What did YOU do to your van today?
Page: Previous  1, 2, 3 ... 550, 551, 552, 553, 554, 555  Next
aidanp
aidanp is offline
PostPosted: Thu Nov 19, 2020 8:07 am    Post subject: Re: What did YOU do to your van today? Reply with quote
Fitted GoWesty rear inertia seatbelts.
1989 Vanagon Westfalia, with 2.5l Subaru by SmallCar, manual 'box, 16" wheels.
andy52
andy52 is offline
PostPosted: Thu Nov 19, 2020 10:29 am    Post subject: Re: What did YOU do to your van today? Reply with quote
u guys are lucky u get gowesty parts...
they charge me more in shippings than the item itself
shadetreemech
shadetreemech is offline
PostPosted: Mon Nov 23, 2020 4:37 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Cut out the Reflectix for the pop top:
https://www.thesamba.com/vw/forum/viewtopic.php?t=463901
Measure Twice, Cut Once.
Dan
'84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "Miss Dorothy"
space
space is offline
PostPosted: Wed Nov 25, 2020 9:50 am    Post subject: Re: What did YOU do to your van today? Reply with quote
Rear Disc conversion
16" tire conversion
aidanp
aidanp is offline
PostPosted: Fri Nov 27, 2020 9:50 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Fitted LED headlight bulbs (Torchbeam T2 9004) from Amazon:
https://www.amazon.com/gp/product/B07T1QKLXY/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
Big improvement over the regular bulbs, and they don't seem to dazzle oncoming drivers.
175grams
175grams is offline
PostPosted: Sat Nov 28, 2020 11:31 am    Post subject: Re: What did YOU do to your van today? Reply with quote
We're these a direct plug n' play install or did you have to change the base? Might be worth trying.
campism
campism is offline
PostPosted: Sat Nov 28, 2020 3:50 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Apologized to it for thinking it was leaking gas and freaking out about it. Turns out it was my neighbor's Beetle Turbo GSR that had a fuel line chewed on by pesky critters, was leaking fuel copiously a hundred feet away, and I wound up working on it instead of on my own VW.
'87 Westy in Wolfram Grey Metallic
aidanp
aidanp is offline
PostPosted: Sat Nov 28, 2020 5:33 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Yes, plug and play. A doddle to fit - remove locking ring, remove old bulb, insert new one, refit locking ring and plug into old connector.
fxr
fxr is offline
PostPosted: Sat Nov 28, 2020 5:52 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
I'm disappointed they all seem to be 6000K or 6500K - far too 'blue' a light for me at night-time. That also doesn't help peripheral vision when it's dark.
It seems to be 'the fashion' though, sigh.
Jim Crowther
Vespa GTS 300
andy52
andy52 is offline
PostPosted: Sun Nov 29, 2020 1:44 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
ive been trying halogen bulbls which are supposedly white and they all seem yellow to me
this time i got the Phillips white vision ones and i even called a friend maybe i dont see colours properly... but he also said yellow hahaha
and on the other side the LED poisition light seem blue hahha
so i bought LED H4 & H3 (my van is european..) and ill try them on this week.
of course, nothing above 55W since I have the stock wiring
bobbyblack Premium Member
bobbyblack is offline
PostPosted: Sun Nov 29, 2020 6:18 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
House battery, installed. Glad I have to go to the office tomorrow... Im pooped!
'87 Westy 'Flossie','83.5 Vanagon L 'ZoomBus','74 Karmann Ghia, '63 Notch
andy52
andy52 is offline
PostPosted: Tue Dec 01, 2020 3:54 am    Post subject: Re: What did YOU do to your van today? Reply with quote
plugged LED bulbs H4 45W, H3 50W + position light/day light
vid: https://i.imgur.com/B3MgOSW.mp4
happy with them so far
aidanp
aidanp is offline
PostPosted: Tue Dec 01, 2020 7:42 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Looking good!
andy52
andy52 is offline
PostPosted: Wed Dec 02, 2020 2:08 am    Post subject: Re: What did YOU do to your van today? Reply with quote
Looking good!
videos uphill & downhill
https://i.imgur.com/wm48rZs.mp4
https://i.imgur.com/UGM0I7E.mp4
not bad
aidanp
aidanp is offline
PostPosted: Wed Dec 02, 2020 2:42 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Looking good!
not bad
A massive improvement!
PostPosted: Fri Dec 04, 2020 5:49 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
Alt belt had chirped a bit this morning on startup, ~4.5C in garage overnight.....
it settled out in a couple seconds...
(wait for it now)
Then on the way home, after a stop at the grocery store, it chirped more for 4 or 5 seconds.
Then at the last stop light it really chirped, and then ---ta-daaaa! Red lights on dash!! Bingo, belt blew. Sad really, no more than 3K miles on Napa's premium belt.
So, in a 12 miles drive, it went from just a little chirp to completely tore up.
And, guess what?!?!? it ripped off the PS and A/C belts just for spite.
So, moved bedding, groceries, got out tools from under the bench, and on the side of the road, only 100 yards from the intersection where literally 300 cars went by, I replaced the Alt and PS belts. Nobody pulled over, and I am very certain at least half of them had seen me wave to them on the road over the years. Then again, I guess it only took me 10 minutes.
Noticed more flex in the alternator bracket than I remember. Maybe I've got to dig deeper for a cause of this flex, as that certainly would stress a belt. I know I have seen a TON of posts about better brackets and or broken brackets.
At least I didn't just keep driving saying to myself "It's only 4 miles, that's not too far, right? (wrong)"
-bobby
andy52
andy52 is offline
PostPosted: Sun Dec 06, 2020 1:00 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
added switchback LED bulbs on the front indicators, that means, I have extra position lights at the same time i have indicators,
video of how all the LED front set up looks like
https://i.imgur.com/xYcmGo5.mp4
next step would be convert them to driving lights that turn off when I put position lights on. I'll leave that for the future.. enough time and money invested in the lights!
how to:
throw a cable from the position light cable
take it out through the indicator wiring rubber
plug all the wiring to a double lamp holder
Steve M.
Steve M. is offline
PostPosted: Sun Dec 06, 2020 4:20 pm    Post subject: Re: What did YOU do to your van today? Reply with quote
andy52 wrote:
That RED snap on connector is just asking for trouble down the road.
They work, but they allow moisture to get in under the insulation and corrode the wiring.
Stereo shops and UHaul shops use them all the time. They are just a mistake to use.
4Gears4Tires
4Gears4Tires is offline
PostPosted: Mon Dec 07, 2020 1:46 am    Post subject: Re: What did YOU do to your van today? Reply with quote
What's your recommendation for a wire tap?
'87 Syncro
Ferric Oxyhydroxide Superleggera Edition
dhaavers
dhaavers is offline
PostPosted: Mon Dec 07, 2020 7:56 am    Post subject: Re: What did YOU do to your van today? Reply with quote
https://www.motorcycle.com/how-to/mo-wrenching-how-to-properly-splice-wires
FWIW...if not willing to strip & solder, for any connection outside the shell of the van
I'd at least look for something designed weatherproof for wet conditions:
https://smile.amazon.com/BLBS-Low-Voltage-Wire-Con...l_huc_item
- Dave
86 White Westy Weekender
"The WonderVan"
Page 551 of 555
