87 Syncro
Posted: Sun Nov 01, 2020 6:44 pm Post subject: Re: What did YOU do to your van today? |
My wife was amazing today!
She took a rats nest of wiring (solar, two independent AUX battery banks, starter batter, Prosport on board battery charger, inverter, etc.) and made it sane. This also has the side effect of creating more usable storage space under the sink.
Also, we reworked what was our old poorly done pantry space in the fridge cabinet and converted it back to hold our new12v fridge.
We still have some work to build a shelf above and a pull out drawer beside. But that will be another weekend.
Also, also - the fridge is now hook up to AUX power and can be used.
Also, also, also, we have a better system for the stoves 1lb propane cylinder. The one in use fits into 2 hose clamps in the top right of the fridge cabinet. The propane hookup used to be in the electric cabinet - and that always made me a little nervous.
I'm much happier with this system. Better use of space and gas isn't right next to a potential spark.
Also, also, also, also, we found a use for the little cubby.
Previously we has cooking gear there, but it worked *poorly*
We basically had to tear the van apart to get things out.
Now the Little Buddy Heater we picked up and spare propane fits it perfectly.
Its gone from annoying to convenient.
After we add the shelf above the fridge cooking gear will stowe there.
We are quickly getting to a place for all the things and everything in its place.
Posted: Sun Nov 01, 2020 7:25 pm Post subject: Re: What did YOU do to your van today? |
And while I wasn't looking my wife finished the denim roll up blinds
kiltedhiker Samba Member
Posted: Mon Nov 02, 2020 7:17 pm Post subject: Re: What did YOU do to your van today? |
Upgraded my wheels and tires from 15" Mefros with BFG KO2 215/75r15 to CLKs with BFG KO2 215/70r16
_________________ 1989 Syncro Westfalia (bought new) sold
1990 Syncro Westfalia sold
1990 Syncro TinTop |
Posted: Mon Nov 02, 2020 7:55 pm Post subject: Re: What did YOU do to your van today? |
^^^ Sweet!
- Dave
PS: How much you want for the Mefros...???  _________________ 86 White Westy Weekender
"The WonderVan"
andy52 Samba Member
Posted: Tue Nov 03, 2020 6:15 am Post subject: Re: What did YOU do to your van today? |
kiltedhiker wrote: |
LOVE IT |
Vancouveria Samba Member
Joined: September 28, 2020 Posts: 8 Location: Puget Sound
Posted: Wed Nov 04, 2020 8:22 am Post subject: Re: What did YOU do to your van today? |
Last night’s goal was to clean out under the rear seat. The heater control valve had leaked previously so the heater was bypassed. Once we pulled the seat things were even more disgusting than we had imagined, so now we’ve deleted the rear heater and are pulling up the floor.
Any hints on removing the wall panels on an 85 Weekender? In the spirit of “while we’re at it” we want to clean behind them and check for hidden rust.
