zabo Samba Member
Posted: Wed Jan 09, 2013 1:53 pm Post subject: |
got my old Unity light hooked up a few weeks ago-
Wanted to keep it low..
_________________ 1960 6 volt sedan- 1978 adventurewagen
–wanted bill spreen atlanta dealer tag frame |
subgraphic Samba Member
Joined: January 02, 2004 Posts: 141 Location: San Diego, CA
Posted: Wed Jan 09, 2013 2:01 pm Post subject: |
Can we get some info on this one? |
GinsterGTIVR6 Samba Member
Posted: Wed Jan 09, 2013 3:29 pm Post subject: |
Just finished making the reverse lights brake lights..Painted the lenses and wired them up last night....Crappy pics for now..
mrmarcdude Samba Member
Joined: December 15, 2005 Posts: 715 Location: Vacaville, Ca
Posted: Thu Jan 10, 2013 12:01 am Post subject: |
That looks good! _________________ - Marc M.
-65 Beetle -1600dp- |
2type2 Samba Member
Joined: June 02, 2002 Posts: 975 Location: SW Colorado
Posted: Thu Jan 10, 2013 5:01 am Post subject: |
Subgraphic et al- My third brake light is in the rear vent (pic in my gallery). Many have placed LED strips in the vent but its not visible in sunlight because they are mounted too far back and too low inside. I put LED strips in a piece of 1" alumunum and curved it to concave, but it is close to the vent and more visible. Also its angled up to meet the eye of the taller vehicles that are behind. _________________ "A life of peace and happiness depends on your own gratefulness" |
VWMIke82 Samba Member
Joined: June 10, 2008 Posts: 70 Location: Lancaster, CA
Posted: Mon Nov 04, 2013 11:32 am Post subject: |
I hate to bring this back from the dead but its the best thread for this question. You guys with snowflake taillights, how did you wire the third brake light? I want a third brake light that wont flash with the blinkers, just a brake light. The way I understand it, is there are 2 wires to each bulb, one for running light and one for brake/turnsignal. So if I just splice into the brake light wire, I will get both signals from it. Am I understandning this correctly? Thank you
Mike
1959 Bug _________________ 1959 VW Bug Sedan
I chopped it up for Baja and then put it back to stock...
1914 cc, 043 heads, 110 cam, weber 40idfs. |
fluxcap Samba Member
Joined: February 07, 2006 Posts: 1969 Location: Newnan GA
Posted: Mon Nov 04, 2013 11:55 am Post subject: |
I have a 62 that I retrofitted snowflakes to. My third brake light is l.e.d. and gets its power directly from the brake light switch on the master cylinder.
Mine is mounted in my rear window, so I ran the wire under the carpet, then up into the trunk through the grommet that the dimmer switch wires pass through, then through the grommet that passes down to master cylinder area. _________________ Eric - 1966 camper bus
"It's like, how much more black could this be, and the answer is none.......none more black." |
Buck Naked Samba Member
Joined: March 11, 2009 Posts: 400 Location: El Dorado County,CA
Posted: Mon Nov 04, 2013 11:58 am Post subject: |
VWMike82, yes taping into the wires at the rear of the car with snowflakes will cause your third brake light to flash with the blinkers. In order to get just a brake light signal you would need to run a wire from front of the car. Connecting directly at the brake light switch or catching it where it comes up to the blinker wiring in the trunk.
Shane _________________ Be unique, like everyone else.
'63 Beetle Ragtop |
Posted: Mon Nov 04, 2013 12:07 pm Post subject: |
Thank you very much! _________________ 1959 VW Bug Sedan
thefladge Samba Member
Joined: July 25, 2005 Posts: 1290 Location: Anaheim, CA
Posted: Mon Nov 04, 2013 1:55 pm Post subject: |
Back in the '80's, I made a third brake light for my Cal Look Bug from pieces of a 1956 to 1961 tail light.
I cut an oval hole in the deck lid and fit it sideways.
_________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate. |
Maxoceanblue Samba Member
Joined: June 27, 2013 Posts: 429 Location: Pensacola, FL
Posted: Tue Nov 05, 2013 6:49 am Post subject: |
Just got mine installed, love it!
_________________ 1964 Beetle Sedan/1600cc DP 12v converted |
wellcraft Samba Member
Joined: September 12, 2014 Posts: 647 Location: Georgia
Posted: Thu Nov 13, 2014 7:28 pm Post subject: |
Nepenthe88 wrote: |
Keeping an old (but wonderful) thread alive...
What set up do u have? |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Fri Nov 14, 2014 9:25 am Post subject: |
We recently did a night race with our gravity cars and that required wiring them up for lights and a battery.
I was looking at lights in Advance Auto and they had a pretty large selection of LED lights. We purchased a set of 8 inch flexible strip lights to use as tail lights on one of the gravity cars and man are they bright!
But they also have a lot of longer flexible strip lights as well. And I think many of these could be used up in the plenum behind the louvers as a third brake light. They should be pretty easy to get up in there and they mount with a double stick tape so no holes to drill.
I'm thinking my 64 is going to grow one of those pretty soon and I need to see how well they do on 6 volt for the 55 as well. _________________ Mother Nature is a Mean Evil Bitch! |
bugandxbandme Samba Member
Joined: November 09, 2009 Posts: 162 Location: Richmond, VA
Posted: Fri Nov 14, 2014 10:14 am Post subject: |
Got my light hooked up a little while ago. It is one of those old Pioneer lights. I love it, but I wish it was bigger! I also might try to raise it a bit higher. |
tenover Samba Member
Joined: June 25, 2014 Posts: 5 Location: United States
grandpa pete Samba Member
Buscowboy Samba Member
Joined: October 29, 2004 Posts: 402 Location: South Coast, England
Posted: Mon Feb 23, 2015 12:02 pm Post subject: 7" STOP Light in a SO33 |
finally got round to installing my 7" stop light. Kept mine inside the rear hatch, easier to see when the bulb needs replacing as you wont get the reflection on rear window when the bulb has blown.
_________________ 1962 Gulf Blue Patina Deluxe Beetle
1963 SubHatch Westfalia MG/PW
1967 Fastback RHD Regatta Blue
1970 FI Auto Squareback
1999 T4 Transporter 2.5 TDI Reimo
http://www.youtube.com/@BuscowboyClassics
https://www.instagram.com/buscowboy/ |
Longboardluv Samba Member
Joined: September 23, 2014 Posts: 934 Location: Austin TX
Posted: Thu Apr 30, 2015 10:47 am Post subject: |
rcedola wrote: |
Here is MINES......
I just got this same light, can you post some pictures behind the light as to how you actually mounted the darn thing? |
Posted: Fri May 01, 2015 5:16 pm Post subject: |
I'm going to need an overrider clamp. Anyone have any suggestions?
[img[/img] |
codycat Samba Member
Joined: July 18, 2006 Posts: 1163 Location: Mobile, Alabama
Posted: Fri May 01, 2015 5:37 pm Post subject: |
Mine is that size - picked it up on ebay for a deal - mine is also the smaller size - I'd like to have the 5" one myself - i haven't hooked mine up yet tho
_________________ Did you ever stop to think, and forget to start again?
Winnie the Pooh
Sometimes the questions are complicated and the answers are simple.
Dr. Seuss |
