chrisradioman Samba Member
Joined: September 20, 2007 Posts: 4873 Location: Swansea (Sunny Penllergaer) Wales UK
NASkeet Samba Member
Joined: April 29, 2006 Posts: 2958 Location: South Benfleet, Essex, UK
Posted: Wed Dec 05, 2007 7:25 am Post subject: VDO Placement? |
nvwainfo wrote: |
mine uses the stock sender for the idiot light, with a couple of minor alterations via some brake fittings from the local auto parts store, the oil pressure is right on the money, oil temp is going to be a little on the low side on the gauge, but is a good ball park.
sender i am using for temp came with the gauge, the oil pressure is aftermarket, as the porsche 914 one seemed to have a higher minimum pressure then stock vw |
It would be interesting to determine, just how much lower the indicated temperature is, below that of the true oil temperature. The oil in that adapter is virtually static, so it would respond extremely slowly, to any change in the temperature of the oil being circulated.
That oil-temperature, gauge-sender, with 6·3 mm (i.e. ¼-inch) diameter button terminal, looks similar to two VDO 50~150ºC, oli-temperature, gauge-senders:
VDO part No. 323.801.009.003 – M10 x 1·0 taper thread
VDO part No. 323.801.010.001 – M10 x 1·0 parallel thread _________________ Regards.
Nigel A. Skeet
http://www.vwt2oc.net |
Randy in Maine Samba Member
Posted: Wed Dec 05, 2007 8:01 am Post subject: |
If you are trying to come up with even a remotely accurate oil temperature, do not put it there. |
Desertbusman Samba Member
Posted: Wed Dec 05, 2007 11:37 pm Post subject: |
Installing the sender there is probably giving you a more accurate reading of the combined engine case and engine compartment temperatures than it is of the oil. _________________ 71 Superbug
71 Westy |
Tri-Bus Samba Member
Joined: November 29, 2005 Posts: 732 Location: Butler PA
Posted: Thu Dec 06, 2007 9:28 am Post subject: |
Ok, would i rather have it in the case? yes.
Is it better then nothing? yes.
Does it give me a ballpark figure? yes
If somebody has a better way to do it that does not involve pulling the engine and having a machine shop tap the case, or involves sometype of a bolt on that would eliminate the need for machine shop work.
It is in a 2.0 litre type-4 motor in a 73. |
busdaddy Samba Member
Posted: Thu Dec 06, 2007 9:54 am Post subject: |
Suggestion:
Just put the OT sending unit in the taco plate on the underside. You need to dirill a hole in the taco plate and "JB weld" a nut on the inside or braze a 1/8 NPT nipple on the inside and thread the sender up through the hole.
Better than using the OP sender hole.
Looks something like this (from Whip618)....
Posted: Sun Dec 30, 2007 6:45 am Post subject: Substitute GRP dashboard, for 1968~79 VW Type 2 |
Rivierra Roof Company, Old School GRP Dashboard for 1968~79 VW Type 2, shown installed in a 1973~74 VW Type 2:
http://www.riveria-roof-company.co.uk/dashboard_oldschool.html
Note the enlarged vertical section at the bottom, where the dashboard switches and ashtray would fit. It's large enough to accommodate a DIN-E radio, radio/cassette player or radio/CD player, so leaves lots of space on the main part of the dashboard, to fit gauges, warning-light clusters and other items.
http://www.riveria-roof-company.co.uk/dashboard_unit1.html
Customisable Dashboard £145
Available in white primer finish, the dashboard unit allows you to
cut holes to your own configuration for all your dials, clocks and switches etc.
Here's a contact telephone number, for enquiries and pricing, found in the GRP bumper's section and order section:
Max Hanson, Riviera Roof Company
e-mail: [email protected]
Tel (from within UK): 01474 359 924
Tel. (from outside UK) +44 1474 359 924 _________________ Regards.
Nigel A. Skeet
JMazier Samba Member
Joined: February 20, 2006 Posts: 900 Location: In my garage, Georgetown, Ontario, Canada...
Posted: Sun Dec 30, 2007 7:46 am Post subject: Re: Substitute GRP dashboard, for 1968~79 VW Type 2 |
NASkeet wrote: |
Note the enlarged vertical section at the bottom, where the dashboard switches and ashtray would fit. It's large enough to accommodate a DIN-E radio, radio/cassette player or radio/CD player, so leaves lots of space on the main part of the dashboard, to fit gauges, warning-light clusters and other items. |
Nigel,
That is a beautiful thing! I really like that look! The web site however leaves something to be desired as I could not find any pricing or contact information... I will do some Google searches.
Found it! http://www.riveria-roof-company.co.uk/
Thanks for posting it! _________________ Cheers!
Jérôme
’79 Cali Westy 2.0 F.I.
'74 Honda CB 350 Four
'78 Honda CB 750 K
'12 Golf GTI
'11 Ural Patrol |
CHARLES JETT Samba Member
Joined: March 24, 2006 Posts: 115 Location: ORANGE PARK FL.
Posted: Sun Dec 30, 2007 12:15 pm Post subject: 1971 Bus Pictures |
Here is my 1971 dash.
Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Sun Dec 30, 2007 12:30 pm Post subject: Re: 1971 Bus Pictures |
CHARLES JETT wrote: |
That's a clean job, can you tell us more about these gauges & indicators and their functions? _________________ www.zwerks.ca |
Bleyseng Samba Member
Posted: Sun Dec 30, 2007 12:54 pm Post subject: |
nvwainfo wrote: |
breadloafdeluxe wrote: |
CHECK OUT PHOTOS OF MY 71 W 914 GUAGES AND VDOs UNDER THE RADIO IN THE GALLERY UNDER BREADLOAFDELUXE |
available for the 914 combo gauge is the triple combo which includes the gas gauge, oil pressure and oil temp using 911 gauge pods. _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Posted: Sun Dec 30, 2007 7:41 pm Post subject: 71 bus dash |
Mark, The gauges are all stock VDO and a Audiovox Cruise Control. The gauge panel is aluminum powdercoated semi-gloss black. The dash was sandblasted and powdercoated Black Krinckle finish. The two green lites are for left and right blinkers. The blue lite is for high beam and the red ones oil pressure and alt. After two years and a lot of inspiration from you guys on Samba, I am almost through. |
dwill49965 Samba Member
Joined: August 08, 2005 Posts: 1396 Location: Dartmouth, Nova Scotia
Posted: Mon Dec 31, 2007 7:44 am Post subject: |
Wow Charles, that looks really nice and professional. _________________ Darryl
'78 Westy, Boston Bob built 2.0 L, FI, MSD 6A
Meyer wrote: |
Lastly, you just referred to US citizens as 'Americans'. Exactly what kind of Canadian are you? From what continent? |
Posted: Mon Dec 31, 2007 7:52 am Post subject: VDO Placement? |
Please note that I have updated my earlier post about the Riviera Roof Company's 1968~79 VW Type 2, "Customisable" and "Old School" GRP dashboards, including a contact telephone number and e-mail address.
I also like the appearance of your replacement, aluminium instrument panel, but I'm surprised that it accommodates so few gauges!
Is the panel flat, with a gap behind it, rather than curved to follow the profile of the steel dashboard.
Instead of using individual warning lights, I would be inclined to use a customisable, Lucas Industries, 60 mm diameter, 8-segment warning-light cluster, as illustrated in one of my posts, in the general-purpose parts & accessories section, of The Samba forum.
The handbrake's triangular trim panel looks neat, which regretably, all the British specification, 1968~79 VW Type 2s seem to lack, my own included! I would like to obtain one, along with the handbrake warning-light switch and associated parts, but I haven't seen any advertised yet.
I notice that one possible upgrade, you have yet to implement, is the substitution of the matched pair, of steering-column mounted, 1973~74 VW Type 2, stalk switches, for windscreen wiper & washer, plus turn-signals, headlamp dip & flasher. You could then retain your existing dashboard mounted windscreen wiper & washer switch, for a rear-window wiper & washer system.
Nigel A. Skeet
Posted: Mon Dec 31, 2007 4:44 pm Post subject: |
NASkeet, While the alum panel is flat, the edges are folded back 3/8 " and each end is radius to fit the dash . There is no gap. I will change the warning lites to something not so plain later, after two years, I just want to drive it. dwill49965, it means a lot that you guys like the results of a lot of work and it ain't bad for a southern boy. NASkeet, I might have a handbrake trim piece if you need it. Thanks for the kind comments guys. |
Posted: Wed Jan 02, 2008 8:37 am Post subject: VDO Placement? – 8-segment warning-light cluster |
NASkeet wrote: |
Instead of using individual warning lights, I would be inclined to use a customisable, Lucas Industries, 60 mm diameter, 8-segment warning-light cluster, as illustrated in one of my posts, in the general-purpose parts & accessories section, of The Samba forum. |
Here is the link to my posts about Lucas Industries, 60 mm diameter, 8-segment warning-light cluster:
http://www.thesamba.com/vw/forum/viewtopic.php?p=2731656#2731656 _________________ Regards.
Nigel A. Skeet
theizzardking Samba Member
Posted: Fri Jul 11, 2008 12:39 pm Post subject: Re: VDO Placement? |
[quote="nvwainfo"]
NASkeet wrote: |
nvwainfo wrote: |
hey what normally sits in the gauge spot on the far right? mine has some wierd blank thing with strange lines radiating from the center, i don`t know what it does and i fear the day it does do somthing! please tell me! thanks! |
Posted: Fri Jul 11, 2008 1:02 pm Post subject: Re: VDO Placement? |
[quote="theizzardking"]
nvwainfo wrote: |
NASkeet wrote: |
nvwainfo wrote: |
optional clock
