virtanen Samba Member
Joined: January 08, 2006 Posts: 1461 Location: Finland
thom Samba Member
Joined: October 12, 2000 Posts: 5943 Location: Sacramento
Posted: Tue Nov 27, 2007 7:58 am Post subject: |
Good deal; I should buy them just to have on hand!
A while back, I needed 1st-over bearings for my ghia's engine. I posted a wanted ad, and a helpful gent replied: he wanted $350 for the engine bearings, and would cut me a deal of $150 for a set of rod bearings. _________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
VWwerks Samba Member
Joined: March 07, 2002 Posts: 207 Location: Wisconsin
Posted: Tue Nov 27, 2007 8:39 am Post subject: |
They look like standard bearings to me? |
Posted: Tue Nov 27, 2007 9:19 am Post subject: |
Look at the label, + Ø 0.5 that means for 0.50 mm over size bored case. I have similar set and I have measured it. |
HeSa Samba Member
Joined: January 15, 2007 Posts: 466 Location: FINLAND
Posted: Tue Nov 27, 2007 1:04 pm Post subject: |
thom wrote: |
A while back, I needed 1st-over bearings for my ghia's engine. I posted a wanted ad, and a helpful gent replied: he wanted $350 for the engine bearings, and would cut me a deal of $150 for a set of rod bearings. |
All possible sizes of 25/30bhp main bearings have been available from cip1 for a while now for 69,95USD. |
Posted: Tue Nov 27, 2007 1:42 pm Post subject: |
HeSa wrote: |
Are they old German made or some others? |
52HoffmanSplit Samba Member
Joined: April 07, 2006 Posts: 1272 Location: Lamorinda CA
Posted: Tue Nov 27, 2007 2:13 pm Post subject: |
virtanen wrote: |
Beg to differ... This means... STD Case and .020 Crank (0.50)... these aren't align bore bearings....... _________________ DB
9/1950 Hoffman Standard
11/1966 Porsche 912
10/1966 Porsche 912
7/1968 Type 265 Double Cab
10/1958 Type 117
Last edited by 52HoffmanSplit on Wed Nov 28, 2007 8:31 am; edited 1 time in total |
Posted: Tue Nov 27, 2007 2:17 pm Post subject: |
bump _________________ DB
11/1966 Porsche 912
10/1966 Porsche 912
10/1958 Type 117
commercial air Samba Member
Joined: July 19, 2005 Posts: 230 Location: Driving in the crumple zone...Regina, Saskatchewan, Canada
Posted: Tue Nov 27, 2007 3:11 pm Post subject: |
HeSa wrote: |
This is a misconception. CIP does not carry first cut align bore bearings(.25). The list starts at 2nd cut(.50) and they only offer oversized thrust in .50/.50 spec bearings. It is nice that some are now available though.
Chris _________________ Northern United Transporter Society
www.nuts.commercial-air.com |
Posted: Wed Nov 28, 2007 1:25 am Post subject: |
VW made only +0.50 mm case align bore bearings (based on Spare part catalogs).
I have measured the similar Glyco set, and it has outer dia 60.50 mm. |
Posted: Wed Nov 28, 2007 1:56 am Post subject: |
virtanen wrote: |
Here is a set of Repco bearings, that I have, that are +.25mm/-.25mm with oversized thrust.
Thanks for the tip on the bearings. Thom is right again. They would be good to have on hand.
volksworker Samba Member
Joined: October 30, 2004 Posts: 309 Location: Arizona
Posted: Wed Nov 28, 2007 8:05 pm Post subject: .010 bearings |
Its true that VW didnt make .010 or .25mm align bore bearings but as you can see Repco did. The only reason that they did is that 2 or 3 of the 4 bearings in the set were already in production as std size bearings for early Porsche. I dont know of any other manufacturer that made .010 align bore bearings. If I remember right the repcos were made in Australia. I worked at a Repco WD for 13 years.The Glyco box pictured above is definitely Standard crank, .020 case........which is the normal first cut. The Pre A and early A porsche guys covet the .010 [std for them]and .020 oversize. 6 months ago a fair price on a set of 36hp align bore bearings would be between 120 and 150.00 dollars....more for larger oversizes. I was just able to save a 25 hp with a .040 case , .080 thrust set of bearings that I have been saving for years. I stashed all of the sets in the 80s when no one cared, in fact my employer of the time gave me his entire stock. These larger sizes are the ones to look for as most 36ers [if they need it at all] need at least an .020 align bore and a slight thrust cut. Severely worn 36hp and pre a motors can be saved with them. I custom cut the thrust bearing for just the amount it takes to clean the case up allowing for another cut or 2 in another 50 years......... _________________ Tom
67 Porsche 912 Bahama Yellow
68 Crew Cab Transporter
73 Thing original
57 MGA 1500 Coupe
71 K20 Suburban 3dr |
Posted: Wed Nov 28, 2007 9:19 pm Post subject: |
Thank you very much for that information. Because I've had Repco .25 align bore bearings in the past, I've always wondered why I hadn't seen any from other makers. I guess that clears it up.
Posted: Wed Nov 28, 2007 10:38 pm Post subject: Re: .010 bearings |
volksworker wrote: |
Its true that VW didnt make .010 or .25mm align bore bearings but as you can see Repco did. The only reason that they did is that 2 or 3 of the 4 bearings in the set were already in production as std size bearings for early Porsche. I dont know of any other manufacturer that made .010 align bore bearings. If I remember right the repcos were made in Australia. I worked at a Repco WD for 13 years.The Glyco box pictured above is definitely Standard crank, .020 case........which is the normal first cut. The Pre A and early A porsche guys covet the .010 [std for them]and .020 oversize. 6 months ago a fair price on a set of 36hp align bore bearings would be between 120 and 150.00 dollars....more for larger oversizes. I was just able to save a 25 hp with a .040 case , .080 thrust set of bearings that I have been saving for years. I stashed all of the sets in the 80s when no one cared, in fact my employer of the time gave me his entire stock. These larger sizes are the ones to look for as most 36ers [if they need it at all] need at least an .020 align bore and a slight thrust cut. Severely worn 36hp and pre a motors can be saved with them. I custom cut the thrust bearing for just the amount it takes to clean the case up allowing for another cut or 2 in another 50 years......... |
Thanks Volksworker..... and the 25hp runs just fine.. Lots of power.... I stand corrected.. they are align bore bearings... I am ashamed..but the box threw me.... I defer to my brothers vast knowledge. _________________ DB
11/1966 Porsche 912
10/1966 Porsche 912
10/1958 Type 117 |
Posted: Thu Nov 29, 2007 5:15 am Post subject: |
As you might know the other possibility to rework the engine case is to make surface cut between the case halves. It can also make only right side half of the case. Normally cutting total 0.30 mm. After cut, all bores is aligned to be STD size. Then is possible to use bearings of overdia STD size and cam boring coming new again. Trust bearing is changed to thicker one and case cut according it.
I just made that for my April 1951 case. Nice to have new cam bore. |
Posted: Thu Nov 29, 2007 10:13 am Post subject: |
Machining the case half is an option and I will do it if the cam bore is bad. However since the cam bore is rarely worn past specs on a 36 it usually isnt necessary. Now, when they went to 40 hp and increased valve spring pressure and redsigned the lifter bores , cam bore wear became a problem.[which is why 40hps always suffer from flickering oil light syndrome] VW adressed this by machining 40hp cases for cam bearings. I certainly would not use the planing method if I could use oversize mains as it does change the actual width of the motor. Its also a one time process and wont clean up a really bad case like the one I just saved. If I remember correctly you have to remachine the flywheel seal and cam plug bore also which is very tedious. I guess the point is you have to measure and check cam bores for wear and know the facts. VW used that method in their case rebuilding program so its certainly an option. However few cores met their tough specs and they discontinued the program in like 72. The thrust is still not addressed without an oversize thrust bearing but its nice to know you can save a bad cam bore case with that method. Its interesting to note that VW never sanctioned any remachining of their engine cases untill very late on using align bore equipment. I wonder who actually introduced the align bore bearings to the market? ......It may of been Repco that actually marketed those oversize bearings first.........anyway..........40 bucks for 25/36 hp align bore bearings is a great deal.................... _________________ Tom
73 Thing original
57 MGA 1500 Coupe
sgmalt46 Samba Member
Joined: April 20, 2005 Posts: 1293 Location: south san francisco
Posted: Thu Dec 06, 2007 9:40 am Post subject: |
i've got .10 line bore bearings in glyco' k/s 'and metal leve. who say's only repco made them? my 2 cents
steve |
Posted: Wed Jan 09, 2008 3:05 am Post subject: |
Here pictures of my engine case after seam cutting. 0.30 mm machined on the right side case. All bores machined to STD size. Fitted special VW NOS repairing fly wheel end bearing for axial wear of the case.
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3776 Location: Twin Cities, MN
Posted: Sun Sep 08, 2019 3:48 pm Post subject: Re: Engine main bearing set for line bored case |
Where is a good place to find 36hp bearings these days? It seems all the usual vendors are out of the size I need.
STD crank and 60.50mm /.020" (first cut) on the case.
Also am I correct in thinking the part number for these is 111 198 451? |
Posted: Sun Sep 08, 2019 10:09 pm Post subject: Re: Engine main bearing set for line bored case |
111 198 451 is std case. std. crank. you need 111 198 451/50 . cip1 shows they have them. _________________ 55 deluxe 23 window bus
64 crew cab
55 rag top beetle
66 beetle
71 square back (sold) ! good luck with it Henry!
46 beetle 552nd royal army service corps CCG |
