pewe_kodok Samba Member
Joined: October 15, 2006 Posts: 64 Location: Bandung, West Java, Indonesia
Posted: Mon Dec 03, 2007 8:46 pm Post subject: brake line and master cylinder |
peeping master cylinder under the front hood, and start questioning...
fyi I get dual circuit master. btw sorry for incorrect term I used
1. how brake line bolted on the master cylinder?
2. I saw front circuit bolted 2 line. One for right and other for left.
rear circuit only 1 line go to the rear and chocked other port (by bolt).
after read bentley, brake master has residual port (cmiiw). so front circuit only 1 line and split by tee line.
it is correct?
take a ride (around 600 km round trip) last weekend. When brake it hard, thing will steer left. |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Mon Dec 03, 2007 9:33 pm Post subject: |
If it pulls hard to one side then you should look at your wheels first. Check the adjustment of your brake shoes and the wheel cylinders- then move on to the master cylinder. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Tue Dec 04, 2007 1:49 am Post subject: |
There should be 2 lines going to the front wheels, and only one line giong to the rear. At the rear, there is a "T" piece, that splits to each of the rear wheels.
The bolt you see in the master cylinder, is not a plug, but is there to hole the interal parts of the master cylinder in the proper place. Do not remove this bolt unles you are rebuilding the master cylinder. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Tue Dec 04, 2007 1:34 pm Post subject: Re: brake line and master cylinder |
pewe_kodok wrote: |
I agree with Crofty, but will add the the likely problem is the flexible brake line on the right front wheel. The lines often swell shut. _________________ VW-181 shirts and stickers.
http://ian.epperson.com/vw |
uberautowerks Samba Member
Joined: October 17, 2005 Posts: 1600 Location: Longmont Co
Posted: Tue Dec 04, 2007 5:54 pm Post subject: |
Check for play in your tie rod too! A worn out tie rod end can cause pulling under braking. _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black) |
