86scotty Samba Member
Posted: Sun May 21, 2017 6:57 pm Post subject: Re: What did YOU do to your van today? |
Arcfyre wrote: |
Salvaged some mirrors from an old step van. Cut them to the proper length, then welded them back together. Made some custom mounting brackets and bolted them on the van. Now I finally have mirrors that don't blow over in the wind, plus i feel a little better with convex mirrors for blind spot awareness. Here's a pic of my old man just after I finished the install.
Nice work man! I'd love to see some more pics of those if you have them. _________________ 86 Vanagon Westfalia 87k
1998 Ford E350 4x4 camper build
Vans flip flops |
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Sun May 21, 2017 8:37 pm Post subject: Re: What did YOU do to your van today? |
Nice GMC in the background.
So, you have a thing for retro-cool, or what? _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
singletrackrod Samba Member
Joined: January 14, 2011 Posts: 77 Location: Southern Oregon Coast
Posted: Mon May 22, 2017 1:23 pm Post subject: Re: What did YOU do to your van today? |
I decided to find a tough coating product for one of the high impact areas of the nose on my van. This was recommended by a local auto paint expert. It comes in black, white and clear. Went on easily and I ended up liking the appearance. I'll have to wait to see how it weathers.
_________________ Ella '89 Full Camper - bit by bit I'm importing the pieces from my wrecked '87
Louise '87 Full Camper - bought her new - zero hours 2.5L subie conversion. She had more add-ons and mods than I could ever count. (lost in an accident 10/25/2020)
'08 Stage 2 STI (sold)
'04 Forester XT
'00 4Runner Limited (sold) |
danfromsyr Samba Member
Posted: Mon May 22, 2017 1:29 pm Post subject: Re: What did YOU do to your van today? |
you missed the windshield.
that's where I get rocks hitting the most
singletrackrod wrote: |
Abscate wrote: |
16CVs Samba Member
Joined: February 22, 2004 Posts: 4024 Location: Redwood City, California
Posted: Mon May 22, 2017 11:20 pm Post subject: Re: What did YOU do to your van today? |
Fixed my front G57 calipers after the piston popped out on my Tristar. Oh a horrible feeling when you step on the brake pedal and it goes to the floor.
Stacy _________________ 1987 Syncro Westfalia Triple knob (bastard)
Samba member # 14980
Don't let your van end up in an "abortions" thread. |
campism Samba Member
Joined: September 07, 2007 Posts: 4491 Location: Richmond VA
Posted: Tue May 23, 2017 5:36 am Post subject: Re: What did YOU do to your van today? |
That's what the clear is for.
danfromsyr wrote: |
_________________ '87 Westy in Wolfram Grey Metallic |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1490 Location: Victoria,B.C.Canada
Posted: Tue May 23, 2017 1:35 pm Post subject: Re: What did YOU do to your van today? |
Finished installing an auto trans temp gauge and an aux outlet.
dsdunbar Samba Member
Joined: December 19, 2014 Posts: 564 Location: Crozet VA
Posted: Wed May 24, 2017 10:04 am Post subject: Re: What did YOU do to your van today? |
Changed out my lights for custom made headlights from a local samba member. Really like the output. New set up has HIDs for high and low (outside squares) and the inside square is a "spot light" for primary use off main roads.
Ignore all my clear coat eroded paint spots....
Low/High Beam: H1 HID bulb, 6000 kelvin
Spotlight: H3 HID bulb, 4300 K
Balast: 12V 35W balast
Newly installed Porsche 944 light switch for spotlights, fused and relayed.
_________________ '89 2WD Westy "Grey Goose" - Manual 4spd
Crozet VA
Vanaru EJ25, Peloquin
jimf909 Samba Member
Posted: Thu May 25, 2017 5:00 am Post subject: Re: What did YOU do to your van today? |
^^^^ well done! Looks like a good project! _________________ - Jim
Abscate wrote: |
Posted: Fri May 26, 2017 7:31 am Post subject: Re: What did YOU do to your van today? |
A couple mods I made to these T3 air scoops. The standard install was ok at lower speeds, but failed at higher speeds. Above 80mph they flex and vibrate to the point the glue fails. I also had screws work lose and even the prongs at the top of the vents broke off. I added a center support, glued top (with a flange) and bottom. I also drilled an access hole to easily reach and firmly tighten the back screws. A hardware store plug cleaned things up. Now everything is stable to silly speeds.
'04 Forester XT
regis101 Samba Member
Joined: July 28, 2005 Posts: 2078 Location: Livermore, Ca
Posted: Fri May 26, 2017 2:16 pm Post subject: Re: What did YOU do to your van today? |
Killed an hour and thirty eight minutes by doing R&R to the six slider door wheel/bearings. Used a kit from VC. Cleaned and lightly regreased the tracks.
Much much more betterer. _________________ Peace, Regis |
Paulbeard Samba Member
Posted: Fri May 26, 2017 6:06 pm Post subject: Re: What did YOU do to your van today? |
Above 80mph they flex and vibrate to the point the glue fails. |
Above 80mph, I'd see more carnage than that… _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4348 Location: United States, Iowa
Posted: Wed May 31, 2017 8:35 pm Post subject: Re: What did YOU do to your van today? |
Decided it was time to pull the fridge, maybe see if I could clean out the firebox, etc. And since I was that far in, I knew I was in for a peek at the much anticipated rust. I wasn't quite prepared, even with all the threads Iv'e poured over on the usual nightmare.
So, sure enough, its pretty bad. I had previously been thinking I had most of the places stuffed full of stainless steel scrubbies to keep the vermin out... Well, lets just say I needed to make an emergency run to the store. I will pull the entire kitchen and cabinets sometime soon, but at least for now, I needed to feel like I'd not get 5 mice and 2 snakes while camping this WE.
_________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Italjohn Samba Member
Joined: October 29, 2016 Posts: 193 Location: Molde, Norway
Posted: Fri Jun 09, 2017 7:01 am Post subject: Re: What did YOU do to your van today? |
Today, I removed the two side rear windows, and installed a tinted glass with vent on the passenger side, and an Alu piece with vent on the drivers side (behind the cabinets).
(I didn't snap a pic from the other side, but it looks the same, just black...) _________________ 1990 Feldjäger Syncro AAZ
Click to view image
MyName Samba Member
Joined: February 07, 2013 Posts: 19 Location: Ljubljana, Slovenia
Posted: Fri Jun 09, 2017 2:40 pm Post subject: Re: What did YOU do to your van today? |
Washed it after probably 3 months, and went to take a picture with the new wheels:
_________________ [img]http://driiive.com/ub/6232/img[/img] |
Posted: Fri Jun 09, 2017 3:42 pm Post subject: Re: What did YOU do to your van today? |
MyName wrote: |
Washed it after probably 3 months... |
Me, too! And scrubbed the roof in preparation for another application of Penetrol this weekend. _________________ '87 Westy in Wolfram Grey Metallic |
Posted: Fri Jun 09, 2017 5:03 pm Post subject: Re: What did YOU do to your van today? |
Yeah but MyName is handing out free candy.
Says so right there on the side of his rig. _________________ Peace, Regis |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Sat Jun 10, 2017 12:44 am Post subject: Re: What did YOU do to your van today? |
MyName wrote: |
Looks Great! _________________ This free advice is worth exactly what you paid for it.
BCE56 Samba Member
Posted: Sat Jun 10, 2017 6:57 pm Post subject: Re: What did YOU do to your van today? |
Passed smog yesterday, without going to a *special* smog station. Whew.
Replaced a burnt-out tail light, type 67. Oddly this was at the inboard socket, which on closer examination is marked 32 W. I previously thought the inboard sockets were Euro only, for inclement weather, and disabled on USA Vans. The outboard socket is marked 8 W.
(Housing is stamped USA.)
Live and learn.
At any rate, I could not find a high watt #67 at FLAPS. So, whatever...
Interestingly, all bulbs were marked Hella Germany and wattage matched stamps on the housing (except the inboard taillights) and wattage corresponded to USA hi watt incandescents. This includes front TS bulbs.
I suspect the bulbs are all factory original.
Also tried some inexpensive ($5.00 ea) brake and reverse LEDs. There was no significant improvement over the incandescent bulbs. Possibly dedicated LEDs might work better, but at $15.00 ea I'm not convinced they would be cost efficient. And now I have plenty of spares... _________________ =BCE56=
'86 Syncro tintop
EJ22, OBD II early SC adapter plate conversion
Side project: '69 Frankenbug "It's alive!"
