4Gears4Tires Samba Member
Posted: Sat May 08, 2021 8:11 pm Post subject: Re: What did YOU do to your van today? |
I washed it! I don't think I have washed it in over a year so it was pretty overdue. _________________ '87 Syncro
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Sun May 09, 2021 10:02 am Post subject: Re: What did YOU do to your van today? |
Installed the Vanistan (tencentlife's) excellent fresh/recirculated air control system yesterday.
Note, if you have EPAS then you might think you need to let that down to the floor in order to see what's what with the cable - that's a PITA and not necessary - remove the cluster instead, far, far easier!
Also, when removing the spring-clip for the rear vent cable, ensure it doesn't fly into the black hole of the folds in the chassis. If it does, consider using that cable for the control, rather than installing the supplied one.
I also added some 0.3 micron filter material in front of the intake screen - last years fire smoke was very unpleasant to drive through. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Mon May 10, 2021 6:13 am Post subject: Re: What did YOU do to your van today? |
It's such a nice modification! I like your filter idea, I might give that a go. The pollen has been really bad the last week in the DC area. _________________ '87 Syncro
fxr Samba Member
Posted: Mon May 10, 2021 7:59 am Post subject: Re: What did YOU do to your van today? |
This is the filter material (Mrs fxr acquired it for making masks):
https://www.amazon.com/Polypropylene-Filtration-Electrostatic-Efficient-Non-woven/dp/B08L3D73VQ
If you bend back the screen at the top by 1/8" or so then the filter will cling to the spikes. The front grille then holds it all firmly in place. _________________ Jim Crowther
Vespa GTS 300 |
jAndrew Samba Member
Joined: October 11, 2020 Posts: 306 Location: Atlanta, Georgia
Posted: Mon May 10, 2021 2:29 pm Post subject: Re: What did YOU do to your van today? |
New radio install. So far liking a lot and looks pretty unassuming. Streams from the phone, good display that's easy to see and make the same color as the rest of the Doka.
_________________ '89 Syncro Doka |
dlosey Samba Member
Joined: May 05, 2008 Posts: 42 Location: Winterset, Iowa
Posted: Mon May 10, 2021 4:52 pm Post subject: Re: What did YOU do to your van today? |
After owning my 88 Westy for 20plus years I finally got the cruise control repaired. A Ken Wilford video and a 59 cent rubber washer trimmed to fit the switch piston is all it took! _________________ '88 Westy, |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Mon May 10, 2021 4:58 pm Post subject: Re: What did YOU do to your van today? |
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
shadetreemech Samba Member
Joined: October 05, 2005 Posts: 777 Location: Claremont, CA
Posted: Mon May 10, 2021 5:55 pm Post subject: Re: What did YOU do to your van today? |
Opened the slider and put in the box of Devcon Titanium Putty I ordered in March. Just arrived today from Estonia. I'll be starting on the Westy's case repair shortly.
Dan _________________ '84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "MZDRTHY" |
Blakesinclair Samba Member
Joined: January 22, 2021 Posts: 60 Location: Santa Ana, California
Posted: Wed May 12, 2021 6:29 am Post subject: Re: What did YOU do to your van today? |
Blakesinclair wrote: |
Replaced the old destroyed horn ring. Beep beep kids are stoked. |
Update: Its been about a week since I fixed the horn and I have yet to use it. All my time driving with a broken horn, I needed it almost daily. But now that it works, the world seems to be driving in perfect harmony. _________________
1985 Weekender Vanagon 1.9L - Manual |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
wheatenwestie Samba Member
Joined: February 27, 2016 Posts: 5 Location: Ellensburg, WA
Posted: Thu May 13, 2021 6:03 pm Post subject: Re: What did YOU do to your van today? |
Upgraded starter using Karl's adapter. Night and day difference. Replaced used coil with new Bosch variety. |
Posted: Fri May 14, 2021 7:20 am Post subject: Re: What did YOU do to your van today? |
Installed an Autovox V5 dashcam that has a front and rear camera. Drivers around here have really gotten out of hand and many years ago having one when my wife was in a fender bender in another vehicle really saved the day as the other driver was not honest about being at fault.
Pretty tedious to get the wires fished up the A-pillar. I will replace the headliner so I wasn't too careful with pushing it back in and making it pretty. It's in a Doka and I ran the cable for the rear camera in some split loom along where the coolant pipes run and into the engine bay. I drilled a 1/2 hole between the tag lights and ran the cable thru a grommet and attached above the tag. I would have rather placed it inside at the top of the rear window but would need to get a new mount fabricated. I might still go that route in the future though.
I've only driven a couple of times so far and having a video feed instead of the mirror is odd. I do not see a way to turn the display off and still have it recording, which would be nice. It seems a little dark in bright sunlight as well to me. Time will tell.
Posted: Fri May 14, 2021 7:23 am Post subject: Re: What did YOU do to your van today? |
Installed the GW alternator bracket support thing yesterday. Turns out the whole orginal bracket was loose. One nut was missing and the other was loose. Getting to those things was a nightmare, but I tightened them best I could with a little blue locktite, and hopefully with the support bracket itll be ok. _________________
jlrftype7 Samba Member
Posted: Sat May 15, 2021 1:04 pm Post subject: Re: What did YOU do to your van today? |
Finally installed the DIY Rear Cabinet that I made recently.
Sliding doors, 3 shelves, and a dropped lower section that stores 5 qt oil bottle out of the way of the lowest shelf.
Baltic Birch, 3/4 and 1/2 thicknesses as needed. Doors are actually 1/4 Birch, but I flipped the plywood around since the Laun veneer layer looked more interesting as a contrast to the birch next to it. Made the doors darker as well.
A bit of brown T- Moulding, finish is Old Masters Golden Oak Gel Stain, several coats of Epifanes Rapid Clear and one top coat of Rapid Coat( tinted varnish with Brown tint to it). Interior got several coats of Outdoor Lacquer that I had on hand.
Mounting is 2 steel angle brackets on the floor, and 1 custom setup using the VW rear seat belt welded nut on the back pillars( 7/16 fine thread). I used 3/8 pipe nipple as the spacer/bushing around the 7/16 bolt, so the bolt tightens the cabinet up against the body but doesnt pull it anymore than whats needed.
_________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
84 Tin Top - Hilga....Auto |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3100 Location: ABQ NM USA.... Except when not
Posted: Sat May 15, 2021 2:23 pm Post subject: Re: What did YOU do to your van today? |
(above)
is that your shop or one of those rent-a-lift places? _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Sat May 15, 2021 5:20 pm Post subject: Re: What did YOU do to your van today? |
vanis13 wrote: |
(above)
is that your shop or one of those rent-a-lift places? |
My work, out in the Suburbs. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
1971BugGuy Samba Member
Joined: October 16, 2004 Posts: 426 Location: Ontario, CANADA
Posted: Sat May 15, 2021 8:14 pm Post subject: Re: What did YOU do to your van today? |
My high-heat adhesive arrived from Amazon so I was able to finish my driver side interior door panel.
_________________ Only a fool or a child would judge a project before it reaches its completion.
1971 Super Beetle
1986 Vanagon Westfalia Weekender |
Posted: Sat May 15, 2021 8:26 pm Post subject: Re: What did YOU do to your van today? |
jlrftype7 wrote: |
Kudos to you. It looks fantastic. I'd love to be able to get a glimpse inside at all of those wonderful details you spoke of. _________________ Only a fool or a child would judge a project before it reaches its completion.
1971 Super Beetle
Posted: Sun May 16, 2021 6:23 am Post subject: Re: What did YOU do to your van today? |
1971BugGuy wrote: |
jlrftype7 wrote: |
Kudos to you. It looks fantastic. I'd love to be able to get a glimpse inside at all of those wonderful details you spoke of. |
. Ill post some of the build pictures this morning. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Sun May 16, 2021 6:28 am Post subject: Re: What did YOU do to your van today? |
