4mymalamute Samba Member
Posted: Sun Jan 06, 2019 1:02 pm Post subject: Re: What did YOU do to your van today? |
Fixed the cruiser control. Took the two sensors off each peddle, took them apart, cleaned them, checked diaphragm in back (easy...just sucked air out of it and it held) and ran a new hose from it to the pump. EASY and it works like a champ! |
Igeo Samba Member
Joined: September 25, 2018 Posts: 888 Location: Oakland, CA
Posted: Sun Jan 06, 2019 1:35 pm Post subject: Re: What did YOU do to your van today? |
Finished installing Schwenk springs and new Bilstein XHD shocks on my '87. The ball joints were tight, so I put them back into service. The rear springs are easy to swap. I used an internal spring compressor for the fronts. Made me nervous to compress the springs, but it all worked out. Big brakes go on the front next week after I clean up the backing plates.
_________________ 1987 Westfalia 2.1 WBX Manual |
jp52 Samba Member
Posted: Sun Jan 06, 2019 3:40 pm Post subject: Re: What did YOU do to your van today? |
Pulled the dash (again) to install heater and vent ducts, sort out weird stereo wiring from previous owner, fixed cigarette lighter power, etc all in anticipation of the new radio arriving Monday. Hooray for tunes!
Also swept all the mud out of the van from the last few mountain bike rides/dog.
Its making me consider a rubber floor mad rather than something fancier. |
cellerdoor Samba Member
Joined: July 10, 2012 Posts: 403 Location: Fairfax Virginia
Posted: Sun Jan 06, 2019 3:45 pm Post subject: Re: What did YOU do to your van today? |
removed the propane tank, refrigerator, utility boxes and kitchen cabinet to start my camper utility refresh. Still have to take out the bench seat and water tank cabinet.
Pondering many upgrades while the cabinets are out. _________________ 1986 Westy |
campism Samba Member
Joined: September 07, 2007 Posts: 4492 Location: Richmond VA
Posted: Sun Jan 06, 2019 8:07 pm Post subject: Re: What did YOU do to your van today? |
cellerdoor wrote: |
Pondering many upgrades while the cabinets are out. |
Slot the holes in the base of the sink cabinet so it will simply slide back into place and not have to be lifted over the propane lines or sink drain during reinstall.
Also, we replaced the hinged door of the closet with twin sliders. Much better access when the wayback is loaded or the bed is occupied.
And we converted the hanging space to more shelves.
We also removed the hinges from the lids of the two cubbies in the low cabinet so that we could access them when the rear table is stowed in the low position. Just lift a lid off to get to the contents. No lifting the table to get into the cubbies. _________________ '87 Westy in Wolfram Grey Metallic |
elizer Samba Member
Joined: May 02, 2016 Posts: 1466 Location: Northern Virginia
Posted: Sun Jan 06, 2019 8:26 pm Post subject: Re: What did YOU do to your van today? |
Love the sliding door mod. |
Posted: Sun Jan 06, 2019 8:30 pm Post subject: Re: What did YOU do to your van today? |
elizer wrote: |
Only thing I'd do differently would be to cut the opening lower, maybe flush with the top of the mattress. This would permit better access to the bottom area for bulky items like boots, big coats or computer bag. May still do that. _________________ '87 Westy in Wolfram Grey Metallic |
AndyBees Samba Member
Joined: January 31, 2008 Posts: 2331 Location: Southeast Kentucky
Posted: Tue Jan 08, 2019 4:48 pm Post subject: Re: What did YOU do to your van today? |
Removed all ground connections and cleaned them... engine starts much better (ALH 84 Vanagon). _________________ '84 Vanagon Tin-top, ALH TDI. 1989 Tin-top
1983 Air-cool, 225k miles, 180k miles mine. Seven trips to Alaska from 1986 thru 2003. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Jan 08, 2019 5:20 pm Post subject: Re: What did YOU do to your van today? |
FINALLY moved into winter storage...with a new $75 Walmart battery...trickle charger...waiting for spring...
"Sleep, my little one...my pretty one...sleep." - Tennyson
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3099 Location: ABQ NM USA.... Except when not
Posted: Fri Jan 11, 2019 2:45 pm Post subject: Re: What did YOU do to your van today? |
dhaavers wrote: |
FINALLY moved into winter storage... |
NO WAY!!!
get that $179 furnace going, keep it 90deg in the van and go SKIING!!!
(I actually got the $1,500 high-altitude Espar but would have gone $179 if available when I installed mine)
Finished creating the side ski rack.
Dedicated topic here https://www.thesamba.com/vw/forum/viewtopic.php?t=712654
_________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Fri Jan 11, 2019 3:27 pm Post subject: Re: What did YOU do to your van today? |
vanis13 wrote: |
dhaavers wrote: |
NO WAY!!! |
Sadly, yes.
Too much d@mn salt on the roads around here, and too much rust on the van already...
We'll continue maintaining the van for non-salty summer road trip fun...& continue to use our
more disposable AWD rig for ski trips...(skinny skiing)...
- Dave
PS: Nice rack! _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Paulbeard Samba Member
Posted: Sat Jan 12, 2019 3:56 pm Post subject: Re: What did YOU do to your van today? |
Replaced the AWG8 wire from the starter to my ACR with a premade AWG4 cable from the local marine supply store.
Discovered an oil leak but not the source. Somewhere in the vicinity of the oil filter/heat exchanger and new gauge senders. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Vnyd Dog Samba Member
Posted: Sat Jan 12, 2019 4:14 pm Post subject: Re: What did YOU do to your van today? |
Mounted up the Jack Bombay struts. Followed the instructions exactly and it came out great. My ultimate goal is mounting Thule ARGs. The two-hole bracket kind so I want to "reuse" one of the strut holes. I know someone has done this before but I can't find the thread. I'll use the rear ARG hole with the strut acorn. But, it looks like the ARG bracket and arm itself need to be bored out?? Pics? Linky? _________________ '87 Westy 1.8T Conversion, Orignal Owner, European Delivery @ Westfalia factory in Weidenbrueck.
The Story:
https://www.thesamba.com/vw/forum/viewtopic.php?t=713391&highlight=life |
elizer Samba Member
Posted: Sat Jan 12, 2019 4:52 pm Post subject: Re: What did YOU do to your van today? |
The bolt that jack bombays strut uses is bigger so you just have to bore it out as you said. With the thule it will be a little lower so you might need to get a the midlength towers from thule. I went with yakima so I am not 100% sure with thule.
Hardest part for me with the arg was making sure they were in the exact same placement on both sides. Took a lot of measuring.
But if i were to do it all over again I would not have tried so hard to use the same bolt and just placed the arg at a more optimal spot. |
Posted: Sat Jan 12, 2019 7:39 pm Post subject: Re: What did YOU do to your van today? |
Finally replaced both the lower and upper oil pressure units....and while I was there, I replaced both belts. Now for the sending unit in the gas tank |
Posted: Sun Jan 13, 2019 5:29 pm Post subject: Re: What did YOU do to your van today? |
Reconnected/cleaned up the rest of the wiring I undid when I took the dash out the other week. I have a radio again as well as footwell lighting and other conveniences. Handy grounds are to be found at the screws for the glovebox hinge.
Did some more testing of the solar charging system: full sun, 18V at the panel, 14 at the battery from the charger but at 2 mA. At the panel it's 7 mA so there's nothing happening there. Maybe after the equinox the sun will be strong enough to make a difference.
Now to see how long it takes to wear the battery down after driving around to charge it up.
— dhaavers |
AZ Landshaper Samba Member
Joined: February 08, 2009 Posts: 1698 Location: The Old Pueblo
Posted: Sun Jan 13, 2019 5:56 pm Post subject: Re: What did YOU do to your van today? |
Replaced my Blau expansion cap. Old one wasnt able to make the horn noise and didnt allow coolant back into the expansion tank once pushed out. New one toots like a trumpet. Works too. No more blinking light every morning or slowly draining expansion tank.
vroom vroom vrooooom! _________________ Support Small Business.
85 Weekender w/ EJ22
Previously
64, 71, 72, 73, 76, 81, 84, 85 & 87 Campmobiles and Westfalias
and a 67 bug. |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Mon Jan 14, 2019 9:16 am Post subject: Re: What did YOU do to your van today? |
I replaced my windshield mister nozzles with dual hole units and aimed them. Fresh wiper blades for winter too. _________________ Steve
Steve's 87 Syncro project |
jlrftype7 Samba Member
Posted: Fri Jan 18, 2019 7:37 pm Post subject: Re: What did YOU do to your van today? |
Finally got back to working on Hilga with the Holiday Crush now subsided. Replaced the Rear Heater Core tonight with a new core from Van Cafe and finally quieted down the squeaky blower motor along with it. I had lubed the easy to get to rear bearing , but only got the still noisy front bearing on the Rear Blower once I had the assembly out of the Vanagon.
One down, one to go... _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Sun Jan 20, 2019 2:58 pm Post subject: ATF Fluid quieted my suspension sqeeks.. |
I got a disposable paint brush and a jar of ATF fluid and painted my suspension bushings. The van squeeked incessantly all the way back from BBTB in Lake Havasu. 4.5 hours. Thank god for head phones. Now, 10 miles after the ATF treatment things are silent. Im not 100% sure we are in the clear but so far so good. _________________ Support Small Business.
Previously
and a 67 bug. |
