Paulbeard Samba Member
Posted: Sun Nov 05, 2017 9:18 am Post subject: Re: What did YOU do to your van today? |
Nice interior. I wish I had given more thought to the color…I like the look you went with. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Spey Caster Samba Member
Joined: October 27, 2017 Posts: 36 Location: Vancouver
James Mayfly Samba Member
Joined: November 10, 2017 Posts: 6 Location: Colorado
Posted: Thu Nov 16, 2017 3:02 pm Post subject: Re: What did YOU do to your van today? |
I installed a new temp sensor on my 81 Vanagon - hoping it would cure my bucking. I've changed all the spark plugs, rotor, distributor cap, temperature sensor, coil and the fuel filter. And now after driving around for a bit the van runs like a dream but after about 5 minutes of idle it will start to buck, but won't die on me. Any thoughts on the potential cause of the bucking? I'm new to the Samba, so if any one could direct me to a forum that would help me out that would be radical. Thanks!! |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4349 Location: United States, Iowa
Posted: Thu Nov 16, 2017 3:17 pm Post subject: Re: What did YOU do to your van today? |
James Mayfly wrote: |
James,
You have the air cooled version, I believe. Although you are in a Vanagon, the engine actually has much more in common with the late Bay's. You could try asking on that forum as well.
Good luck!
-bobby _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
WestfaliaMike Samba Member
Posted: Thu Nov 16, 2017 8:33 pm Post subject: Re: What did YOU do to your van today? |
Fixed my "no charge light".. (Hooked up a long lost blue wire) lol |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1645 Location: Budapest Hungary, Europe
Posted: Fri Nov 17, 2017 1:10 am Post subject: Re: What did YOU do to your van today? |
Hi!
Is that the narrow or the wide sliding window vent you have?
I am planning to buy but cannot decide from these photos which is good for me:
http://tk-carparts.de/vw-bus-t3-aufbauteile-frischluftgitter _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Fri Nov 17, 2017 1:26 am Post subject: Re: What did YOU do to your van today? |
Those vents were bought from Günzl Classic Parts.
Here are the links for LEFT and RIGHT.
Seeing as you are an EU resident as well, I would HIGHLY recommend you look here for your parts first.
It has been my experience that anything purchased from Günzl will breeze through your State Sponsored Inspection Process. _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
ZsZ Samba Member
Posted: Sat Nov 18, 2017 3:00 am Post subject: Re: What did YOU do to your van today? |
Team WorldTour wrote: |
It has been my experience that anything purchased from Günzl will breeze through your State Sponsored Inspection Process. |
Thanks for the info. I like the shop of Thomas Koch as their shipping prices are lower than other shops so usually cheaper to buy the same thing from them. If you are sure that the two items are the same so some research is usually needed
Altough there are some special things that Gunzl has only, so maybe I'll order from them anyway. _________________ Zoltan
Rich_T Samba Member
Joined: May 25, 2015 Posts: 32 Location: Fort Collins, CO
Posted: Sat Nov 18, 2017 8:19 pm Post subject: Re: What did YOU do to your van today? |
Finished the CV joint replacement today! Only one to the four joints was frozen on the axle - it was the last joint of course, as I thought to myself just before, wow this is going great... Had to find a bigger hammer.
Lobros CVs w Rockford boots.
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat Nov 18, 2017 9:14 pm Post subject: Re: What did YOU do to your van today? |
Looks G D!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
teej Samba Member
Joined: November 26, 2010 Posts: 897 Location: Seattle
Posted: Thu Nov 23, 2017 11:23 am Post subject: Re: What did YOU do to your van today? |
On a last minute run to the grocery store for some thanksgiving ingredients, I noticed we had no reverse lights as I left the house. After getting back, there were still 30 minutes before we had to leave, so:
Did a quick search on the samba, read several threads, enough to understand the circuit. Got under the van to make sure the two male spades were secure on the switch--removed and re-attached both.
Bingo! Lights!
The Samba rocks. _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Thu Nov 23, 2017 3:58 pm Post subject: Re: What did YOU do to your van today? |
Yesterday I added a quick connect battery terminal behind the driver seat. I cut the alligator clips off my MV-50 tire pump that I keep in the van. It will save the trouble of opening the battery box to attach the alligator clips each time. I also cut one end off some spare battery cables if I need to jump start someone. I can also use them to connect an extra deep cycle battery for longer trips.
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Thu Nov 23, 2017 8:14 pm Post subject: Re: What did YOU do to your van today? |
davevickery wrote: |
That's really smart, Dave. Now I want some, too!! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
Posted: Fri Nov 24, 2017 8:56 am Post subject: Re: What did YOU do to your van today? |
Thanks, yah I think I will like it. These are under $10 for a pack of 4 or 5 on ebay and they are universal and can only fit together one way.
Jamo7 Samba Member
Joined: September 25, 2014 Posts: 124 Location: Seattle
Posted: Fri Nov 24, 2017 9:10 pm Post subject: Re: What did YOU do to your van today? |
Quote: |
Lobros CVs w Rockford boots. |
Rich_T- you may have already read this, but quite a few Samanistas were getting water in between the stiff Rockford boot and the axle when they didn’t use the clips. I wanted to preserve my fresh, precious CV grease, so I quickly put on the clips after this was brought to my attention.
May you have many trouble-free miles on yours!
James _________________ '84 Westy 2.1 wbx |
Posted: Sat Nov 25, 2017 9:51 am Post subject: Re: What did YOU do to your van today? |
I had an ambitious day planned, and got half of it done.
New (manual) steering rack, inner- outer tie rod ends, and on driver's front; upper- and lower ball joints, and new CV boots (inner and outer), plus a wheel alignment.
Lets see how tomorrow goes.... _________________ 1990 Feldjäger Syncro AAZ
Click to view image
UngaWunga Samba Member
Posted: Sun Nov 26, 2017 12:24 pm Post subject: Re: What did YOU do to your van today? |
What brand are those? Thanks. |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3796 Location: VA/TN
Posted: Sun Nov 26, 2017 2:03 pm Post subject: Re: What did YOU do to your van today? |
well not today, but this weekend I continued to upgrade brake lines to Burley's Stainless. I upgraded a couple of lines where I thought was needed. I wanted to replace ALL lines but it looked like a hell of a job.
I also replaced the Clutch Slave Cylinder. . It was pretty easy to do! I took the time to also upgrade to Burley's stainless for that too. I feel good about replacing it next time (or if on the road). I had one bad spring coil in the rear so I replaced both rear springs with some used ones for $30. This should buy me time before I put the lift springs from GoWesty. _________________ Brandon
Instagram @joannthevan |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32592 Location: Reading Pennsylvania
82westyrabbit Samba Member
Posted: Sun Nov 26, 2017 3:51 pm Post subject: Re: What did YOU do to your van today? |
Changing all the brake lines is not that if you have the right tools I did mine about a year ago |
