jlrftype7 Samba Member
Posted: Fri Oct 22, 2021 12:22 pm Post subject: Re: What did YOU do to your van today? |
bobbyblack wrote: |
Developed a hunting idle, figured I have a vacuum leak. Got out my smoke machine, I seem to have a little leak through my cruise control vacuum canister relief valve. I have not used my CC much.. maybe that is why it just "lets loose" when going along .. never has worked other than at about 58-59 mph.
Anyway, I need to find a decent "plug" for the AFM hole. Anyone know of a good match for a plug the size of the AFM when its taken out of the engine area? |
Any chance you can take the intake boot over to a hardware store or big box store and match up PVC/ plumbing drain pipe caps to the ID of the boot?
You'll get a smooth surface to clamp to, so probably no leaks once you are smoke testing the system with the boot reinstalled. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
84 Tin Top - Hilga....Auto |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4332 Location: United States, Iowa
Posted: Fri Oct 22, 2021 1:32 pm Post subject: Re: What did YOU do to your van today? |
I carry a spare AFM in my bus... so I guess I just take the AFM in with me, find some jar or other product that matches.. Like a jar of olives or such that I would chomp on while awaiting the smoke machine to fill the intake... makes me laugh a little about 'smoke machine' and 'Lid' .. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4020 Location: Redwood City, California
Posted: Fri Oct 22, 2021 4:17 pm Post subject: Re: What did YOU do to your van today? |
You must have a Non FActory Cruise system. The stock CC does not use intake vacuum. It has it's own Vacuum or Bi Pressure pump to activate the bellow.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
Mckinleyvillian Samba Member
Joined: July 22, 2021 Posts: 504 Location: Macktown, CA
Posted: Sat Oct 23, 2021 5:29 pm Post subject: Re: What did YOU do to your van today? |
PO had made a mess at the exhaust stud, leading to a crack in the head. So I pulled it today! Took about 90 minutes. It was far easier than replacing fuel tank, rerunning/routing fuel line, etc. Slap that new head on next week along with my 2.1 exhaust and new cat. Frickin stoked.
[url=https://www.flickr.com/gp/67006022@N04/My9AB1] _________________ so many roads i know
all i want is one to take me home
85 Vanagon GL 1.9 stick |
TomInAlaska Samba Member
Joined: June 02, 2007 Posts: 385 Location: Anchorage, Ak
Posted: Sat Oct 23, 2021 9:59 pm Post subject: Re: What did YOU do to your van today? |
I finished getting my "new" wheels and studded tires bolted up thanks to new studs, nuts, and spacers from T3!
_________________ '73 Super Beetle (resto-mod/rally look, 1776)
'84 GL adventure van project (1.9L, 4speed) https://www.thesamba.com/vw/forum/viewtopic.php?t=755844&highlight=
Posted: Sun Oct 24, 2021 7:18 am Post subject: Re: What did YOU do to your van today? |
Tested my Group 41 battery , still tests very good.
Removed and cleaned the Aux Air Valve, then adjusted it for a bit longer cold engine operation.
Replaced two vacuum hoses as a preventative measure while I had that all apart. They were getting rock hard, so time to go before , they went further and started cracking on me
happy2CU Samba Member
Posted: Sun Oct 24, 2021 8:02 am Post subject: Re: What did YOU do to your van today? |
replaced driver and front passenger seat belts. |
Diy2k Samba Member
Posted: Sun Oct 24, 2021 8:39 am Post subject: Re: What did YOU do to your van today? |
Pump bearing is toast, sounds like slight rod knock. This one cost me 32$ from Rockauto. _________________ 1987 VW Vanagon Wolfsburg Weekender
2012 Ford Transit Connect Xlt |
Posted: Sun Oct 24, 2021 7:31 pm Post subject: Re: What did YOU do to your van today? |
ODO turned 331k miles today, returning our son to the Hawkey U, after a bone graft surgery last Thursday. He's doing pretty well, other than the swelling and pain. .. It was a white knuckle ride, the storm had us on edge, and for whatever reason Iowa drivers knew not how fragile the flow of traffic is, saw evidence of 8 wrecks. Locked up my fronts to avoid a front ender on IA380, recovered. The next 3 hours were just as harsh.
Glad to land and put the bus away, tho ridden hard and left wet.
bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3081 Location: ABQ NM USA.... Except when not
Posted: Sun Oct 24, 2021 8:11 pm Post subject: Re: What did YOU do to your van today? |
bobbyblack wrote: |
bobby |
There aughta be a "What has my Vanagon done for me today" thread
Glad you are back home _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32432 Location: Reading Pennsylvania
Posted: Thu Oct 28, 2021 4:58 pm Post subject: Re: What did YOU do to your van today? |
Installed my Snow Tires onto my new Passat rims. I had drilled out the centers on the rims last night at home, using my Drill press and the Carbide Tipped Hole saw suggested here on Samba.
One more job done before Winter
After a few days of driving, I like the set-up. You can feel that the Passat Rims are a bit lighter than the Mefros, so my Unsprung Weight changed enough that even with the Load Range C Snow Tires, the ride of the Winter Tires is smoother and not the same as when they're mounted on the Mefros.
Still thinking about Hub Caps , or just running them 'bare' for Winter.
I did paint the enlarged hole centers to slow down any rusting, not sure if any salt spray would be held back by plastic Hub Caps even if I had them mounted.
.. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
Posted: Mon Nov 15, 2021 9:33 am Post subject: Re: What did YOU do to your van today? |
Finally identified where my brake fluid is disappearing to. I believe it is the LR wheel cylinder. I can see that backing plate is wet.
That said, now its just a matter of digging in. I've got all the parts on hand for a full rear brake job. Hopeful to do it this coming weekend.
I know brake fluid is fairly corrosive. I'm going to have a few cans of brake clean on hand, but that stuff is really bad. Not real sure how exactly I will avoid exposure. One option, I guess, is to do the work in the driveway. Clashing, of course with the arrival of Winter!! Whoot! Carhartts coverall time again! _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
campism Samba Member
Joined: September 07, 2007 Posts: 4484 Location: Richmond VA
Posted: Mon Nov 15, 2021 4:34 pm Post subject: Re: What did YOU do to your van today? |
Something totally different. Dropped it off at a trusted mechanic to have the front brakes redone. I had ordered new rotors and pads and was planning to pull the van into the garage but the bride started making "Let Jeff do it" noises because of our extensive list of remodeling and repair chores in the queue.
So, while the van is off at the spa I came home to work on bedroom door casing and baseboard and to take the refrigerator apart. _________________ '87 Westy in Wolfram Grey Metallic |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15129 Location: Syracuse, NY
Posted: Mon Nov 15, 2021 10:02 pm Post subject: Re: What did YOU do to your van today? |
I'd rather work on the van and pay someone else to do the home remodel/repair chores...
*says the guy trying to finish a porch remodel before snow/freezing temps fly here..
yeah would rather work on the van.. _________________
Abscate wrote: |
These are the reasons we have words like wanker |
Posted: Tue Nov 16, 2021 5:15 am Post subject: Re: What did YOU do to your van today? |
danfromsyr wrote: |
I'd rather work on the van and pay someone else to do the home remodel/repair chores... |
So would I, but have you tried to get contractors to show up just to give an estimate? We've known this mechanic for decades and can do work on the house ourselves in the time that would otherwise be spent waiting for callbacks. _________________ '87 Westy in Wolfram Grey Metallic |
Posted: Tue Nov 16, 2021 9:42 pm Post subject: Re: What did YOU do to your van today? |
my buddy came over a few days ago and helped me put the new (to me, but used) head on. he really wanted me to pay attention to the green gaskets and make sure they didn't kink up or pop out of place. otherwise, it wasn't too complicated. Pretty sure the next time will be a solo job.
adjusted valves and compression was 140 and 150 on the drivers side (where head replacement happened), so that's pretty cool too.
now I'm putting the 2.1 exhaust on the 1.9. I started taking it all apart back in august. then I got very sick with covid, started a new job, and returned to graduate school within a 3 week period, so it's been on the back burner since then.
getting the exhaust back on wasn't so hard. I remembered to get that nut on the stud by the thermostat housing while the thermostat housing was removed, so that was a plus. cutting the muffler heat shield to size was pretty easy too.
now I've just got to get the muffler to seat in the brackets. it's a tight frickin fit. Hopefully it'll be running this weekend and I can finally get it smogged and drive again! might get a camping/gun shooting/skateboarding trip up the coast over thanksgiving break! _________________ so many roads i know
dobryan Samba Member
Joined: March 24, 2006 Posts: 16473 Location: Brookeville, MD
Posted: Wed Nov 17, 2021 8:24 pm Post subject: Re: What did YOU do to your van today? |
dobryan wrote: |
^^^^^ Good work! |
thanks, man. my buddy who helped has been taking these things apart and putting em back together for 22 years or something like that and I wouldn't be doing any of this without his knowledge and help! _________________ so many roads i know
jimf909 Samba Member
Posted: Mon Nov 22, 2021 4:43 am Post subject: Re: What did YOU do to your van today? |
bobbyblack wrote: |
bobby |
Holy cow, bobby. Have you put 40K or more miles on it over the past two years? Here's hoping all is well with your son. _________________ - Jim
Abscate wrote: |
