crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Wed Dec 05, 2007 1:52 pm Post subject: What's your MPG? |
Mine is not too impressive at around 15mpg with a 34-3 and a SVDA 034 on a 1600 dual port. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
GSD_Master Samba Member
Posted: Wed Dec 05, 2007 2:08 pm Post subject: |
I was also wondering about some of the little things that can be done to improve gas milage. I know an electronic ignition and a good tune up will help. Is there anything else? _________________ Is that the new Hummer! |
miscreantgnomie Samba Member
Joined: October 15, 2005 Posts: 637 Location: Near lackland AFB come and visit
Posted: Wed Dec 05, 2007 2:51 pm Post subject: |
Mine is powered by glares and looks _________________ 62 sc, 62 SO 34, 61 mango, (2) 67 deluxe in crappy shape, 73 thing, 64 ghia,
and some embarassing bays. shhh, I just use them for storage. (hides)
San Antonio (SAAC/VOSA) |
Posted: Wed Dec 05, 2007 4:03 pm Post subject: |
miscreantgnomie wrote: |
Mine is powered by glares and looks |
So hows the mileage on those? _________________ Your Vanagon sucks, Stop waving at me.
Posted: Wed Dec 05, 2007 4:05 pm Post subject: |
probably 17 18 :_ _________________ 62 sc, 62 SO 34, 61 mango, (2) 67 deluxe in crappy shape, 73 thing, 64 ghia,
Acetone Jack Samba Member
Posted: Wed Dec 05, 2007 5:50 pm Post subject: |
Did you test your MPG with a GPS or road markers?
I thought I was getting about 15-16mpg but turned out that the odometer was horribly off, not to mention I'm running larger that stock tires.
A healthy Thing should be pulling between 20-25 mpg
obviously stay under 60mph in fourth on the freeway. |
klokard Samba Member
Posted: Wed Dec 05, 2007 6:31 pm Post subject: |
No secrets to getting appropriate MPG in a 181. The key word here is appropriate. They are not as aerodynamic as the beetle and have a lower set of gears so they are not made to get beetle MPG. That being said the obvious applies. Proper tuning including valves and ignition (both timing and dwell), properly inflated tires, driving in the correct gear and a properly jetted carb make for about 22 - 24 avg MPG. |
Posted: Wed Dec 05, 2007 11:38 pm Post subject: |
klokard wrote: |
I know how that goes i have a couple buses!
So, I guess I should have asked to post what you all are doing in relation to the above mentioned to get the 20-25mpg. _________________ Your Vanagon sucks, Stop waving at me.
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Thu Dec 06, 2007 12:13 am Post subject: |
My odometer is broken, so I have no clue about my car.
Using a GPS to figure out odometer error is a really good idea. Rest of it is obvious tuneup stuff you've no doubt gone over with your Buses: check the brakes and wheel bearings for excessive drag, don't carry unnecessary stuff, drive slower, check the alignment, new plugs, right jetting, right timing, clean the aircleaner, etc. Smaller tires, synthetic transmission oil, and thinner engine oil might make a difference, too.
Oh, and lose some weight, fatass. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
sam_w Samba Member
Joined: March 07, 2002 Posts: 1479 Location: Petaluma, CA
Posted: Thu Dec 06, 2007 12:23 am Post subject: |
Sean
I get better gas mileage than my 63 singlecab, it gets 22 mpg, when I drove to the Classic & up to CLara in Olympia, WA in the thingster I was getting about 25 mpg _________________ 63 singlecab
73 thingster
74 Thing |
perello Samba Member
Joined: April 15, 2005 Posts: 829 Location: where social security comes for free
Posted: Thu Dec 06, 2007 2:25 am Post subject: |
last time I checked it was around 25 mpg ..1600DP that leaked oil
now I am building a 1600SP..I dont expect any difference in that sense |
Thingggg Samba Member
Ian Epperson Samba Member
Joined: January 12, 2005 Posts: 2262 Location: Alameda, CA
Posted: Thu Dec 06, 2007 11:41 am Post subject: |
Because of a fuel leak, I'm getting about 10MPG right now - it goes even lower the longer it sits!
Do you smell gas anywhere around the car? Are any of your fuel tank seals bad, allowing the gas to evaporate to the atmosphere? I've lost half a gallon in a day just by leaving the gas cap off!
So, in addition to checking the tuning, also check for fuel leaks. _________________ VW-181 shirts and stickers.
http://ian.epperson.com/vw |
howiesfamily Samba Member
Joined: March 31, 2004 Posts: 858 Location: Panther City, Texas
Posted: Thu Dec 06, 2007 12:01 pm Post subject: |
I'm averaging 20mpg. I've got the original 1600 dp with a .009 and 34PICT-3 with a slightly larger than stock jet. Just put some new 195/75-14's on the ground. I'm cruising the freeway about 65 for probably 50 miles or more a day with another 50 miles city driving. _________________ member of: Fort Worth Aircoolers Gang |
Posted: Thu Dec 06, 2007 12:15 pm Post subject: |
howiesfamily wrote: |
I'm averaging 20mpg. I've got the original 1600 dp with a .009 and 34PICT-3 with a slightly larger than stock jet. Just put some new 195/75-14's on the ground. I'm cruising the freeway about 65 for probably 50 miles or more a day with another 50 miles city driving. |
That's pretty similar to what I am running. I just put on some of the same size tires.
Ian-
I don't really smell gas and the heater should only be using a pint a day or so. I was a little heavy on the gas though...I'll try and let off and see if that helps. I replaced all the fuel lines and hoses from the filler to the carb.
Towelrail-
I'll see if I can find a GPS unit. Oh, and I'm big boned you bastid! _________________ Your Vanagon sucks, Stop waving at me.
Posted: Thu Dec 06, 2007 1:04 pm Post subject: |
i have 15 inch wheels on mine wonder how much thats affesting gas milage.
I smell gas around my wifes ghia maybe thats why gas milage is bad.
I thought it was dual 40s and a 1915 might be evaporation never thought of it thanks. _________________ 62 sc, 62 SO 34, 61 mango, (2) 67 deluxe in crappy shape, 73 thing, 64 ghia,
FV195 Samba Member
Joined: February 19, 2005 Posts: 480 Location: carlisile, pa
Posted: Fri Dec 07, 2007 11:10 pm Post subject: |
74 with 1835, dual 34 webbers, 15" tires I'm getting 26mpg on a long trip, floating at 70
THOR |
Posted: Sat Dec 08, 2007 7:03 am Post subject: |
FV195 wrote: |
THOR |
hey thor my sons name is Odin _________________ 62 sc, 62 SO 34, 61 mango, (2) 67 deluxe in crappy shape, 73 thing, 64 ghia,
oldthingguy Samba Member
Joined: December 02, 2007 Posts: 146 Location: California
Posted: Sat Dec 08, 2007 10:09 pm Post subject: |
Mine depends on how much my wife makes me run the gas heater. With a 1904cc and dual carbs it's actually in the high teens around town. |
