NuggJugg Samba Member
Joined: July 27, 2003 Posts: 84 Location: Bay Village, Ohio
Posted: Tue Aug 12, 2003 7:51 am Post subject: Carb Sweating |
What would cause my carb to have beads of water on it sometimes? _________________ My Shows:
http://db.etree.org/nugg_jugg
1971 Westfalia 1600 DP
1972 Campmobile 2.0 Liter
1975 Beetle
1990 Jetta GL 5 speed manual 190,000 miles and still smokes! |
Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Tue Aug 12, 2003 9:05 am Post subject: |
Your carb is icing. The venturi effect causes the intake temperature to be significantly lower than the engine compartment, causing condensation. It should only be there for a short while before the engine warms up. Sorry for the geeky explanation. Do you have a heat riser setup for your carbs? _________________ www.zwerks.ca |
Posted: Tue Aug 12, 2003 9:36 am Post subject: |
What if it has condensation on it after its been driven for awhile? _________________ My Shows:
1975 Beetle
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Tue Aug 12, 2003 10:00 am Post subject: |
I would check for vacuum leaks as well. Change out your gasket and make sure that the two mounting nuts are tight. I switch mine over to the nylon lock nuts.
Make sure that your heat risers are not clogged too. Those preheat your manifold as well. Soemtimes just tapping them while the motor is running will free them up. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
nodtobob Samba Member
Joined: May 27, 2003 Posts: 208 Location: Santa Barbara, CA
Posted: Tue Aug 12, 2003 10:47 am Post subject: |
Sometimes that happens on the neck of the intake just below the carb but it is not a problem, just two different temps meeting together like the threads above stated. _________________ slow down! |
