nebe Samba Member
Joined: October 08, 2007 Posts: 450 Location: Rhode Island
Posted: Fri Nov 16, 2007 5:35 pm Post subject: BF Goodrich AT's |
anyone use these? i came up with a few search results but not much.
I would love to see a photo of what they look like on a bus. I dont want to look like a redneck, but I will be driving in sand and need a wide footprint.
thanks |
hagermanfolley Samba Member
Joined: August 03, 2005 Posts: 235 Location: Boise, ID
Posted: Fri Nov 16, 2007 6:36 pm Post subject: |
Sxuxrxf had them on the tiki bus, 27's I think but I have been searching for a while and cant find them. |
Traveling Writer Samba Scribe
Joined: May 07, 2006 Posts: 1112 Location: Florence, Italy
Posted: Fri Nov 16, 2007 7:31 pm Post subject: |
Here's my bud Cyril with his 14" BFG ATs.... tough to make out from here, but I don't think they look redneck at all. I've been very happy with them, and I thnk they look great. BUT they are almost entirely impossible to find in the 14 inch size. I think I bought the last 4 in the country! Any online shop you'll try to order from will list it on their page, but will call you back a few days after you've ordered to explain that they're out of stock. In fact, they're discontinued.
But great tires if you can find them!
_________________ Cheers,
Davi
1977 2.0 FI Westy
2011 1200cc Yamaha Super Tenere
1976 Feet (they work surprisingly well) |
Posted: Fri Nov 16, 2007 7:35 pm Post subject: |
does anyone make an all terrain that will fit the bus? |
torocreek Samba Member
Joined: June 20, 2007 Posts: 95 Location: Long Beach, Ca.
Posted: Fri Nov 16, 2007 7:36 pm Post subject: |
These are Bridgestone All Terrains 27x8.5x14
Other posts have said they are a discontinued tire and are only available as stock on hand so you might be able to find a set if you called around.
I don't know how to link cause I am lame at this computer stuff but search for a post named "14" BFG All Terrain Question" in the Vanagon forum. I think this post also explains some other tire options in the same size.
nebe Samba Member
that sucks that they are discontinued
I found the tiki bus
nebe Samba Member
Posted: Fri Nov 16, 2007 7:39 pm Post subject: |
heres another bus that inspires me to beef up my bus.
Randy in Maine Samba Member
Posted: Sat Nov 17, 2007 10:17 am Post subject: |
Just be aware that if you end up with taller tires (circumference wise) you end up gearing up your final drive ratio.
It is important if you have to worry about your cylinder head temps.
Here is a handy little calculator for looking at different tires circumferences.... Put in the stock 185R14 on the drop down menu to see where you are starting from.
http://www.1010tires.com/TireSizeCalculator.asp |
jmstu76 Samba Member
Joined: March 01, 2004 Posts: 1227 Location: Edmond Oklahoma
Posted: Sat Nov 17, 2007 11:16 am Post subject: |
I had my BF AT's for over about a year and a half. I love them and so do most of the other bus guys around here. I don't think there is a shortage. I bought all five of mine from tirerack.com. Great price and shipping was lightning fast (hint hint bus depot). Here's 2 pics, not the greatest pics but you can get another view.
Our new spare
Also check out CJMazier's gallery. He's running a set, and I believe he ran them all the way from Canada to Baja.
Good tires, haven't had a problem with quality. They are just barely stiff enough to pass a acceptable bus tires. What i mean is they have a load rating of 1520lbs. per tire. I believe our buses call for a 1550 lb. load rating for each tire, so they are close. I do know that they only have 3 ply sidewalls so they are not as stiff sidewall wise as a true load C tire. They are a little noisey on the highway. They are 27 inches tall so you do lose a little pep and if you have a head temp guage (I don't, ignorance is bliss) you might want to watch those temps as Randy previously mentioned.
Ok, I just looked on the tire rack and they are not listed anymore. May be they are disappearing. I just bought my spare in August and had no issues. Ugh? _________________ James
'76 Deluxe Sage Green Westy
2258 cc GD case 78mm CW crank, 2.0 H-beam rods 5,325” 22mm pin, JE forged pistons with 15cc dish, JE rings, type 11 clearanced oil pump, CB Eagle 2205 Type-2 “Torque Special” hydraulic cam with matched lifters fed by CB Dual Weber 40 IDF MX with 6” foam air filters, currently 55 idle, 130 main, 200 air correction, 32 mm venturis. 27in General Grabber AT2 All Terrains, Berg Shifter, stock '76 exhaust HPC Ceramic Coated. 11/18/2020 |
vw76westy Samba Member
Posted: Sat Nov 17, 2007 12:23 pm Post subject: |
Try off-road shops
The bfgoodrich all-terrains are king in off-road world
They handle abuse just like any other off-road tire
but not as noisy my off-road friend said the bf...mud terrians
Are better, handle just as good on streets & no different than all-terains
As far as noise is concerned
The draw back........ More expensive will wear out a little faster on streets
& harder to find in large sizes
This is coming from a friend who buys 38 inch tires & off-roads every weekend
So maybe mud-terrains could still be found in vw size |
JMazier Samba Member
Joined: February 20, 2006 Posts: 900 Location: In my garage, Georgetown, Ontario, Canada...
Posted: Sat Nov 17, 2007 1:28 pm Post subject: |
jmstu76 wrote: |
check out CJMazier's gallery. He's running a set, and I believe he ran them all the way from Canada to Baja. |
I use them and love them. I drove them 12000 miles from Toronto to the tip of Baja and back and they are wearing beautifully and handle great. I took them on many different types of sand and they worked well. Even had to air them down to 12lbs to get out of deep sand and again they worked fine. They also have a wheel protector bead which is really nice, saves the wheels from getting scratched up. They are a bit taller than stock however according to my GPS they made my speedometer much more accurate.
I am in Canada and they are still available here…
Here is a picture in Baja;
I just happen to be doing some maintenance on the bus now that she is put away for the winter so some tires are off.
Here is a picture of the bead that protects the wheel
A picture of the tread
A couple of pics of the passenger front wheel. Note that the bus is off of the ground on jack stands…
_________________ Cheers!
Jérôme
’79 Cali Westy 2.0 F.I.
'74 Honda CB 350 Four
'78 Honda CB 750 K
'12 Golf GTI
'11 Ural Patrol |
nebe Samba Member
Posted: Sat Nov 17, 2007 4:02 pm Post subject: |
thanks for the pics. They do look great on a bus. I have a set on my tacoma and have always loved them but its hard to visualize them on a different vehicle. |
NOVA Bus Samba Member
Joined: April 18, 2005 Posts: 517 Location: Herndon, VA
Posted: Sun Nov 18, 2007 9:08 pm Post subject: |
Are those the BFG Radial AT KO's? If so, have used them on my 4Runner's for years, really good in sand, snow. They handle decent as well, for my 31-10.50's usually averaged 45-55K miles.
Here's a story, when changing to a new set at Costco to tire guy tells me there were two big nails in the tread, though the tire did not leak air--->they are very tough tires! _________________ ********************************
1977 Transporter / Weekender
- GE engine, L-Jetronic w/ hyd. lifters
- Brown Beige plaid P27 Interior (ED)
http:/[url=http://www.vw-mplate.com/mplate-29638.png]Click to view image
Camper Interior donor:
[/URL]/www.vw-mplate.com/mcode.php?lang=EN&id=721 (M-Code for interior). |
CLH Samba Member
Joined: September 03, 2003 Posts: 235 Location: Ben Lomond, CA
Posted: Sun Nov 18, 2007 10:48 pm Post subject: |
Been looking for replacements for mine for a month now, NLA |
CLH Samba Member
Posted: Mon Nov 19, 2007 10:55 am Post subject: |
Woot! Update, just ordered new Cooper Discoverer LTs in 27 8.50 14 from my local Big-O tires, will have them tomorrow. They said they have 50 available. BTW the Big-O Pathmax is NLA in that size. |
Steelhead Samba Member
Joined: February 25, 2007 Posts: 1791 Location: Kentfield, CA
Posted: Mon Nov 19, 2007 11:00 am Post subject: |
CLH wrote: |
Good choice. Perfect alternative to the BFGs and they are available everywhere. I love mine and will soon be putting some on my vanagon. _________________ '77 Bay Window / '89 Caratsburg (aka. the Stormtrooper) |
gostros Mr. Obvious
Posted: Sun Apr 06, 2008 11:08 pm Post subject: |
CLH wrote: |
got any updates/pics? |
CLH Samba Member
Posted: Mon Apr 07, 2008 11:09 am Post subject: |
Sorry, no digicam. I can tell you that I like the tires. They have a less aggressive tread pattern than the BFGs, so are a little quieter on the road, yet still seem good on dirt and snow. They look less beefy on the vehicle, but I think they are a great all around tire, and they're available! |
Collie Samba Member
Joined: April 03, 2006 Posts: 1285 Location: Virginia
Posted: Mon Apr 07, 2008 11:12 am Post subject: |
JMazier wrote: |
Jerome, whats the road noise on these things like compared to 'normal' tires??? |
Ruptured Tortoise Samba Member
Posted: Mon Apr 07, 2008 12:23 pm Post subject: |
I found these at Good Year. I think they're generic Wranglers. The size is 195/75 R14 Courser LT.
The scuffing on the sidewall is from a curb not the fender
_________________ My wife giggles everytime I say "Gland Nut".
66 Beetle
67 Karmann Ghia
68 Bay Window Camper |
