emccann86 Samba Member
Joined: May 24, 2018 Posts: 7 Location: San Diego, CA
Posted: Thu May 24, 2018 9:06 pm Post subject: Re: What did YOU do to your van today? |
Got new rear view in the mail and popped it in, then started this nightmare
https://www.thesamba.com/vw/forum/viewtopic.php?t=700142
Cleaned up Some of this shoddy wires and re-insulated some others.
Oh and I bent my new stove wrench trying to pull the tops off to inspect and clean them .......yup |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4348 Location: United States, Iowa
Posted: Fri May 25, 2018 7:11 am Post subject: Re: What did YOU do to your van today? |
Today I asked my twins of 16 which vehicle to drive them to school and me to work. Flossie! Flossie! Ok so that makes it 2 weeks of every school day taking the Westy. I won't have the luxury of a nap-instead-of-lunch today tho, as the temp and humidity are going to conspire against that. Should be somewhere around 85F and 98%H, so that's out today, I guess. Makes me wish for solar panels and a super small footprint window A/C! _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
82westyrabbit Samba Member
Posted: Fri May 25, 2018 6:22 pm Post subject: Re: What did YOU do to your van today? |
A new set of shoes!
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7754 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri May 25, 2018 7:23 pm Post subject: Re: What did YOU do to your van today? |
Utah trip prep:
New AT tires (General Grabbers, 27x8.50R14) & alignment, new gear oil (after break in miles on "new"
rebuild last fall), brake fluid flush & snugged belts since I had extra 10 minutes before beer-thirty...
(Sorry for crappy phone pic...and obviously untreated seam rust... )
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
campism Samba Member
Joined: September 07, 2007 Posts: 4491 Location: Richmond VA
Posted: Sat May 26, 2018 4:16 pm Post subject: Re: What did YOU do to your van today? |
Yep, that photo is a gear oil job, for sure.
I got to work on the Westy's sink drain that we discovered leaking last year. Turns out the drain tubing was torn and getting it loose did more damage so the remaining piece is not long enough to reach from drain to floor, so I need more of that tubing or a substitute.
The drain itself also needed work. Took a lot of muscle to get it apart and out of the sink, and it seems that the drain spout portion is cracked and the little fixing screw was nearly rusted through. I found another screw that works and repaired the crack, so once I get new drain tubing I'll put it all back together and we'll be ready for a trip. And I'll make sure there's enough lube on everything that it can come apart again more easily next time.
Still need to reseal the tank.
_________________ '87 Westy in Wolfram Grey Metallic |
Posted: Sat May 26, 2018 9:10 pm Post subject: Re: What did YOU do to your van today? |
Got up early enough to catch the morning shade on the west side of the house and used a few quarts of "Green" degreaser and rags on the engine. It was a mediocre success. Took my boy to Solo ASWS, and I thought it was about 6.5/10, he gave it a 7. $22 and 2 hours and 15 minutes run time was about enough to allow the engine to dry out completely, then I took the rare moment that my shop bay was open (kids subi-swap in progress has been taking up the bay!) and decided that the 2 year limit had been reached on my coolant, so I pulled the drains, raised the nose and let it drool into a 5 gal bucket. changed the oil too.
Coolant fill is a work in progress: I opened both heater valves, filled coolant, put it up on my "bleeding hill" (nose is about 30% down) and filled coolant, while letting bubbles out of radiator. Noticed coolant I spilled was in the level sensor recess on the expansion tank, but didn't wipe that up yet... Probably the reason the sensor level is blinking on the dash, as the tank is full. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3091 Location: ABQ NM USA.... Except when not
Posted: Sun May 27, 2018 8:12 am Post subject: Re: What did YOU do to your van today? |
Replaced my brake light switches on the master cylinder to stop the brtake light flickering when I pressed the brake pedal - per this good post that made it very easy with tilting the dash out of the way - https://www.thesamba.com/vw/forum/viewtopic.php?p=8773883#8773883
Caution that the dash tilting can cause the main harness to partially disconnect which in my case caused a alternator to stop charging and the alt lingt not to work. I discovered the partially-disconnected harness after an unnecessary alternator replacement . (it was n Autozone Lifetime warranty so no impact on my pocket book) AND as a part of this I did also got to discover that my main and aux batteries both had a dead cell and it was month 41 of the Costco 42 month full replacement _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
DehlerPEB Samba Member
Joined: January 13, 2010 Posts: 111 Location: Germany, Augsburg
Posted: Sun May 27, 2018 8:25 am Post subject: Re: What did YOU do to your van today? |
- fixed right turn signal indicator („Blinker“); The flexible cap has come loose, water entered and so the connections corroded. Brushed of the rust, sprayed w/ WD40, resealed the cap: indicator working again.
- fixed speedometer. Left front axle cup that holds the speedometer-cable disengaged on the highway after switching to the summer tires. So the last 500km were „driving blind“ concerning speed. New cap installed, unfortunately the pin that holds the cable was slightly to large, so doesn’t lock properly. And as always, the proper was not at hand. So for the moment i installed the not so nice locking circlip and made certain with tape that I have some time to get the correct size.
- Worst and last: my right windshield-wiper was loose. Tried to fasten it, but the whole thing needs a new thread. And that is nothing I will tackle on a Sunday afternoon. So at the moment I am driving just with one whisper .... weatherforecast is 25C and no rain for the next days, so Monday is a call ...
S0, two things out of three solved. 66% achieving rate and no stress.
Seems to be a successful weekend
Peb |
babywindow Samba Member
Posted: Sun May 27, 2018 2:31 pm Post subject: Re: What did YOU do to your van today? |
Dropped my fuel tank. Surprised to find there was about 5 gallons left in it, after draining at the outlet. The outlet looks to drain from the center of the tank, inside a screen...so I won't be coating the tank.
When I fill the tank ( with water now), with the tank level, it doesn't start to flow out the outlet until there's about 5 gallons in , but then it drains down to about 2 gallons (like a siphon effect?)
Anyone else have an experience like this?
Do I need a new tank? |
Posted: Sun May 27, 2018 6:49 pm Post subject: Re: What did YOU do to your van today? |
I replaced my fuel tank when I had similar symptoms. The tank was full of rust. They are available and no that expensive. A pian in the but to install. |
lowbody Samba Member
Joined: December 10, 2017 Posts: 4 Location: Chesapeake VA
Posted: Sun May 27, 2018 7:17 pm Post subject: Re: What did YOU do to your van today? |
Drove mine for the first time. Finally got to take a picture of it not in my driveway.
Posted: Sun May 27, 2018 9:30 pm Post subject: Re: What did YOU do to your van today? |
Had chipped some bondo off last fall, and worked the dents out a bit with a hammer and dolly, and then covered it back up with the Bra. Today I took the Bra off, I think for the last time, as all the Bra's I've ever used just snadpapered down the paint under them from the grime that gets underneath. Its definitely not a good job, but compared to how the PO left it, I'd say it is an improvement. I really hadn't intended to get it to look all that good, as there is very little way to actually fix the metal, so instead of putting a bunch of mud back on, I got it 'better' and put on some lipstick. Perhaps there will be a future where everything is all straight again, and a whole paint job gets done, but for now, this little improvement is one that I can live with.
Cobra88 Samba Member
Joined: May 28, 2018 Posts: 82 Location: Ipswich, Suffolk, UK
Posted: Mon May 28, 2018 10:08 am Post subject: Re: What did YOU do to your van today? |
Took mine for a spin to Bentwaters Airbase here in UK
I'm new to this forum after years lurking.
84 Caravelle GL Auto Tintop with Full steel sunroof.
Spent 2 days getting roof unfrozen and back in use after PO sealed it up with silicone in 1998!
Regards
Rick
Posted: Mon May 28, 2018 10:19 am Post subject: Re: What did YOU do to your van today? |
^^^ Beauty! Was the wood side treatment original or added later? Very retro!
For my part, yesterday I replaced the old dry-rotted screen material with fiberglass
screening for the back hatch. Also added 6" fabric "tail" at the bottom to tuck under
the cushion, hopefully to provide one more barrier between us & the black flies...
"The WonderVan"
Posted: Mon May 28, 2018 10:22 am Post subject: Re: What did YOU do to your van today? |
Hi Dave
Woody Vinyl was added by Previous owner
I removed a lot of it from front & rear panels but quite like the Station Wagon look
I will have to remove it at some point as it was fitted over the Caravelle stripes and logos
Regards
Rick _________________ 84 (85) model year Caravelle GL 1.9 DG Auto WBX Bronze Beige Metallic w Steel Sunroof |
Paulbeard Samba Member
Posted: Mon May 28, 2018 12:44 pm Post subject: Re: What did YOU do to your van today? |
Drained and filled the engine oil, replaced the filter, found a very frayed O2 sensor wire from the upstream (non-cat) sensor, stripped/crimped/taped to fix. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4083 Location: East Kootenay, British Columbia
Posted: Mon May 28, 2018 6:22 pm Post subject: Re: What did YOU do to your van today? |
Installed the Westylounge bits from Boxeer. https://www.boxeer.com
As I suspected my original parts were getting kinda beat up.
Would be nice if Boxeer supplied new springs for the price!
Managed to straighten out the spring well enough to reuse, but as soon as I get a chance I'll be buying a new one.
The install video shows him installing the bits with the bed in the van, but we took ours out to keep from spreading grinding grit inside. Found some stickers that had wandered while the seat was out.
Works as advertised. Also makes folding the bed/seat easier . _________________ Currently:
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
Posted: Fri Jun 01, 2018 6:37 am Post subject: Re: What did YOU do to your van today? |
As it ended at 12:01 today when we finally called it quits for the night: got the EJ22 under the Cosmo/Bluebird of Happiness, and lifted it up. Got the long stud into the starter, and briefly had the other three in their holes, but the starter stud was hanging halfway into the hole. Buggared around for a long time trying to mate that engine to transaxle! Me plus two kids were sweat soaked by the end. Perhaps we will sort it later today.
Mod'd governor.
Half shafts greased and installed.
Destroyed the overflow tank.
Grease and ATF in my hair.
But, Hi-5's all around to have gotten at least as far as we did. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
elizer Samba Member
Joined: May 02, 2016 Posts: 1461 Location: Northern Virginia
Posted: Fri Jun 01, 2018 9:06 am Post subject: Re: What did YOU do to your van today? |
I wish I had children. Not for the fulfillment of raising them and watching them grow, but for the extra hands when I work on stuff. But nice job. That first startup will be awesome. |
