regis101 Samba Member
Joined: July 28, 2005 Posts: 2078 Location: Livermore, Ca
Posted: Sun Mar 04, 2018 5:22 pm Post subject: Re: What did YOU do to your van today? |
Not silly at all. More like, that's awesome!! _________________ Peace, Regis |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Mar 04, 2018 5:32 pm Post subject: Re: What did YOU do to your van today? |
x2... That's what fun looks like!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
WestfaliaMike Samba Member
Posted: Mon Mar 05, 2018 5:39 pm Post subject: Re: What did YOU do to your van today? |
dhaavers wrote: |
- Dave |
Thanks Dave _________________ 1981 Vanagon Westfalia
1983 Vanagon Passanger (Parts Vehicle)
2016 Passat TSI |
downshifting1984 Samba Member
Joined: September 28, 2017 Posts: 11 Location: Montréal QC
Posted: Tue Mar 06, 2018 2:36 pm Post subject: Re: What did YOU do to your van today? |
Pulled the dash, removed and cleaned heater box (2 bolts gave me a really hard time), sorted PO’s wild wiring, installed an aux battery. Can’t imagine paying someone to do that work!
Nicolas
Buss Marius Samba Member
Joined: February 29, 2012 Posts: 98 Location: Oslo, Norway
Posted: Thu Mar 08, 2018 1:23 pm Post subject: Re: What did YOU do to your van today? |
I putt my syncro back on its 4 wheels, for the first time in 51 months. I took the front left Wheel off in December 13 and today i was finaly finished changing the buschings to Powerflex, The only thing not finished is 1 inner Cv boot and i need a ned a ned ARB drop link and put the powerflex bushings on the ARB. I have also changed brake hoses, 4 brake lines (2 i bought, 2 i made) splash plates, Cv booth protection, ball joints on the left side and donne a lot of rust removing from the parts i have worked on.
Tomorow i start working on the rear axle, the engine and start instaling the decoupler. I also have to instasl the Reimo interior and then i can take it to inspection.
Working in a non-heated garage i look forward to the temperature going abow freezing, for the first time since before christmas, next week, if the weather forcast is correct. _________________ 87 75hp VW LT 28 Karmann LT L, 90 T3 Syncro 75hp AAZ Reimo Camper. 00 T4 102hp TDI Caravelle bus. |
Zeitgeist 13 Samba Member
Posted: Mon Mar 12, 2018 11:06 am Post subject: Re: What did YOU do to your van today? |
I finally completed my engine install after finishing the custom intake manifold. But of course the starter shit the bed, so I haven't started it yet. I have a TDI starter adapter coming later this week. This project took way way longer than anticipated, but then again I became distracted by the acquisition of our much loved EV.
_________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Mon Mar 12, 2018 12:48 pm Post subject: Re: What did YOU do to your van today? |
Finished the '86 automatic's RnR CVs after finding my lost GW package with the c clips. So, at least the axles are ready. Also, finally got the main pulley free'd from the EJ22, so the t-belt/water pump kit goes in next. Closing in on the end-goal. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
pbrown Samba Member
Joined: July 15, 2008 Posts: 443 Location: Seattle, WA
Posted: Mon Mar 12, 2018 1:23 pm Post subject: Re: What did YOU do to your van today? |
I installed Dynamat to my roof. I'll be installing 1/2" Dynaliner over this and then installing a new headliner board.
_________________ Patrick Brown
1986 Westy Syncro EJ25
Flickr --> https://flic.kr/s/aHsmQNUXEF |
randolph57 Samba Member
Joined: January 03, 2014 Posts: 36 Location: plymouth,uk
Posted: Fri Mar 16, 2018 5:10 am Post subject: Re: What did YOU do to your van today? |
Finished fitting the dash after heater/blower replacement ,PWM upgrade,New bug screen/mesh in roof canvas and black case Fiamma F45s awning.
Ready for whenever it stops snowing/raining/blowing!
Posted: Fri Mar 16, 2018 6:30 am Post subject: Re: What did YOU do to your van today? |
Randolf57, wow, that is really nice! Good work! _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
WestyWanter Samba Member
Joined: February 15, 2017 Posts: 459 Location: San Diego
Posted: Fri Mar 16, 2018 7:47 am Post subject: Re: What did YOU do to your van today? |
I dig the color randolph! |
elizer Samba Member
Joined: May 02, 2016 Posts: 1466 Location: Northern Virginia
Posted: Mon Mar 19, 2018 10:28 am Post subject: Re: What did YOU do to your van today? |
I got the rear end jacked up to finally address the rear axle that fell off back in January. Got all my tools lined up that I would need, my new axle ready, and crawled under. The axle bolts were hex heads and I had 12 points. After failing to find my hex bits I packed everything, lowered the van, and cursed the world.
Yesterday was the nicest day so far to be able to work on the van and now I will be out of town for the next 2 weeks. Sigh. |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Mon Mar 19, 2018 8:12 pm Post subject: Re: What did YOU do to your van today? |
Zeitgeist 13 wrote: |
Hey Casey. Are those small tubes a methanol system? Doooooo tell?! Inquiring minds want to know. Thanks _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
Posted: Mon Mar 19, 2018 8:40 pm Post subject: Re: What did YOU do to your van today? |
I got my new voltage regulator today, pulled the alternator out and it didn't fit... sigh |
Posted: Tue Mar 20, 2018 6:59 am Post subject: Re: What did YOU do to your van today? |
rmcd wrote: |
Hey Casey. Are those small tubes a methanol system? Doooooo tell?! Inquiring minds want to know. Thanks |
Do you mean the green and yellow lines? Those are the boost signal lines for the LDA, wastegate actuator and boost gauge. Now I'm kicking myself for not welding in another bung, since I have a complete water/methanol injection system...I also have a complete propane injection system, but that's probably not the foolish endeavor I'm looking for.
I fired it up yesterday, after many many rotations on a borrowed TDI starter. I was only able to get the pump to prime by stuffing the inlet hose into a container of ATF. I suspect my MB fuel filter setup may not be drawing well, as those engines use a small lift pump to push fuel into the filter, while the VW pumps have internal suction pumps--at least that's my theory. Since I still have the original ALH filter I'll mount that up today. I'm also building the A/C lines and mounting up the cruise actuator.
Oh, and welding up my rear shock extensions...and finishing wiring up all the VDO gauges...and... _________________ Casey--
y u rune klassik? |
wesitarz Samba Member
Joined: August 20, 2012 Posts: 1491 Location: Victoria,B.C.Canada
Posted: Tue Mar 20, 2018 3:00 pm Post subject: Re: What did YOU do to your van today? |
Finished installing front door remote door locks from set of 4 from EBay. About $30 CAN delivered. Since I already had electric door locks, just had to drill 2 new holes for the actuator and the controller fits behind the glovebox with easy access to battery 12v,ground and tap into all the door lock wiring. They work really well,faster and more positive than the old VW door locks. Next have to see if I can swap in new actuators in the sliding door and hatch or I may just leave them manual especially the hatch.
12Paths Samba Member
Posted: Fri Mar 23, 2018 7:59 pm Post subject: Re: What did YOU do to your van today? |
(Not my van)Bad photoshop job I did...you’re welcome
Just ordered all the parts for my Subaru swap and front and rear suspension! Hopefully it won’t take me a year to complete lol |
Posted: Sun Mar 25, 2018 3:44 pm Post subject: Re: What did YOU do to your van today? |
Spring work season begins!
With temps forecast above 40 degrees (finally! ) I turned on the garage heater & started by installing
my new <cheap> ARB-knockoff awning. Many more projects to come...Happy first week of Spring!
"The WonderVan"
Paulbeard Samba Member
Posted: Sun Mar 25, 2018 4:25 pm Post subject: Re: What did YOU do to your van today? |
R&R'ed my rear bench, a long overdue project. Tons of cruft and crud and debris back under there on the sides. Not a difficult job but made more complex by the fact the ECU and fuel pump relay are mounted to one wall and I have a battery combiner and solar charge controller mounted on another, plus the house battery. So I just shifted it as far as I could without removing everything, drove over to the car wash to use their vacuums, and then put it all back together. Lost one lock nut under the whole mess at the very end
Pro-tip: the Bentley cautions that the circuit breaker can be damaged when you pull the bench out. I removed the cover plate, unscrewed the breaker, and shoved it back into the hole so it was out of the way.
I really need to pull the other cabinets and this was a trial run for that. I have seen estimates of 2-3 hours to pull the cabinets. Looks more like 2-3 days for me…
Interesting how much louder the motor/transaxle are with the seat moved. The trans does whine in every gear…
Also, the sun was strong enough today to allow the combiner to work its magic and charge both batteries with the 50W panel. Wasn't expecting that this early. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers
Chestercopperpot Samba Member
Posted: Sun Mar 25, 2018 4:41 pm Post subject: Re: What did YOU do to your van today? |
Finished sealing my new center console.
Have some space inside for a small non sine inverter? Not sure.
May do some usbs out the rear. Ordered an led for some cupholder illumination but it's on the slow boat.
Hope to see my vinyl e brake cover by next weekend.
So nice to have cupholders! |
