EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Mon Mar 08, 2021 6:02 pm Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
djfordmanjack wrote: |
most excellent ! beautiful detail work ! |
I appreciate the continued support!
This isn’t easy stuff. It takes lots of time and willingness to just not care what step is needed next. Just making it happen. _________________ www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine |
Posted: Mon Mar 08, 2021 6:09 pm Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
EverettB wrote: |
gatorwyatt wrote: |
If anyone has clear pics to show how throttle return spring and brake return spring hooks It would be super helpful. I looked through the gallery. Did t see much. |
Awesome work and pic layout
There are a couple pics at the start of this thread, is that what you need?
https://www.thesamba.com/vw/forum/viewtopic.php?t=553172
It's not a RHD Bus though |
As always, I try and document things because even though this site is old and not as much communication here as was 10-15 years ago I know it’s still a resource that is need to compile info and help each other.
I will say this, the RHD group is sure quiet when I ask for a basic question regarding a wire or cable routing or spring attachment point. I’ve been alerted on my way to work that someone is asking for details on something that I can share and immediately go into my office bypass my obligations and snap pics and put a tape measure to things and upload and help. In return, I ask nothing. Seems to be a one way community of cunts these days....
I typed that with my upmost sincere sarcasm... maybe. _________________ www.blastserv.com
wanted:
Who.Me? Samba Member
Joined: July 14, 2014 Posts: 2211 Location: UK (South)
Posted: Tue Mar 09, 2021 2:01 am Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
gatorwyatt wrote: |
I will say this, the RHD group is sure quiet when I ask for a basic question regarding a wire or cable routing or spring rattachmwbt point |
Maybe try creating an account on the Split Screen Van Club forum in the UK and asking there, and/or search the rides and projects forum to see who has a RHD Barndoor and PM them through that forum? You may get more RHD-related answers from a country that drives on the left.
https://www.ssvc.org.uk/phpbb/viewforum.php?f=8 _________________ Andy
Looking for info on my truck's history. Are you from Campbell California or nearby. Do you recognise it? ... http://www.thesamba.com/vw/forum/viewtopic.php?t=636786 |
bubba Samba Member
Posted: Wed Mar 10, 2021 2:42 pm Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
gatorwyatt wrote: |
EverettB wrote: |
gatorwyatt wrote: |
I typed that with my upmost sincere sarcasm... maybe. |
_________________ ***WANTED***
SO-23 Cargo net hooks...
for sale
curtain Bungee cords for SO23, 22, 33 ,34 ,35
http://www.thesamba.com/vw/classifieds/detail.php?id=1587591 |
Scotty Samba Member
Joined: July 02, 2003 Posts: 1531 Location: Northampton - Uk
Posted: Thu Mar 11, 2021 6:17 am Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
Here you go
No return spring for the throttle cable _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
Posted: Thu Mar 11, 2021 7:45 am Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
Much appreciated, Scotty.
I have tried thumbing around on SSVC and maybe it’s me but the site sure is difficult to see anything. Probably what you are used to.
There is a tab on the frame rail just to the left of the throttle cable and back a little. I attached a normal later model carb return spring to it and to the hole below the attachment point for the throttle.. seems good. _________________ www.blastserv.com
wanted:
D-train Samba Member
Posted: Thu Mar 11, 2021 12:37 pm Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
gatorwyatt wrote: |
There is a tab on the frame rail just to the left of the throttle cable and back a little. I attached a normal later model carb return spring to it and to the hole below the attachment point for the throttle.. seems good. |
Even try on dsk.com.au there’s a barndoor section in there. _________________ shiny paint doesnt make it worth any more |
Scotty Samba Member
Posted: Fri Mar 12, 2021 5:16 am Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
gatorwyatt wrote: |
My pleasure.
I didn’t have to search on the ssvc forum, those pictures are of my 52. _________________
EverettB wrote: |
Blue barny ute Samba Member
Joined: December 29, 2017 Posts: 9 Location: Australia
Posted: Mon Mar 22, 2021 5:06 am Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
Hey Gatorwyatt sorry I haven’t seen your posts for a while really enjoyed your pictures of your Ute back in the day I jumped under my Ute to check out the return springs found the throttle return spring that I added but no brake return spring which is odd thought I would also mention I put a 67 ATE master cylinder which works beautifully with my Barndoor wheel cylinders front and back anyhow here is a photo of the throttle return spring which had a tab already mounted on the Ute from memory I used a 31-34 pict carburettor accelerator spring
Cheers! |
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Mon Mar 22, 2021 7:08 am Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
I love the gate protection strips. I think I will put some on my singlecab.
_________________ .
Wanted:
Posted: Tue Mar 23, 2021 3:58 pm Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
Blue barny ute wrote: |
Cheers! |
I appreciate the effort and the info! Mine has the same tab and I used the same spring!
There are NOS Barndoor brake pedal springs in the classifieds right now. They hook to a small hole in the frame rail and around the indented pedal bracket that is clamped to the pin/shaft. Get one! Before they are gone...
The pics coming to me after 14 years of ownership and all from a simple email across the globe is nothing short of amazing and was better than my best Christmas as a child. _________________ www.blastserv.com
wanted:
Posted: Tue Mar 23, 2021 4:00 pm Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
Lind wrote: |
Those are from when the bed was heavily cut out and the bed strips were relocated to the gates on the inside. _________________ www.blastserv.com
wanted:
Posted: Tue Mar 23, 2021 4:09 pm Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
Heater pipe covered! And lots more done!
2 rims from Christer in Sweden. 1 from Virginia and one from Lind! Thanks guys _________________ www.blastserv.com
wanted:
Lind Samba Member
Posted: Tue Mar 23, 2021 5:59 pm Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
gatorwyatt wrote: |
2 rims from Christer in Sweden. 1 from Virginia and one from Lind! Thanks guys |
Always glad to help.
The underside of the truck looks awesome. _________________ .
Wanted:
Posted: Tue Mar 23, 2021 6:46 pm Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
Looks amazing! _________________ shiny paint doesnt make it worth any more |
Mr. OGPaint Samba Member
Joined: September 24, 2010 Posts: 823 Location: Oregon
Posted: Tue Mar 23, 2021 11:44 pm Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
Its really coming together, all your hard work shows. Thank you for sharing, I've been enjoying it. _________________ https://instagram.com/mr.ogpaint
Patrick Hall |
Posted: Wed Mar 24, 2021 12:57 am Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
Thanks Gatorwyatt I’ll certainly look into that brake return spring glad to help a fellow 54 single cab owner
Your doing a great job on yours
Cheers |
zuggbug Samba Member
Joined: June 17, 2008 Posts: 3479 Location: Anderson SC
Posted: Wed Mar 24, 2021 5:03 am Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
wow - i miss a few days on the samba and you have a picture dump.
thanks for sharing - you are doing a great job on the truck. _________________ SOUTHERN INTEGRITY AIRCOOLERS
58 15 window
56 westy |
DSweinhagen Samba Member
Joined: July 30, 2002 Posts: 382 Location: Phoenix, AZ
Posted: Mon Apr 19, 2021 8:53 am Post subject: Re: Melville Engineering steel and pipe 54' rhd single |
Hey Todd- The truck is looking great! Is anyone supplying the BD heater tube wrap or did you make your own? _________________ David S |
