HUGO bOSS Samba Member
Joined: April 27, 2008 Posts: 2602 Location: Madeira Island - Portugal
twokegger Samba Member
Joined: June 28, 2012 Posts: 69 Location: Ringgold, GA
Posted: Wed Aug 16, 2017 10:58 am Post subject: Re: My 63 Ragtop |
looking good man. keep it up |
63Ragtop NZ Samba Member
Joined: December 04, 2007 Posts: 895 Location: West Auckland
Posted: Thu Aug 17, 2017 10:04 pm Post subject: Re: My 63 Ragtop |
Thanks Guys, was trying to get it done for this month, maybe next month?
been focused on the engine for the last couple weeks.
dirty.
clean.
many thanks to Adrian who helped me rebuild and clean these 36's
back in the cave.
gave the heat exchangers a good de-grease.
they're pretty much worn out, but will do a few more miles/years, until I finally give up on this fantasy of having a working heater.(its never worked)
Alt stand and a very quick black paint job.
if you look back a couple post, you'll notice the fan shroud had two holes for the throttle cable, neither were in the right spot.
sorted.
terrible paint on this thing, ran out of primer, ah fuckit!
shiny!
sparky!
after spending a not insignificant amount of time cleaning up all the old, oil covered stainless tinwear screws,
I found these new button head ones, ah well! _________________ If you can't join them, beat them! |
Posted: Thu Aug 17, 2017 10:11 pm Post subject: Re: My 63 Ragtop |
fan stuff.
new oil cooler seals
so the fan housing could get bolted down now.
thinking about mounting the coil here.
on the top of the oil cooler scoop.
Posted: Thu Aug 17, 2017 10:13 pm Post subject: Re: My 63 Ragtop |
B6HS.
Hmmmmmmm.
that don't look right at all.
so I took it all back apart, double checked everything, took the Alternator off, put the gennie back on, still the same.
I think it's been like this for years, I blame the shitty aftermarket tinwear, the Alt can move back into the stand but the shroud and everthing thats bolted to won't let it, I even leaned on it and got a mate to tighten the strap, but that just made it crooked and out of alignment.
need more beer. _________________ If you can't join them, beat them! |
Posted: Mon Aug 21, 2017 10:58 pm Post subject: Re: My 63 Ragtop |
Carrying on,
we gonna rock down to electric avenue...
please please work!
spent several hours of my life making these air cleaner spacers.
now looking not quite as homemade, still need holes for studs on top of the crabs.
played mix and match with the fuel inlets on my old single dell, twins now both the same fittings with one side blocked off, so the line will come up though the firewall, to the left carb then over the the right hand side.
got the linkage working nice and fitted the sparkplug wires.
test fitting the old k&N off the single, new ones will be the taller ones I think.
so close! _________________ If you can't join them, beat them! |
Posted: Mon Aug 21, 2017 11:03 pm Post subject: Re: My 63 Ragtop |
sTRANGE bED FELLOWs.
our cars couldn't be any more different!
finished mounting the fuel line, ended up going under the throttle tube. mounted the coil on the cooler scoop, the extra weight makes the scoop flap about, might need a couple more screws to hold the scoop now
fitted up the crusty old heater boxes, so I could button up the tins. valve covers will be painted dark grey at a later date.
found these little RUBBER NIPPLES at pineline, that place has everything! these block the vacuum ports on the carbs, very handy for keeping you walrus protected also.
test fitted the old bugpack zorst, fuck it's shite!!
get in there ya wee bugger!! guess I'd better install the rear engine bay seal.
ah yeah.... _________________ If you can't join them, beat them! |
Posted: Sun Sep 03, 2017 10:45 pm Post subject: Re: My 63 Ragtop |
have hopefully fixed the worn out gas sender problem.
I have no idea how much gas I have, but the old gauge don't work anyway, I can just look down the filler neck and at least I can full'er up now.
And then as Sunday drew to a end...
dells seem to fit. oh man those manifolds are right bastards!
hooked up the throttle wire.
made brumbrum noises.
ust need to finish wiring and install electric fuel pump, K&Ns etc... _________________ If you can't join them, beat them! |
Posted: Sun Sep 03, 2017 10:50 pm Post subject: Re: My 63 Ragtop |
it's off the stands, ass starting to squat down.
lost that sweet rake it had, just need to drop the front another inch or two!
popped the muffler and rear valance on, easy.
looking good.
Darrell to the rescue again with his tiny little 1/4 inch socket set.
sorted those pesky manifolds out! wired up the coil, oil pressure sender, Alternator and spark plugs.
Should fire up now
spend a couple nights sorting out the fuel system at the front end, looped the line around to the front, through to the old washer bottle spot, which is now the fuel filter and pump spot, and back to the hard line under the tank.
I have had this set up in my head for a while now, I had even drilled the holes for the fuel lines, but no hole to mount the pump, drilling into my nice new paint fun! but at least gives a good earth, the power for the pump is for the moment hooked up to the spare radio fuse circuit, which is always live, which is not ideal.
Anywho.
rear bumper and mutherfucking number plate bitches!
legal beagle.
bumper rubbers not fitting all that great, will fit rubber first, then bumper when I next remove the muffler as the bumper mounts are a pig to get to with that big ass muffler in the way. So the correct process is Valance-Bumper-Muffler. reverse of the way I just did it.
time to fire it up. _________________ If you can't join them, beat them! |
Posted: Sun Sep 03, 2017 10:54 pm Post subject: Re: My 63 Ragtop |
I actually tried to fire it up last Friday night, but the second hand fuel pump out of Darrell's HZ Statesman, which I've had in a box for a few years, had died from natural causes.
I wasn't keen on changing all the lines and installing the factory pump, so I googled up the brand of the old pump and found they are a NZ company manufacturing these pumps in a Waihi,
95bucks delivered to my work yesterday, 5 o'clock couldn't come soon enough! I rushed home and mounted it up.
This is a 2psi low pressure pump for carbs, they do a 4psi 6si a 6volt version and 24 volts version.
I like it as it's small, in line, no regulator needed, and very quite.
So after battling to find a good earth I ended up using the screw that holds the left service cover thing on.
By now it was nearly ten at night but I've waited to long to let that stop me!
I took it for it's first wee drive up and down the street last night, woke up all the neighbours and stuck it back in the shed as no lights is a bit scary!
Darrel came up and we quickly realized the "to do" list is getting bloody small!
-lights
-seat belts
-4 wheel nuts
-brakes still spongy
-wipers
plus non wof things like air filters, sunroof etc...
so while we were on a roll we connected up the lights.
still no front indicators, but I'm sorting that out today.
moved the power for the fuel pump over to one of the only on when car is on fuses, indicators I think?
and holy shit! everything works! the wipers! both speeds!
the horn, everything!
can't believe it!!
even though it is technically running like a bag of shit, carbs need tuning/jetting/sync, brakes where scary bad and the steering felt heavy as(might have just gottin use to power/no tiny wheel) it was awesome!
I even gave it a bit of welly in second up the road and man, it wants to go!
:mrgreen: :mrgreen: _________________ If you can't join them, beat them! |
Posted: Sun Sep 03, 2017 10:58 pm Post subject: Re: My 63 Ragtop |
Now I did say I'd sort the indicators today didn't I.
got these off trademe for 20bucka, it did say mini LED indicators(mouse for scale)
The plan is to drill a hole in the headlight inner bucket thing, make them look like the US oval lights.
installed the tiny lights here.
added another nut to jam it in place and so the thread bit doesn't stick out to much
took the opportunity to replace the left chrome ring with a non dented one from my stash.
clean and polish everything.
the adjusters on the old ring were all lose and broken, so two birds, one stone.
looks pretty good.
tried to wire 'em up but no dice, I did get the left park light working just by fiddling around with the park light bulb and other wires, no such luck with the right hand side, bad earth I'm hoping?
i think I need a LED flasher unit?
also, proof it has been out of the shed.
all the neighbours came for a jack, colour looks different outside, got the carbs tuned a bit better, set the tappets, changed the oil, and then it wouldn't start.
faaarrk!
Posted: Thu Sep 28, 2017 8:51 pm Post subject: Re: My 63 Ragtop |
I got the battery hooked up good and it barely had enough juice to run the fuel pump.
Had it on charge all night will see if it works pretty sure it's FUBAR.
Lookie Lookie what turned up yesterday!
ah yeah.
was slightly worried they might not fit under the engine lid, my old single dell had the shorter 1inch filter which rubbed.
the 1-2 side is close but no touch
also had another play with the front drum adjusters and the pedal adjustment for 1/2 inch of free play,much better! still seems a bit soft and firms up after a pump but at least it's not hitting the firewall anymore. _________________ If you can't join them, beat them! |
Posted: Thu Sep 28, 2017 8:53 pm Post subject: Re: My 63 Ragtop |
Super frustrating as it was running and driving, warmed it up to change the oil and it's not been right since.Best I've got it to run it was only running on 3 and 4, 1 and 2 side felt cold still, or it wouldn't fire at all.
Went and got another set of spark plugs and a "big mother"of a battery.
Have had the carbs out and pulled apart twice, the accelerator pump jet on number one was blocked so that fixed that problem, also adjusted the float levels to spec, 5-6mm closed, 12-14mm open, i think it was.
started playing with the timing and got it to fire and run for a short time, but just as it was warming up it fell down to two cylinders and wouldn't start again.
have tried replacing the electronic points replacement module with the old points and condenser.
have tried other HT and spark plug leads.
got to the point last week that the new started now sounds like a chainsaw and the battery went flat again.
swapped the starter out last night for a old Bosch brazil 12volter and had the battery on charge all night and most of today.
Got another good distributor cap and rotor off Frank yesterday, got home from work tonight and got everything together, but had reinstalled the old leads.
the bugger started and sounded the best it had ever had, tightened the dizzy down, bumped up the idle stop had it idling pretty bloody well, got brave enough to try to drive it down to Darrell's house 50 mtrs away to check the alt is charging the battery and when i started it up after about the third attempt it was back to two cylinders, farting and hicupin and now it wont start again'.
Have been trolling thesamba and found a page with a guy having the exact same issue's, he ended up buying new everything which didn't solve the problem until he moved some wires about, thinking about it now, I've routed my leads though the middle of the manifolds under the carbs because its tidy and looks neat, could this be causing problems? the leads are old after sitting in my shed for nearly ten years but not 40 years old or anything. _________________ If you can't join them, beat them! |
Posted: Thu Sep 28, 2017 8:58 pm Post subject: Re: My 63 Ragtop |
so, were was I? ah yes friday. I phoned around a few places and found Autostop are the only people that carry Bosch car parts these days, asked about a GT40T (for transformer) coil, no worried the helpful young man said, I 'll ring ya back once the van drops it off, sorted. at about noon the guy rings me back, the coils here in the local shop, but for some reason I double checked, it is the small square one right? no its the round cylinder one, doh! no worries he assures me, I'll get it on the next van, I get another call at about 3, square coil is here, sweet! so I bunk off work early as I have the wifes car for the day to go and pick it up, get home on the double time just as Darrell does and we install the new one and she fires straight up!
Once I got the old coil out it was obvious it had see better days, but in my defence most of that great crack was hidden from view under the mounts, and I was more worried about the clutch and piston rings still working etc..
all this pissing about with the coil had at least given me time to sort a few other small but important things.
these are my jets.
as I said in the earlier winge post everything has been checked and double checked, which does at least give me more confidence in the old girl.
gave the last few parts of the sunroof mech a lick of paint and duct taped the old cover on for now.
water tight bug
which bring us back to friday night and a for the first time a running car. First job, wash all the dust and cat paw prints off it.
jeah.
stood back enjoyed a beverage until it was nearly dark.
once the kids were in bed and I'd realized the only things stopping a wof was a front number plate, wipers and them brakes, or lack there of. I then remembered I hadn't yet had another go at adjusting the rear drums and noticed when I pulled the handbrake on, I had a good pedel, hmmmm.
Sure enough they were miles out, whats next? wipers and a plate? might as well keep going!
I have some how amassed quite a collection of wiper arms and blades over the years and so had a nice working matching pair, something else new of this car, polished up the old black plate, so many battle scars, but I love it.
By now its 11.30, fuck it, I'm going for a drive!
:mrgreen:
now it get this thing legal.
I have however driven it on private roads and those twin carbys have transformed this car into a bit of a beast.
that little 1600 feels like it wants to rev to the moon! still needs a bit of work on the timing and jetting, but dear god it pulled 50mph in second gear today! a little bit scary with drum brakes!
so friggin loud though, no headlining at all, my brother said after I took him for a wee blast, it like sitting in the engine bay!
it kind of hard to drive normal as it so much fun to wind out. _________________ If you can't join them, beat them! |
Posted: Thu Sep 28, 2017 8:59 pm Post subject: Re: My 63 Ragtop |
Went for another wee spin last night, found a dark wall and adjusted the headlights, so now they point at the road, not the sky. Also adjusted the steering box, feels much better, just needs alignement me thinks, still a bit vague and twitchy. Rear end feels good, amazing how much of the road surface transfers though the car, from the rear end it would seem, might be the ride height I guess
AZOffTheWall Samba Member
Joined: December 27, 2012 Posts: 209 Location: Arizona
Posted: Mon Oct 23, 2017 9:06 pm Post subject: Re: My 63 Ragtop |
Cheers AZ, I friggin love it!
But...
Been have been having a nightmare getting this thing legal, Drove it to work a couple weeks back as I was feeling to weak with a headcold to ride my bike anymore, Knocked off early and went to see Frank at the local vw workshop, but he had staff off sick also and was flatout himself. So I rolled the dice at a nice looking garage across the road from work for a WOF.
I didn't want to leave my baby with any fuckwit or some young guy who wouldn't even know how to drive a real old car, this guy has been in the trade for nearly 30 years and use to own/work on bugs back in the day, Sorted.
Or so I thought, it failed, which I was fully expecting, as the brakes are not great and the rear tyres are old,hard and nearly bald. But it didn't fail on any of those things, there were a few small things like rear seat belts are old and one won't adjust, somehow though the rear tyres past and the front one didn't because apparently they are full on drift spec stretched tyres, ie to narrow for the rims and the real kicker the chassis number doesn't match the paper work, this was something I've always know about, this car is build from about 12 bugs, but no one has ever worried or picked up on it before, so I was off to the vtnz, handly just up the road also, filled out MR16 change of reg details form, waited a week, computer says no. can't just be swapping chassis numbers around I guess.
So now I'm waiting again for the faceless bureaucrats to rubber stamp me a new VIN number and I should be good to go! still need to sort a couple small things but tyres really piss me off,I looked up the rim size they fit on(145.65.15) a smart car and it's 5inchs, these mags are 5.5inch, that an't stretched fuck all and in my opinion, the rear tyres are more dangerous as most of the vehicles weight is on the rear.
rant rant ranty rant, I know the guy is just doing his job, but I'm running out of energy at this point.
anyway as our recently departed friend Mr Petty sang, Waiting is the hardest part.
so I didn't
rush hour still sucks
