fortheloveofvdub Samba Member
Posted: Thu Nov 15, 2007 10:41 am Post subject: worn out pressure relief valve spring and happy vanaman |
I wanted to post this picture of the oil pressure relief valve spring I removed from my 100,000 mile old 2.1 compared to its replacement.
Long story short: I completed 24 months of Sundays work on my ’86 weekender with its transplanted ’91 motor only to be squealed at on the first ride, with only moderately high RPM’s (no tach).
I changed the oil from 10w40 to 20w50 Cast. GTX, replaced the spring mentioned above and replaced the high RPM switch. I then kissed the van, said sweet things, and no further problems so far (knock on an atom).
Other positive thoughts: Goldie's brand new pop top seals were turning the first mad river snow here in Ohio today; gotta get the cover on quick, but its nice to see her all sealed up. Spring is gonna be sweet; one more dead vanagon no longer.
good day, |
woggs1 Samba Member
Joined: February 22, 2007 Posts: 531 Location: South Pacifica California
Posted: Thu Dec 04, 2008 5:58 am Post subject: |
How does the spring increase oil pressure? _________________ 4 speed 88 Westy |
wgargan Samba Member
Joined: September 21, 2002 Posts: 871 Location: Dreaming of the Rockies
Posted: Thu Dec 04, 2008 6:11 am Post subject: |
if it is the oil pressure relief spring. My assumption would be that the stronger springs will require more pressure before it can be relieved. _________________ Current ride:
1983.5 Watercooled Vanagon 'L' Automatic transmission |
morymob Samba Member
Posted: Thu Dec 04, 2008 6:28 am Post subject: |
time & a hard run will tell but me thinks the heavy oil has temp overcome other problem(s).good luck. Do a oil press test -will answer your questions. |
tencentlife Samba Member
Posted: Thu Dec 04, 2008 9:30 am Post subject: |
The springs do get tired, every one I pull from a hi-miles wbx looks as short as the one in the pic.
The valve is understood as only relieving overpressure, so it is presumed that it only comes into play when pressure is actually pretty high and should have no effect on low hot running pressure, but I've done direct-comparison testing and found that in reality it affects galley pressure across the board. So one can deduce that it is actually relieving a little oil all the time, and more when the spring is weakened and oil is hot.
This is why I always suggest that people having hot OP problems and the buzzer going off in the classic pattern who are either in search of a quick fix or contemplating changing to a hi-volume oil pump just remove the valve plug and put a 1/4" washer on the spring seat. Standard flat washers are about 1.5mm thick and this will raise hot mid-rpm OP about 5psi, usually. When I did back-to-back tests I found I got better results from the washer for 5 cents and 5 minutes than you get with the $35 HV pump and 3.5 hours of work. The big pump only added about 3psi of pressure hot, when it is needed, but made a huge increase in cold pressure, like to 90-100psi, which isn't desirable.
You should not need to run 20w oil in a wbx that has decent bearing tolerances and the oiling system in good order. Lighter baseweight oil will reach every part of the engine faster on a cold-start, warm up quicker, clear lifter clatter in less time, do a better job of lubrication and heat transfer once warm, and increase engine efficiency overall. One thing that can be serviced without major disassembly to bring the oiling system closer to spec is to replace the relief valve spring, or shore up your tired one by shimming it up with a washer. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Vanagon Nut Samba Member
Posted: Sun May 08, 2016 12:20 pm Post subject: Re: worn out pressure relief valve spring and happy vanaman |
Wow. Great post by .10
Anyone know what the typical length of a tired oil pressure spring is?
Will a lot of oil come out from pressure relief galley when plug removed?
(I may attempt a driveway repair, on my land lords super clean driveway)
Thanks
1988 West DIY 50º ABA
VE7TBN |
CanStan Samba Member
Joined: October 16, 2005 Posts: 1039 Location: Calgary, AB
Posted: Sun May 08, 2016 9:07 pm Post subject: Re: worn out pressure relief valve spring and happy vanaman |
I replaced one I suspected was weak. It's been a while, but for some reason 64mm seems to ring a bell as the new length. I recall my tired spring being 4-5mm shorter. I know I found it easily in a search. Maybe someone else will confirm. You won't lose a lot of oil- less than 1/2 cup. It's a pretty quick and easy job. Good luck! |
Posted: Sun May 08, 2016 11:35 pm Post subject: Re: worn out pressure relief valve spring and happy vanaman |
Thanks CanStan. I'm hoping that valve spring is what's causing the oil buzzer
to go off. _________________ 1981 Westy DIY 15º ABA
VE7TBN |
Posted: Mon May 09, 2016 1:13 pm Post subject: Re: worn out pressure relief valve spring and happy vanaman |
Thanks. Found it. Seems a new spring is 62.4 mm or 62 mm.
CanStan wrote: |
I replaced one I suspected was weak. It's been a while, but for some reason 64mm seems to ring a bell as the new length. I recall my tired spring being 4-5mm shorter. I know I found it easily in a search. ..... |
mattcfish wrote: |
... A new pressure relieve valve spring (62.4mm) and a Mahle/Mann oil filter. I gained at least 15 more pounds at hot idle. No more red light. Lesson learned: don't use anything but Mahle/Mann filters.
tencentlife wrote: |
OP relief and OP switch are both downstream of the filter, so you can see that the filter is a big part of the overall picture. Every drop of oil passes thru the filter housing in a wbx. The only thing that determines how much oil actually has to pass thru the filter media is its internal bypass valve. That's why the correct filter ends up being so important in this engine; that filter bypass valve has a lot of control over pressure and flow. The crankcase OP relief valve provides final correction immediately after the filter itself.
I seem to recall the length of a new OP relief spring to be 62mm. I'm not at home so can't measure one for you, but I have posted that info somewhere here. I haven't measured them all, but I've found that every used one I have measured has lost about 2mm in length.
The error I see everyone make regarding the OP relief, and I was subject to the same until I did some more thorough testing, is that the OP relief is some kind of on/off device, i.e. it only opens when OP exceeds some set value and caps OP at or around that value. But that's not the case at all. It is partially to fully open at practically any time and at all phases of engine operation. It is a linear, not binary, device. That is why having a good spring of the right length, or shimming the spring seat (achieving a similar result) has an effect on OP across the board.
VE7TBN |
Posted: Mon May 09, 2016 8:23 pm Post subject: ReaL time help please |
1/4" washer goes between spring and plunger?
Or am I putting a washer at bottom of Spring where it sits on the plug?
That would be a much larger washer?
Thanks
VE7TBN |
kjono09 Samba Member
Joined: April 03, 2014 Posts: 191 Location: Seattle, WA
Posted: Sun Oct 02, 2016 6:58 am Post subject: Re: worn out pressure relief valve spring and happy vanaman |
How did you get the oil pressure relief plug off? Is there a hex Bilt head I can replace it with? _________________ 84 Retro-Westy GW 2.2L (Vincent)
67 Bug 2007cc (WBX in progress) (Davey)
Submariner |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Sun Oct 02, 2016 10:39 am Post subject: Re: worn out pressure relief valve spring and happy vanaman |
A. Make a special tool......
B. Yes, or just weld a big nut to the plug when it is removed.... _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
dustyrhodes Samba Member
Joined: December 20, 2010 Posts: 38 Location: Venice, CA
Posted: Mon Oct 03, 2016 12:40 am Post subject: Re: worn out pressure relief valve spring and happy vanaman |
Replacing this spring fixed my buzzer issues. I would get a buzzer above 2k rpms after a long run on the highway (or big hills). When I had the shop measure oil pressure it was quite low. I picked up over 10psi hot replacing the spring. _________________ 1989 Vanagon Westfalia |
Stephenmarklay Samba Member
Posted: Mon Oct 03, 2016 3:32 am Post subject: Re: worn out pressure relief valve spring and happy vanaman |
I see that some vendors sell a longer spring than the OEM and then a standard spring. Is going longer than OEM too much? _________________ 1985 Westfalia. Project 2017. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10252 Location: N. Idaho
Posted: Sat Oct 08, 2016 5:07 pm Post subject: Re: worn out pressure relief valve spring and happy vanaman |
Is there a seal in this spring cover? Or do you use sealant? _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32638 Location: Reading Pennsylvania
Robw_z Samba Member
Posted: Sat Nov 19, 2016 6:02 pm Post subject: Re: worn out pressure relief valve spring and happy vanaman |
I just did this. I decided to try the washer method because I like to feel thrifty and save $20 plus shipping from Van Cafe, but frankly it's probably worth it for the proper spring.
I got a single 10mm washer. The OD of the washer was smaller than the screw plug at the bottom of the spring, but the ID was too small to fit around the inner spring perch molded into the top of the screw plug. So I drilled out the washer a bit, and it fits well.
It only gains me 2mm though, I'd have preferred double that. My spring measures 60mm.
I have a hot oil buzzer every once in awhile, it freaked me out at first but this has been going on years with no problems other than the occasional buzzer, I'll update if this helped anything.
-Rob |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Sat Nov 19, 2016 8:37 pm Post subject: Re: worn out pressure relief valve spring and happy vanaman |
Robw_z wrote: |
I just did this.
-Rob |
A 2mm gain in length puts you right at the original 62mm length so your good. _________________ This free advice is worth exactly what you paid for it.
danfromsyr Samba Member
Posted: Mon Aug 07, 2017 11:27 am Post subject: Re: worn out pressure relief valve spring and happy vanaman |
bumping this thread up as I am planning to pull, measure & shim mine in the next week.
will report back any improvements.
Dan _________________
Abscate wrote: |
