Glenn Mr. 010
Joined: December 25, 2001 Posts: 76761 Location: Sneaking up behind you
Posted: Fri Oct 26, 2007 7:07 pm Post subject: Tach instead of clock |
I'm working on a 70 SC that will have a 2276 in the back. The owner gave us a tack to install on top of the dash. I was thinking is it possible to install a tach in place of the clock in the stock gauge panel. And if so, which tach fits best. _________________ Glenn
Member #1009
#BlueSquare |
autiger78 Samba Member
Joined: September 25, 2007 Posts: 411 Location: Auburn, AL
Posted: Fri Oct 26, 2007 7:49 pm Post subject: |
If you do, wanna sell the clock? _________________ Wanted - Dormobile Roof Parts! |
Glenn Mr. 010
autiger78 wrote: |
If you do, wanna sell the clock? |
Not mine... it's a customer's car/truck. _________________ Glenn
Member #1009
#BlueSquare |
stevo Samba Member
Joined: January 22, 2004 Posts: 906 Location: the eugeniverse
Posted: Fri Oct 26, 2007 8:00 pm Post subject: |
check, http://www.ratwell.com/technical/Tachograph.html
i bought an older vdo at a swap for a buck and paid six and a half times [picked up in redding, their shipping is a bear] more for the bus boys ring that holds it in the clock spot. they way it goes, works great. _________________ When you cross an Irishman, they never forget. I mean, never. |
busses2vanagons Samba Member
Posted: Sat Oct 27, 2007 12:53 am Post subject: |
Glenn, check Bus-boys website under VDO Gauges and Accessories. You will find exactly what you need. _________________ *New* '84 Vanagon GL
Daily Drivers:
'94 GolfIII GL
'87 Vanagon GL
Projects:
'71 Type 2 Deluxe 9 Seater
'82 Doka (Imported to Hawaii new) |
MrBreeze Samba Hitman
Joined: October 06, 2002 Posts: 5527 Location: Lawn Guyland, Noo Yawk
Posted: Sat Oct 27, 2007 2:42 am Post subject: |
http://www.bus-boys.com/bbvdo.htm#tach
$6 for a ring so you can mount a tach in that spot. _________________ -=Rob
WTB: Bay Shore or Queensboro VW Frames
HBB 1984-2009
RW 1943-2011
ER 1964-2023 |
hansie Samba Member
Joined: August 29, 2007 Posts: 476 Location: Beach Lake, PA
Posted: Sat Oct 27, 2007 3:04 am Post subject: |
Hi Rob
Do you have any picts of the SC ?
Karl |
germansupplyscott Samba Member
Glenn Mr. 010
Posted: Sat Oct 27, 2007 8:02 pm Post subject: |
Thanks guys... I passed the info on to the customer. _________________ Glenn
Member #1009
#BlueSquare |
neil68 Samba Member
Joined: March 17, 2007 Posts: 3440 Location: Calgary, Canada
Posted: Sat Oct 27, 2007 8:48 pm Post subject: tach |
Glenn,
Another option: I pulled a VDO tach out of a BMW a few years ago (at the wreckers) and it fit perfectly in my '69 bus, where the stock clock would have been located (the bus came with just the blank plate). I don't remember what type of BMW it was, however.
Neil. |
torsten92 Samba Member
Joined: December 21, 2004 Posts: 35 Location: Kahla, Germany
Posted: Sun Oct 28, 2007 5:17 am Post subject: |
neil68,
which type and year was the BMW?
Thanks _________________ 1970 1.6l Kombi
1972 Safare Custom Camper 1.8 dual carbs
1979 Army Double Cab
1995 Audi S6 Avant
1988 BMW K100 RS |
Tri-Bus Samba Member
Joined: November 29, 2005 Posts: 732 Location: Butler PA
Posted: Sun Oct 28, 2007 5:46 am Post subject: |
Glenn,
I have a VDO tach mounted using the Ring from Bus Boys, I also mounted guages using their thre guage panel below the radio.
Oil pressure, temp, and voltmeter were bought on ebay from a 914, came with senders for around $50
Sorry for the poor quality pics
_________________ 73 Westy
A VW team with a triathlon problem, or something like that.... |
nebe Samba Member
Joined: October 08, 2007 Posts: 450 Location: Rhode Island
Posted: Sun Oct 28, 2007 7:25 am Post subject: |
i like the diamond plate kick panel |
Posted: Sun Oct 28, 2007 7:49 am Post subject: |
nebe wrote: |
Thanks
I also did the rear hatch / tailgate ( wood panel was rotted and mostly fone), and am going to do the sides of the walk thru and the back of the z-bed ( Westy)
Might do the lower parts of the inside driver and passenger doors. P.O. realy hacked them bad _________________ 73 Westy
mygreenbus Samba Member
Joined: February 14, 2007 Posts: 1154 Location: Palm Coast, FL
Posted: Sun Oct 28, 2007 9:47 am Post subject: |
I alwasy try and use our VW suppliers but this tach is about $73 at Summit Racing. www.summitracing.com |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Sun Oct 28, 2007 4:41 pm Post subject: Re: Tach instead of clock |
Glenn wrote: |
is it possible to install a tach in place of the clock in the stock gauge panel. |
Movement is out of an old Jaguar with VW speedo numbers shrunk and silk-screened on. Has worked flawlessly for 27 years.
_________________ www.itinerant-air-cooled.com |
tootype2crazy Samba Member
Joined: October 08, 2007 Posts: 1276 Location: St. Louis Missouri
Posted: Sun Oct 28, 2007 4:47 pm Post subject: |
Hi have a vdo tach intalled in my blanking plate/clock spot. I mounted mine with a homemade ring made out of a piece of sheet aluminum that I cut a big hole in for the tach, and then two more for the screws. I used the blanking plate for the measurements. It was really easy. _________________ air-cooled or nothing for me
1978 Sunroof Deluxe Bus (daily driver)
1978 Transporter (mom's, making into a camper)
1970 Single Cab 2.1 turbo/EFI 6 Rib, 78 front beam, vanagon backing plates on rear (project)
2001 GTI VR6 (wife's) |
Desertbusman Samba Member
Posted: Mon Oct 29, 2007 2:59 am Post subject: |
Here is how mine is. I don't have a problem with a small tach but I'd like one in th 6,000 range. Maybe even a 5,000 rpm tach.
_________________ 71 Superbug
71 Westy |
renobdarb Samba Member
Joined: September 13, 2005 Posts: 878 Location: Eastern Idaho
Posted: Mon Oct 29, 2007 4:33 am Post subject: |
If you get that VDO tach make sure you get the $.02 diode from Radio Shack. Your tach will bounce all over the place without it. _________________ ----------
1978 Campmobile, 2000cc w/hydro lifters, dual Weber 44 IDF carbs (50 idle jets, 115 main jets), SVDA distributor w/Compufire. |
Posted: Mon Oct 29, 2007 4:37 am Post subject: |
Nicely done, Desert! _________________ Wanted - Dormobile Roof Parts! |
