Posted: Mon Jul 24, 2017 7:01 pm Post subject: Re: Westy rack differences |
what year is this rack and is it made by Westfalia?
1)The rack has boxed bows like early racks
2) large feet with ribs
3) clamp with ribs and high screw location
4) one screw from wood to bow.
I looked at all the racks on the samba and can't find one like this. |
HappyTheMan Samba Member
Posted: Tue Sep 12, 2017 12:43 pm Post subject: Re: Westy rack differences |
When restoring an original rack, should the legs and clamps be hot dip galvanized or electroplate galvanized? |
otahuhu Samba Member
Posted: Tue Sep 12, 2017 2:46 pm Post subject: Re: Westy rack differences |
Originally, 100% definitely electro galv not hot dip. |
Posted: Wed Sep 13, 2017 11:50 am Post subject: Re: Westy rack differences |
otahuhu wrote: |
Okay, thanks. I've looked into it a little bit and information out there says the electroplating is much thinner than dipping. So, looking at the legs what you say makes sense. I've also read that it doesn't weather well, as in more prone to rust. Still, the legs don't show much sign of that. The clamps do though. Do you think car wax or something would help with that?
I have some remnants of the rubber stuff attached to the clamps (#24 in the drawing shown earlier). Anybody find material close to the original? It seems to be like a closed cell foam type of rubber. Mine are black (it's a 59 rack). |
broozebrothers Samba Member
Joined: June 02, 2008 Posts: 297 Location: Los Angeles
Posted: Wed Sep 13, 2017 10:12 pm Post subject: Re: Westy rack differences |
crofty wrote: |
easy e wrote: |
Yes, slope has taller legs in the front... and shorter in the rear.
A non-slope follows the line of the drip rail.
That's actually a '62 only rack that has all three legs made from the rear leg of a sloper rack. |
I have one of these 62 only racks ,, has all 3 small bows from a sloper rack without reinforcements on the corners , 61 sloper style clamps and 1 tag .. only seen one other , the one on that very bus .. |
Skim Rants Master
Joined: April 15, 2001 Posts: 17082 Location: GFK 31 Year Vet
Posted: Sun Nov 19, 2017 9:58 pm Post subject: Re: Westy rack differences |
My westy rack came with four of these aluminum plates between the slats. Does anyone know what they were for?
_________________ GFK
1953 Kabriolet
1954 Sunroof
1959 Lowlight Ghia vert
1963 Deluxe Turkis Walk Thru 15 Window OG Paint |
GLHTurbo Samba Member
Joined: March 30, 2009 Posts: 1376 Location: New Jersey
Posted: Mon Nov 20, 2017 3:01 am Post subject: Re: Westy rack differences |
Looks like small L-track pieces for cargo control/tie downs. Google L-track and you can see what I man. _________________ 1957 Beetle
1966 Bus |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Nov 20, 2017 9:38 am Post subject: Re: Westy rack differences |
GLHTurbo wrote: |
Looks like small L-track pieces for cargo control/tie downs. Google L-track and you can see what I man. |
^^^ As you know- you hit it on the head. Perhaps the rack's owner did not want to add pulling stress to the side rails. By concentrating the pull on four corners (I'm assuming) it probably helped that rack last a lot longer than many. Pretty smart, and kinda stealth. _________________
EverettB wrote: |
FU#5 |
folks55 Samba Member
Joined: August 30, 2008 Posts: 894 Location: High Desert Ca
Posted: Sun Dec 03, 2017 11:04 am Post subject: Re: Westy rack differences |
Followed a lead about some VWs stored away for years. Looks like a couple of cool racks there too
oakman Samba Member
Joined: February 05, 2014 Posts: 1715 Location: Edge of the Desert, Ca
Posted: Sun Dec 03, 2017 11:58 am Post subject: Re: Westy rack differences |
folks55 wrote: |
Damn dude! _________________ Brandon |
Posted: Fri Dec 29, 2017 1:48 am Post subject: Re: Westy rack differences |
oakman wrote: |
folks55 wrote: |
Damn dude! |
Lucky I suppose right. I needed the rack with the 2 screws at the end of the wood for my bus is Feb 60. Hopefully I'll be bringing it home really soon. |
vworwhat Samba Member
Posted: Mon Jan 15, 2018 8:03 pm Post subject: Re: Westy rack differences |
After a 3 years hunt I finally found a set of original westy clamps (cheers Tony) for my baywindow rack. All I need now is the right hardwear. Does anybody have pics and specs of the original bolts and nuts? Are they the same as for split - DIN 85, 50s style cheese head machine bolts and DIN 557 square brass nuts or is the baywindow hardware different?
_________________ Westfalia Helsinki 6/77
Winter bus 5/74
Earlybay 7 seater deluxe 11/69
Type3 9/63 1500N M264 panel |
easy e Samba Member
Joined: May 28, 2008 Posts: 3931 Location: 1 hr north of Santa Barbara
Posted: Mon Jan 15, 2018 9:04 pm Post subject: Re: Westy rack differences |
Well, I figured this is a westy rack thread, not so much an exclusive split westy rack one. I don’t know whether you have read it, but I have - and it contains quite a bit of information on baywindow westy racks, too. Some guys in this thread really know their way around this topic and have been of great help on my quest so far. Taken all that in consideration, I might have a decent chance to get the missing information on my baywindow rack in this thread.
But thanks, I will try the thread the in baywindow forum aswell! _________________ Westfalia Helsinki 6/77
Winter bus 5/74
easy e Samba Member
Posted: Mon Jan 15, 2018 9:47 pm Post subject: Re: Westy rack differences |
vworwhat wrote: |
I might have a decent chance to get the missing information on my baywindow rack in this thread. |
I agree... so started my last post with "if."
Just hoping you get the info you seek.
I imagine there is a fair amount of Bay + Split owners. _________________ aka: Evan
Searchable, click-navigable 1958 Bus Parts List |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Tue Jan 16, 2018 10:36 am Post subject: Re: Westy rack differences |
What exactly makes it Bay? |
Posted: Tue Jan 16, 2018 10:44 am Post subject: Re: Westy rack differences |
The size, slates are longer. The shape, its lower than split. The size of the clamps, they are larger than late split clamps. _________________ Westfalia Helsinki 6/77
Winter bus 5/74
Posted: Tue Jan 16, 2018 11:15 am Post subject: Re: Westy rack differences |
Any suggestions with regard to the proper hardwear for a bay rack? A mate has galvanized M6x30 machine bolts and wing nuts on his, they don’t quite look original though , but who knows. _________________ Westfalia Helsinki 6/77
Winter bus 5/74
easy e Samba Member
Posted: Wed Feb 21, 2018 11:57 pm Post subject: Re: Westy rack differences |
