NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Mon Oct 01, 2012 8:31 am Post subject: |
chrisradioman wrote: |
Where can i buy some of them? |
The most likely source, would be a car dismantlers in Sweden. _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
chrisradioman Samba Member
Joined: September 20, 2007 Posts: 4873 Location: Swansea (Sunny Penllergaer) Wales UK
Posted: Mon Oct 01, 2012 11:31 am Post subject: |
NASkeet wrote: |
The most likely source, would be a car dismantlers in Sweden. |
I'll ask at FBI they are always over there, thanks Nigel. _________________ http://www.vintagevwweddings.co.uk/contact.html |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Mon Oct 01, 2012 11:51 am Post subject: |
NASkeet wrote: |
I'll ask at FBI they are always over there, thanks Nigel. |
Before you guys all go asking the Federal Bureau of Investigation, what Nigel is referring to is FBI VW, in Swansea, Wales: http://www.fbivw.com _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
jtauxe Samba Member
Posted: Mon Oct 01, 2012 11:55 am Post subject: |
panel wrote: |
Anyone have some pics of what the mounting looks like when looking through the rear seat? I'd like to see what the belts attach to in this area.(not my bus). I need to add a baby seat to the back and need to add a lap belt in the middle or to one side.
Be sure to secure that spare tire, too! That'd be a nasty missile. _________________ John
http://vw.tauxe.net
chimneyfish Samba Member
Joined: July 28, 2009 Posts: 881 Location: United Kingdom
Posted: Mon Oct 01, 2012 3:49 pm Post subject: |
1976 T2 deluxe microbus body, rear seat belt fixing anchor points. On this deluxe frame microbus, I have VW of Australia extension brackets for the near and off side rear seat belts, which were fitted as standard with VW/Audi marked Repa belts to meet what is known as the requirements of the ADR (Australian Drving Regulations).
Here is the VW of Australia rear belt extension ADR compliant bracket removed, there is one bracket each side of the rear bench seat, plus a standard lap belt in the middle of the rear bench seat:
On the deluxe body, these 10mm thread fixing holes (17mm spanner) are an integral part of the vehicle body, integrated into the frame during manufacturing. Absolutely solid fixings:
_________________ 1965 Type 1 Deluxe (1200cc)
1976 Type 2 T2b Microbus L (1800cc Type 4)
Previously...
1972 T2 Camper (Devon), 1988 Golf, 1972 Type 1, 1984 Polo, 1972 T2 Camper (Danbury) |
Posted: Tue Oct 02, 2012 1:45 am Post subject: |
chimneyfish wrote: |
Are these brackets readily available in Australia. _________________ http://www.vintagevwweddings.co.uk/contact.html |
Hoody Samba Member
Posted: Tue Oct 02, 2012 6:55 am Post subject: |
No they are not readily available. I have only ever seen one set for sale. And that was about a month ago. |
Posted: Tue Oct 02, 2012 8:20 am Post subject: Rear seat belts |
The factory-fitted, rearmost passenger, seat belts, with the raised shoulder-strap mountings, were most commonly found, on Swedish-specification, 1968~79 VW Type 2s, where rear seat belt fitment, was probably obligatory, from quite early on.
Hence, the best source is likely to be, through a network of vehicle dismantlers in Sweden.
However, it's debatable, whether these seatbelts would be suitable in unmodified form, owing to the position of the inertia reel and the presence of the Westfalia campervan's rearmost bed-cushion, above the engine deck.
One of my local acquaintances (lives less than 10 minutes walk from my home), owns a second-hand, Swedish Army specification, 1975 VW "1800" Type 2 Kombi, which was also equipped with this type of rear seat belt.
In the near future, when he has completed the present round of vehicle restoration work, I shall be making some sketches, plus taking some detailed measurements and photographs, of "interesting features". This will include the rear seatbelt's raised shoulder-strap mounting, the design of which I hope to adapt, for use in my 1973 VW "1600" Type 2 Westfalia Continental campervan. _________________ Regards.
Nigel A. Skeet
Posted: Tue Oct 02, 2012 11:46 am Post subject: Re: Rear seat belts |
NASkeet wrote: |
In the near future, when he has completed the present round of vehicle restoration work, I shall be making some sketches, plus taking some detailed measurements and photographs, of "interesting features". This will include the rear seatbelt's raised shoulder-strap mounting, the design of which I hope to adapt, for use in my 1973 VW "1600" Type 2 Westfalia Continental campervan. |
Nigel I'd be very interested in pics & drawings, I could then get replicas made of them. _________________ http://www.vintagevwweddings.co.uk/contact.html |
Posted: Tue Oct 02, 2012 12:49 pm Post subject: |
Are these brackets readily available in Australia. |
All I can say is check out the Kombi Club Forums, under buy and sell:
http://forums.kombiclub.com/index.php
You will also see them fitted pretty much as standard to the microbus models in the galleries on there.
Also http://www.ebay.com.au but remember to search for "VW Kombi" rather than "VW bus" or "VW Camper".
Here is an Australian ADR compliance label, these are non-inertia belts, I wonder whether they are longer than standard German belts.
Chris / Nigel, I have a load of pictures with measurements of these things, did them for another member last year. But I think trying to fabricate them would be a lot harder than just keeping an eye on the Australian ads.
Nigel, I like these, are these the Swedish army inertia reel belts you mention?:
Previously...
manikmike Samba Member
Joined: January 01, 2007 Posts: 504 Location: Boston, MA
Posted: Tue Oct 02, 2012 1:22 pm Post subject: |
Quote: |
Nigel I'd be very interested in pics & drawings, I could then get replicas made of them. |
Ditto across the pond, please - tho my usual offer of beer traded for favors might be a bit more difficult than usual...! _________________ Mike
Boston, MA |
Posted: Wed Oct 03, 2012 7:35 am Post subject: Rear seat belts |
They are not specific to the Swedish army. I have also seen them on other Swedish specification, 1968~79 VW Type 2, passenger-carrying vehicles. _________________ Regards.
Nigel A. Skeet
CessnaJon Samba Member
Joined: August 15, 2008 Posts: 677 Location: Senoia,GA
Posted: Wed Oct 03, 2012 8:46 am Post subject: |
There has to be a Sambanite that will make us a rear 3 point kit for our Bays.I would buy 2, for sure. I worry about my boogers in the back with no shoulder strap. _________________ 1973 Westy (shared birthday)
1990 Westy Multivan
2015 Passat TDI 6sp
2015 Sportwagon TDI 6sp
LR-JET, Gulfstream 159 |
tkgeorge_99 Samba Member
Joined: September 30, 2010 Posts: 149 Location: Sacramento
Posted: Sun Oct 14, 2012 4:16 pm Post subject: |
I would definately be in for a pair also if there is a fabricator out there that wants to make a few. |
davidoft Samba Member
Posted: Sat Dec 01, 2012 3:56 pm Post subject: |
im in the process of having some fabricated from originals, my swedish bus came with them in. |
RatCamper Samba Member
Joined: November 13, 2008 Posts: 3305 Location: Australia
Posted: Sun Dec 02, 2012 2:07 pm Post subject: |
My bus is kind of shelved for now as a potential driver. I'm having a lot of trouble justifying rear lap belts for the kids.
I'll keep working on it for sure but really I'll have to hold out until things improve a bit and I can buy a shell from a bus with front end accident damage or something to poach its interior metalwork from the C to D pillars so I can actually mount a shoulder point. But then that's only one belt. _________________ Vehicle: 1975 Special order delivery walkthrough panel based pop-top camper (LCA / Sunliner). Motor: Nippon 1.8L Single port Wasserboxer, Transmission: 3 rib 002. |
Posted: Tue Jul 02, 2013 11:23 am Post subject: seat belt bracket used to clear door air duct |
I thought I should add to this thread as an ongoing resource for info, as I stumbled upon some repros of the Australian brackets for the front seats.
These brackets were made by VW of Australia for the T2, pictured below is an original bracket on my 1976 Microbus, with original VW Audi inertia reels by the OEM manufacturer Repa, to comply with the ADR (Australian Design Rules) which required inertia reel seat belts in the front for the driver and passenger, and enabled the repositioning of an inertia reel block, pushing it further back and inwards so they do not clash with the door and seat, utilising and retaining the stock seat belt anchor point.
I found online that repros are now available and made in the UK:
http://www.status-vw.co.uk/bay-van-68-79/main-body...-1979.html
http://www.justkampers.com/211-809-257-cab-seat-belt-brackets-vw-t2-bay-1967-1979.html
The original brackets, and the repros, should fit all years of T2 bay windows, although I assume they are probably of not much use to Westfalia owners with the swivel seats and no bulkhead (bay window Westies were not generally available in Australia in any case so I understand). _________________ 1965 Type 1 Deluxe (1200cc)
Previously...
Posted: Sat Aug 24, 2013 8:30 am Post subject: Seat Belts & Rearward-Facing Seats |
I was interested to note in the most recent issue of Volkswagen Camper & Commercial magazine, the following article about the innovative provision of three-point, inertia-reel seat belts, which were retro-fitted to Steve Williams' 13-window, "split-screen", 1963 VW 1200 Type 2 Devon campervan, by Quickfit Safety Belt Services, who also advertise in the magazine, on Page 53.
Steve Williams, "Three-point seat belts - Safe travelling in a split!", Technical, Volkswagen Camper & Commercial, Issue 71, September 2013, Pages 72~73.
Making suitable seat-belt provision for all VW Transporter seats, which are occupied whilst travelling, is one of my major "hobby horses", so I was pleased to see the publication of such an article, in one of the mainstream VW Transporter magazines.
However, I was EXTREMELY CONCERNED that the REARWARD-FACING, two-position bench seat, illustrated on Page 72, appears to have NO provision for HEAD RESTRAINTS, to complement the retro-fitted seat belts. Even if seat belts were not fitted, head restraints should have been incorporated, if these seats were to be used whilst the vehicle is in motion.
If properly designed, REARWARD-FACING seats are inherently safer than forward-facing seats, but ONLY IFF the rearward-facing seats have ULTRA-HIGH BACKS (called "tombstone" seats in the USA) or PROPERLY-ADJUSTED HEAD RESTRAINTS; otherwise, even a moderately serious, low-speed frontal collision, could easily result in DEATH or SERIOUS INJURY (i.e. paraplegia or quadraplegia) from a broken neck.
Hence, I hope to somehow contact the author Steve Williams, or otherwise convey this information to him, so that he may take steps to retro-fit appropriate head restraints to his rearward facing seats and hence avoid placing his family or other passengers in EXTREME danger; young children being especially vulnerable to neck injuries! In the meantime, I shall alert Quickfit Safety Belt Services, in Stanmore, Middlesex, to this oversight! _________________ Regards.
Nigel A. Skeet
Sjtw Samba Member
Posted: Tue Oct 08, 2013 1:46 pm Post subject: Re: Seat Belts & Rearward-Facing Seats |
NASkeet wrote: |
Hence, I hope to somehow contact the author Steve Williams, or otherwise convey this information to him, so that he may take steps to retro-fit appropriate head restraints to his rearward facing seats and hence avoid placing his family or other passengers in EXTREME danger; young children being especially vulnerable to neck injuries! In the meantime, I shall alert Quickfit Safety Belt Services, in Stanmore, Middlesex, to this oversight! |
Thank you for your concern Nigel. I saw your letter in Camper and Commercial and appreciate you trying to contact me.
I just wanted to reassure you that the rear facing seats aren't used by my children when we travel. Generally they're occupied by a Colman Cooler (secured by the seatbelts).
On the few occasions they were used, the children were in their car seats which have their own head restraints built in.
Perhaps I should have added that to the article!
Thanks again.
All the best
Steve Williams |
Posted: Tue Oct 08, 2013 9:03 pm Post subject: |
Meanwhile...
Has anyone come up with a schematic for these?
I've someone willing to try to fab - but I can't even find time* to install the 20ft long tach wiring I've been staring at longingly, nevermind try to mock this up...
* I blame my toddler and 3rd grader's science projects; they're too young for psychological impact, right? _________________ Mike
Boston, MA |
