elizer Samba Member
Joined: May 02, 2016 Posts: 1461 Location: Northern Virginia
Posted: Tue Jun 05, 2018 2:09 pm Post subject: Re: What did YOU do to your van today? |
Went to single round headlights. They are jw speaker dual burn evo 2. I still have to aim them tonight against a store wall. I am pretty pleased. I actually bought the SA grill kit from VC but decided to go with singles. I also got JW speaker round fogs as well that I will put in later. I HATE those grill clips. The install got delayed a few days because I broke some in the process of the install. Also they get hung up sometimes when I try to remove it.
I also put on some trim shine on the lower grill and so I wouldn't have to paint for a little while.
The gowesty bracket is pretty sturdy. But I reached the farthest left limit on the right headlight. So you see a lot more of the bracket than on the driver side. I have a set of early headlight brackets that I may try out later. I also had to hit the mounting tabs with some black spray paint on a q tip because they are highly visible. |
syncrogreg Samba Member
Joined: November 08, 2009 Posts: 742 Location: USA (Nashville TN)
elizer Samba Member
Posted: Thu Jun 07, 2018 7:34 am Post subject: Re: What did YOU do to your van today? |
I was planning on doing the Westy Lounge kit install yesterday but my Dremel disappeared. I have to find it.
I ended up doing the jack bombay pop top assist install and my yakima ARGs.
Ideally, I would have liked the strut to have been attached to the rear bottom bolt of the ARG. Drilling holes in the pop top and measuring 300 times was the most nerve-racking part. I had to also clearance the yakima hole a bit to accept the jack bombay ball end bolt. A long sleeve shirt would have come in handy for all the little fiberglass particles sticking into my skin but it was way too hot outside.
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4086 Location: East Kootenay, British Columbia
Posted: Thu Jun 07, 2018 7:55 am Post subject: Re: What did YOU do to your van today? |
syncrogreg wrote: |
Well that was fun!
Greg |
It would be nice if the kits you sold included the springs. _________________ Currently:
elizer Samba Member
Posted: Thu Jun 07, 2018 7:56 am Post subject: Re: What did YOU do to your van today? |
Ordered my kit a week or two ago and it came with new springs. |
Posted: Thu Jun 07, 2018 9:28 pm Post subject: Re: What did YOU do to your van today? |
elizer wrote: |
I ordered my kit about three weeks ago. Rats.
And since the photo on his site doesn't show the springs in the kit I never bothered to contact him. _________________ Currently:
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4348 Location: United States, Iowa
Posted: Fri Jun 08, 2018 12:08 pm Post subject: Re: What did YOU do to your van today? |
Flossie parked when it was dry. 3 inches of rain overnight. Daughter #1 gets to remember the hard way about VW's classic Boffins Idea #1:
1 wheel drive.
Daddy to the rescue with a log chain and a Toyota AWD SUV....
Sheesh... I've got to add a 2nd wheel drive soon... After all, a bit more piece of mind would be worth a rebuilt 091 with a TBD, only like $3 or $4K, I think... PowerBall again tomorrow, I guess.
Prologue: home, rinsed, swept out, and drying off. Loaded up to deliver show to a museum show in the AM
_________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch
elizer Samba Member
Posted: Fri Jun 08, 2018 7:08 pm Post subject: Re: What did YOU do to your van today? |
lost the interior handle trim screw replacing power lock actuator and getting ready to replace a broken wire. 30 cents at VC ... I wonder if they would send me a cookie just for that? Either way now I feel compelled to buy something else... time for some internet shopping I guess. |
campism Samba Member
Joined: September 07, 2007 Posts: 4491 Location: Richmond VA
Posted: Fri Jun 08, 2018 8:13 pm Post subject: Re: What did YOU do to your van today? |
Gave it a bath now that pollen season is over and the benefits of washing will be apparent for more than two days. Discovered while scrubbing a headlight that one of the adjusters is broken so I'll use the old "fuel hose and E-clip" trick to fix it.
Here's an earlier fix on the other side.
_________________ '87 Westy in Wolfram Grey Metallic |
calo1956 Samba Member
Joined: April 18, 2011 Posts: 699 Location: long Island new york
Posted: Fri Jun 08, 2018 8:46 pm Post subject: Re: What did YOU do to your van today? |
Not so much what i did to it, more what i did with it, I took it to a local car show, popped the top, and enjoyed the show! _________________ Enjoy the ride....
72 bug
80 westfalia |
Deadvanwalking Samba Member
Joined: June 07, 2018 Posts: 3 Location: Columbia Gorge
Posted: Fri Jun 08, 2018 9:28 pm Post subject: Re: What did YOU do to your van today? |
[/img] |
elizer Samba Member
Posted: Sat Jun 09, 2018 9:15 pm Post subject: Re: What did YOU do to your van today? |
Yakima 66" bars and mount came in today.
If anyone was wondering its about 7" on each end sticking out from the mounts. Also, you should get a file and deburr the aluminum loops where the bars go through. The first one I put on the bar scratched up the nice new rubber.
The bars are a little high for my liking. The args were mounted where they were so I could share a bolt with the jack bombay struts. I will run them like this for a while I guess until I can get someone to fab me up some ARGs that are flipped upside down. The 1A mounts should still clear and not touch. Not too worried about getting the skylight vent up. If anyone can fab me up some upside down aluminum args I will pay.
jimf909 Samba Member
Posted: Sun Jun 10, 2018 5:45 am Post subject: Re: What did YOU do to your van today? |
^^^ Looking good!
Using the Yakima Sideloader ARG will drop the base of the tower to below the lower bolts, about 1 1/2” - 2”. Perhaps not as much as you hoped? The Sideloader also only mounts with two bolts. I used them for years carrying heavy loads so I don’t believe the four bolts of the Wideloader are needed for carrying capacity or to distribute the load. I think the Sideloader looks better too because there are no exposed carriage bolts.
https://www.rei.com/product/494243/yakima-side-loa...J4EALw_wcB
FWIW, YMMV. _________________ - Jim
Abscate wrote: |
elizer Samba Member
Posted: Sun Jun 10, 2018 6:10 am Post subject: Re: What did YOU do to your van today? |
Thanks! Alas I have committed with the 4 holes. I know a lot of people used the thule 2 bolt args as well and had no trouble. Using the jack Bombay kit I used the forward top bolt to keep it as low and back as possible. Going with the sidewinder kit would have saved me from making my own backing plates. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7754 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sun Jun 10, 2018 8:33 am Post subject: Re: What did YOU do to your van today? |
FINALLY added the missing spacer from my reverse light switch @ the tranny,
so now no more sporadic reverse lights in 1st, 2nd, 3rd, 4th gear...
Wash & wax, prep for road trip...see all y'all on the road!
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Sun Jun 10, 2018 10:03 pm Post subject: Re: What did YOU do to your van today? |
dhaavers wrote: |
- Dave |
How can you tell when you have sporadic reverse lights (SRL?)?
I’ve seen a van going 40 mph forward with reverse lights on and I didnt know it was a syndrome. Regardless, I wonder how you can tell if your van has it. _________________ - Jim
Abscate wrote: |
Zeitgeist 13 Samba Member
Posted: Sun Jun 10, 2018 10:31 pm Post subject: Re: What did YOU do to your van today? |
I finally got around to semi-permanently attaching a prop-rod for the decklid.
I think it's a rear hatch strut from an Audi, but I don't recall which one. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Mon Jun 11, 2018 5:53 am Post subject: Re: What did YOU do to your van today? |
jimf909 wrote: |
dhaavers wrote: |
- Dave |
I’ve seen a van going 40 mph forward with reverse lights on and I didnt know it was a syndrome. Regardless, I wonder how you can tell if your van has it. |
Driving at night & looking in my mirrors I noticed road signs reflecting back to me
after I passed them. I could turn my reverse lights on & off just by wiggling the
shifter around while driving forward in 4th (or actually any other) gear...
"The WonderVan"
Posted: Mon Jun 11, 2018 6:26 am Post subject: Re: What did YOU do to your van today? |
^^^ Thanks. Hmmm, SRL syndrome, one more thing to worry about.
Abscate wrote: |
Posted: Mon Jun 11, 2018 6:28 pm Post subject: Re: What did YOU do to your van today? |
...Mostly just if you return your core tranny without first removing the spacer to use on your "new" rebuild...
"The WonderVan"
