Posted: Sat Jul 23, 2016 5:55 pm Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! |
curtp07 wrote: |
I'm horrified by that video. And to think I just spent days replacing every fuel line, vacuum line and a completely new FI harness with a fuse circuit and I'm STILL not satisfied.
Someone needs to find that poor bus and steal it NOW! |
They need to tow it if they are going to steal it. It would be suicidal to just drive off with it. |
curtp07 Samba Member
Posted: Sat Jul 23, 2016 8:41 pm Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! |
Tow..good point! Can't believe they drove the thing....overheated...yea. _________________ Subaru |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9620 Location: Western WA
Posted: Fri Oct 21, 2016 9:37 am Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ |
Sadness on the roadside last nite. Drove by it this morning east of Cle Elum, WA.
....KTMs, GasGas, SPOT mtb |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Fri Oct 21, 2016 9:51 am Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ |
Bummer - wonder who it was - Its not yours is it? You're a Vanagon guy? _________________
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Sodo Samba Member
Posted: Fri Oct 21, 2016 10:17 am Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ |
Nope, just drove by it, moment of silence, took pics. _________________
timvw7476 Samba Member
Posted: Fri Oct 21, 2016 11:55 am Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ |
Let's hope they got out with their wetsuits unburned. |
Posted: Fri Oct 21, 2016 12:44 pm Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ |
timvw7476 wrote: |
Is there a sweet surf spot in Cle Elum Im unaware of _________________
t3kg wrote: |
1964 1500 S
chabanais Samba Member
Posted: Fri Oct 21, 2016 12:46 pm Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ |
timvw7476 wrote: |
This is sad any way you slice it.
Thanks for posting the photos as a reminder. _________________ "I spud therefore I yam." |
wcfvw69 Samba Purist
Posted: Fri Oct 21, 2016 1:37 pm Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ |
Man, sure a lot of type 4 powered buses going up in flames. Simply scary stuff. Super bummer this happened. I may have to crack my wallet for a blaze cut on my type 1 just because... _________________ Contact me at [email protected]
The Samba member since 2004.
cmonSTART Samba Member
Posted: Fri Oct 21, 2016 1:52 pm Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ |
Wow, the whole fan housing disappeared.. those are Magnesium, right? _________________ '78 Bus 2.0FI
de K1IGS |
dabble Samba Member
Joined: April 21, 2004 Posts: 271 Location: Olympia, Wa
Posted: Fri Oct 21, 2016 2:17 pm Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ |
Bummer. Looks like they didn't have a fire extinguisher to stop it from taking the whole bus down.
_________________ 1973 Westy with a 78 FI 2000cc
[url=http://www.vw-mplate.com/mplate2-9157.png]Click to view image[/URL] |
Posted: Fri Oct 21, 2016 6:51 pm Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ |
Bailing wire and plumber's tape. Just the things I always look for when looking to find a well maintained ACVW. |
Posted: Fri Oct 21, 2016 7:44 pm Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ |
Around Washington, you get several years from fuel lines till they become
bonafide fire hazards.
It's rather amusing, (until it's not) - fuel reformulations seem to be the one
thing that can kill these beasts.
My wetsuit comment was tribute to the Bus Bears, maybe they can re-make
that sequence to include swapping your fuel lines every 3-7 years, or risk bursting into flames at any moment. |
clicknathan Samba Member
Posted: Tue Mar 21, 2017 9:51 am Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ |
I purchased fuel lines from Bus Depot, this stuff: https://www.busdepot.com/N0202811
Can I use this to replace the metal line beneath my bus / outside of the engine compartment.
I'm specifically speaking of the long piece of metal tubing that more or less runs from the tank to the filter & fuel pump. Mine is quite rusty. Any problem with using that hose / fuel line from Bus Depot under there as well? |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Tue Mar 21, 2017 3:29 pm Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ |
clicknathan wrote: |
You talking of the evaporative line/s? _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
airschooled Air-Schooled
Posted: Tue Mar 21, 2017 3:36 pm Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ |
udidwht wrote: |
You talking of the evaporative line/s? |
I think he means the suction line from the tank to the FI filter, then the pressurized line from the pump to the firewall/bulkhead passthrough. I've seen some VW assemblies that used metal hose there, and some where the owner used all rubber.
If the line is pressure and ethanol rated, (Gates Barricade is 225psi rated,) the metal fittings are flared & clamped, and the rubber hose is insulated from chafing and absolutely not allowed to rub on anything sharp (like a tin passthrough without a grommet) I suppose you could use it. But I don't know about the quality of the line.
www.airschooled.com |
Posted: Tue Mar 21, 2017 3:52 pm Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ |
asiab3 wrote: |
udidwht wrote: |
Robbie |
A great mod for the firewall is to use lamp hardware (brass) an create a pass thru in the firewall for the hose to pass thru. _________________ 1972 Westy Hardtop/Type-4 2056cc
71mm Stroke
Bosch W8CC plugs
3 rib 002 Trans
Posted: Tue Mar 21, 2017 6:22 pm Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ |
asiab3 wrote: |
If the line is pressure and ethanol rated, (Gates Barricade is 225psi rated,) the metal fittings are flared & clamped, and the rubber hose is insulated from chafing and absolutely not allowed to rub on anything sharp (like a tin passthrough without a grommet) I suppose you could use it. But I don't know about the quality of the line. |
Thank you. My set up is:
1. Tank has metal "hose" coming out
2. Rubber hosing goes from that to this piece of metal tubing, which more or less goes straight to the fuel filter, which is located near my rear driver's side wheel (I've heard reports this is sometimes up near the front in other models)
3. From the piece of metal tubing then rubber continues the rest of the way, to the filter, filter to pump, pump through firewall to another metal tube inside, to more rubber.
I've also got a bunch of protective plastic sleeve for where it goes through the firewall and other areas it might rub.
Normally VWs have rubber fuel lines the whole way? |
aerosurfer Samba Member
Joined: March 25, 2012 Posts: 1602 Location: Indianapolis, IN
Posted: Wed Mar 22, 2017 7:04 am Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ |
asiab3 wrote: |
All your questions with schematics can be found here:
http://ratwell.com/technical/FuelHoses.html
Click on the different years just below the top section for the differences in fuel hose schematics _________________ Rebuild your own FI Harness..My Harness
77 Westy 2.0L Rockin and Rolling Resto!
72 Sportsmobile (sold)
79 Tran$porter... Parts car money machine (gone) |
Posted: Wed Mar 22, 2017 7:17 am Post subject: Re: Up in smoke... Bus fires... don't let it happen to you! FAQ |
aerosurfer wrote: |
I had seen that, but was curious as it doesn't show several things, such as the cold start valve, Aux Air Regulator, ... That Ratwell page is quite useful, though.
More than that, though, it doesn't mention if the metal pipe / tubing is okay to replace with rubber.
I have everything to replace basically the entire FI system short of the injectors themselves & the cold start valve, and given the corrosion / rust on my "tank line" as the Ratwell site calls it, I thought replacing it might be the way to go while I'm already getting gas inevitably in my eyeballs anyway. |
