John Moxon Samba Moderator
Joined: March 07, 2004 Posts: 13958 Location: Southampton U.K.
70 140 Samba Member
Joined: September 22, 2002 Posts: 8471 Location: Ontario Canada
Posted: Fri Oct 26, 2007 6:30 am Post subject: |
You will need some parts. The gears that drive the odometer tend to wear out or strip.
They are a real PITA to fix, even if you have the correct bits. As much as I hate to say it - time to pay someone else. Maybe Thom will chip in with the name of the guy who did his clock, speedo and Tach. |
mygreenbus Samba Member
Joined: February 14, 2007 Posts: 1154 Location: Palm Coast, FL
Posted: Fri Oct 26, 2007 7:53 am Post subject: |
I highly recommedn North Hollywood Speedo. I first used them in 1988 when we lived in SoCal and continue to do so in here FLA. They did the clock on our Ghia. I think there prices are fair and the work excellent. |
walkerman Samba Member
Posted: Sat Oct 27, 2007 8:08 am Post subject: |
John Moxon wrote: |
70 140 wrote: |
Perhaps North Hollywood Speedometer would give me a quote to fix the odometer and change my non-functioning clock to a Tach.
Any donations kindy received |
They converted my clock to a tach...and kept all of the lights, signals and gas guage in working order. A real good job... |
Posted: Sat Oct 27, 2007 8:16 am Post subject: |
John Moxon wrote: |
mywifesghia wrote: |
Yes I've heard nothing but good reports of North Hollywood Speedo but I might have to go with someone closer to home. |
If you know anyone who owns a DeTomaso Pantera in the UK check with them and see who they use. Many of the old tachs were converted to run with electronic ignition. (mine was done at NH Speedo). Anyway they have a good gorup over there and might be able to help. |
Tall Bloke Samba Member
Joined: October 07, 2005 Posts: 233 Location: UK>Ohio>UK
Posted: Tue Nov 21, 2017 6:54 am Post subject: Re: Odometer repair |
Resurecting an old thread - 10 years + 3 weeks.
John - how did you get on with your repair for the odometer, as I have the same issue - brass 10 tooth gear inside the cable drive worn beyond use?
I have found a supplier in the UK to replace gear on shaft in the UK, but not cheap -cost of used decent beetle speedo - which I could use as spares.
Tim _________________ -------------------
All of 30 horses ! |
paul_round Samba Member
Posted: Tue Nov 21, 2017 9:17 am Post subject: Re: Odometer repair |
I have a speedo I need fixing too, anyone used Speedy Cables? |
c21darrel Samba Member
Andre@KGPR/Airhead Samba Member
Joined: June 15, 2011 Posts: 228 Location: Ventura CA
Posted: Sat Nov 25, 2017 4:37 pm Post subject: Re: Odometer repair |
We’ve offered this service for 100 years. We also zero out odometers on rebuilt speedos for no charge now. It used to be a $20 option...
That said, NH Speedo is great, as is the other outfit in Palo Alto, CA. |
calexican Samba Member
Joined: June 11, 2008 Posts: 730 Location: El Paso, TX
Posted: Sat Nov 25, 2017 7:09 pm Post subject: Re: Odometer repair |
^^^sent mine here and am very happy with the results^^^ |
Dash76 Samba Member
Joined: November 09, 2016 Posts: 23 Location: Denmark
Posted: Fri Jan 19, 2018 5:14 am Post subject: Re: Odometer repair |
I'd be interested in hearing what you decided to do?
I have the same problem and not having much here in Europe finding a solution. Someone suggest Kraut Classic Parts in Germany, but they have issue get late model KG parts at the moment, or so the story goes. |
Posted: Fri Jan 19, 2018 5:27 am Post subject: Re: Odometer repair |
I needed the brass cog in the odometer drive- which I found a company in the UK had - I sent small shaft to them, they removed old worn cog and pressed on the new brass replacement - I reassembled - It now works perfectly.
website -http://www.jdo1.com _________________ -------------------
