fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Sun Nov 26, 2017 4:46 pm Post subject: Re: What did YOU do to your van today? |
Spent yesterday and today prepping the rear cabinet for sliding doors. An excellent excuse to get a new Ryobi jig-saw. It seemed the only way to remove the cabinet was to take down the A/C evaporator - and after the kerfuffle I had getting the A/C working that was NOT going to happen - so the cutting was done in situ. At least the cabinet moved enough so the 32 year old curtain behind could be removed and washed for the first time.
I installed shelves, with the bottom one on hinges so large items could be stowed below - the hinges were re-purposed from the rear cabinet door.
I'm just waiting for the plastic channels to be delivered before finally measuring the required finish height for the doors themselves.
_________________ Jim Crowther
Vespa GTS 300 |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Sun Nov 26, 2017 6:15 pm Post subject: Re: What did YOU do to your van today? |
UngaWunga wrote: |
What brand are those? Thanks. |
There's tons of quick connect plugs on ebay. I think there are generic made in china parts. I bought from a California seller though as I got stung once on a Hong Kong order for something else. https://www.ebay.com/itm/4x-Battery-Quick-Connect-...2134078260 I looked for ones that specify up to 6 gauge wire because some of them are for 2 or 4 gauge wire which is much too big for what I needed. |
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Sun Nov 26, 2017 6:29 pm Post subject: Re: What did YOU do to your van today? |
fxr wrote: |
Spent yesterday and today prepping the rear cabinet for sliding doors. An excellent excuse to get a new Ryobi jig-saw. ;) It seemed the only way to remove the cabinet was to take down the A/C evaporator - and after the kerfuffle I had getting the A/C working that was NOT going to happen - so the cutting was done in situ. At least the cabinet moved enough so the 32 year old curtain behind could be removed and washed for the first time.
Way to go on the door mod. While it's at this point you might want to rethink the height of the door opening and take it down a couple more inches. If I ever take mine out again I plan to make the bottom of the opening flush with the top of the mattress to provide better access to the very bottom of the closet. Look closely at the space you have in that opening right now and think about what you'll keep in the bottom of the closet. Big boots? Heavy coat wadded up? Laptop in a satchel? Try to fit that item through the space available right now and see if you don't want even better access. The hinged shelf is a great idea but depending on what you have stowed on that shelf it might be a hassle to move the stuff to lift the shelf and stow below it and then replace the stuff on the shelf. Think about how many times you're willing to do that. Just saying.
By the way, you would not have had to disconnect the evaporator, just unbolt it while leaving the hoses connected, then swing it out through the hatch opening and let it hang there so you could tilt the closet over to the right, then drag it out through the hatch opening.
_________________ '87 Westy in Wolfram Grey Metallic |
fxr Samba Member
Posted: Sun Nov 26, 2017 7:14 pm Post subject: Re: What did YOU do to your van today? |
Good point about lowering the opening, we considered it - but we have a 2" mattress topper that becomes 4" tall when folded over when the seat's up. If we didn't have that then the opening would definitely have been lowered. As it was, the rear door could only just be opened.
I hadn't spotted that the evaporator could be moved while still attached to the hoses - I'll remember that for the 'next time', thanks. _________________ Jim Crowther
Vespa GTS 300 |
westydriver Samba Member
Joined: July 08, 2017 Posts: 54 Location: Eastside of Nebraska
Posted: Tue Nov 28, 2017 6:47 pm Post subject: Re: What did YOU do to your van today? |
Maybe not today but over the last couple of days I have tossed some current to my old rusty tank and put in a new floor. Pretty impressed with this Coretec Plus flooring.
Brownj Samba Member
Joined: November 05, 2017 Posts: 33 Location: Southern Maine
Posted: Fri Dec 01, 2017 2:39 pm Post subject: Re: What did YOU do to your van today? |
Not quite as ambitious as you all but made & installed a cup holder. Its a start!
Also note the new and improved map light (added a micro switch and removed old sw.)
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Posted: Fri Dec 01, 2017 4:15 pm Post subject: Re: What did YOU do to your van today? |
westydriver wrote: |
Nice job on the tank! |
Posted: Fri Dec 01, 2017 4:16 pm Post subject: Re: What did YOU do to your van today? |
fxr wrote: |
Sweet what are your plans for a door? |
fxr Samba Member
Posted: Sat Dec 02, 2017 3:28 pm Post subject: Re: What did YOU do to your van today? |
Pictures of the doors below. Made from 1/4" project board from Home Depot - annoyingly the height of the original cabinet is 24.75", so two 24"x48" boards are needed. The tan tracks are disappointingly far from the right colour - but they'll do for now! Painted with Krylon Almond Satin rattle-can, one can does both doors nicely.
Vespa GTS 300 |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat Dec 02, 2017 3:34 pm Post subject: Re: What did YOU do to your van today? |
^^^ I've always loved that mod, but it's so far down my list I've never gotten anywhere near it...
Very nice job!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
fxr Samba Member
Posted: Sat Dec 02, 2017 3:39 pm Post subject: Re: What did YOU do to your van today? |
dhaavers wrote: |
Very nice job!
I thank you! Mrs fxr reckons it's her favourite mod so far to the van - that 'closet' was a PITA to get to.
I absolutely have to thank those who've done the mod before for leading the way - and whoever it was who spotted that Krylon Almond Satin was *the* very close match to the cabinet smooth surface colour. _________________ Jim Crowther
Vespa GTS 300 |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Sun Dec 03, 2017 1:36 pm Post subject: Re: What did YOU do to your van today? |
Well.. Three up, and one down. Progress now that the elevator is fixed
_________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Team WorldTour Samba Member
Joined: September 02, 2010 Posts: 2426 Location: Der Vaterland
Posted: Wed Dec 06, 2017 2:37 am Post subject: Re: What did YOU do to your van today? |
So, last week I finished the front end.
Yesterday, I did the read axle boots. I should have just got new CV's as well. These things are TOASTED!
Next axle end:
This was pretty much a recurring theme. Maybe Santa has some new parts for me..... _________________ 1990 Feldjäger Syncro AAZ
Click to view image
H6 Subaru Engine Swap Thread
WV2ZZZ25ZFH094138(x)/ WV2YB0257LH057308(x)/ WV2ZZZ25ZLG113270/
"Where am I going? And what am I doing in this handbasket?" -Nicodemus Jordan
When All Else Fails: Lather, Rinse, Repeat! |
Posted: Wed Dec 06, 2017 1:34 pm Post subject: Re: What did YOU do to your van today? |
New hatch struts! Thanks for the part numbers sambanistas! |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Wed Dec 06, 2017 5:35 pm Post subject: Re: What did YOU do to your van today? |
Which kind did you pick out? Was it an easy job? _________________ Brandon
Instagram @joannthevan |
Posted: Wed Dec 06, 2017 5:44 pm Post subject: Re: What did YOU do to your van today? |
Team WorldTour wrote: |
These things are TOASTED! |
Nah...I've seen worse...
"The WonderVan"
Posted: Wed Dec 06, 2017 6:35 pm Post subject: Re: What did YOU do to your van today? |
shagginwagon83 wrote: |
Which kind did you pick out? Was it an easy job? |
Purchased the Stabilus Struts from ORileys. Part #SG301001. Took one minute at the most on each side. Super Easy. $42 in total. |
Posted: Wed Dec 06, 2017 9:50 pm Post subject: Re: What did YOU do to your van today? |
Cool. Mine are about to go. When they do I know where to go! _________________ Brandon
Posted: Thu Dec 07, 2017 10:26 pm Post subject: Re: What did YOU do to your van today? |
I finished a complete replacement of my heat exchangers/exhaust manifold and muffler system on my 82 air cooler beauty. Went with the Dansk aftermarket exchangers. Also installed a new thermostat from Awesome Powdercoat. Also fabricated and installed new muffler support hangers.
All done in garage without dropping the engine....it can be done! Kick ass man, I'm happy. Nothing beats you're own work....when it all works! |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Fri Dec 08, 2017 8:13 am Post subject: Re: What did YOU do to your van today? |
Truth! Congrats! _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
