deprivation Samba Member
Joined: September 14, 2006 Posts: 1220 Location: Austin, Texas
Posted: Thu Jan 15, 2009 9:56 am Post subject: Re: Ijust |
sgtpepper wrote: |
but used 5/16 inch line, clamped down tight. that should be fine, right? |
You bet.
When I lived in Houston, I couldn't find 7mm line anywhere except for cloth-covered low-pressure line. As a side note, the dude at the VW parts place in Houston insisted that the cloth line is rated at 145 lbs. It is absolutely not rated for injection and I'm really glad I mistrusted his advice.
Several parts stores tried to sell me coolant hoses, transmission cooler hoses, washer hoses, low-press fuel line - you name it. Like the so-called "expert" at KAR Parts in Houston, advice should be viewed with some skepticism or, in some cases, contempt.
I ended up at an Advanced Auto Parts in the Barrio where a disgruntled employee sold me 10 feet of Goodyear 5/16 high-pressure fuel line for 10 bucks.
Take that, Karma! _________________ 1986 Westy 2WD auto a.k.a. "The Old Girl"
www.kittenfart.com |
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
Posted: Thu Jan 15, 2009 10:09 am Post subject: Re: Ijust |
deprivation wrote: |
sgtpepper wrote: |
You bet.
Take that, Karma! |
Scary story!
5/16 is fine, the only thing is that they don't all (5/16) have the same ID and thickness. The one I use fit real tight. So if you are using 5/16 just make sure it fit thighly. If you can remove the hose easily out of an injector it's to loose (ID).
And pay attention to price, they is some junk out there.
Ben _________________ Working with rust, grease, dirt and dust is a sad truth.
FI part for sale: http://www.benplace.com/parts_sale1.htm
My site: http://www.benplace.com/vw2.htm
Subi conversion: http://www.benplace.com/vanaru_eng.htm
Youtube http://www.youtube.com/user/ftp2leta |
Posted: Thu Jan 15, 2009 11:13 am Post subject: |
A lot of regular fuel line says it is rated in the 150-200 psi range. This must be its ultimate burst pressure or something, I can't believe it could actually hold that kind of pressure for long. When I bought my 83 1/2 it had a piece of regular fuel line installed right after the pump. It was all cracked and leaking fuel badly.
I have had good luck running 5/16 FI line. I personally like the kind with a separate liner, it should prove to be more chemical resistant. It is harder to use though as the liner is stiff and hard to get started over fittings.
You can buy very good quality FI line from car dealers. The Subaru stuff seems excellent. |
randiego Samba Member
Joined: October 13, 2008 Posts: 75 Location: San Diego
Posted: Mon Nov 30, 2015 1:19 am Post subject: |
Perales wrote: |
Does anyone know offhand what the length of the injector hose segment is? |
I was looking for the answer to "what is the length of the injector to fuel rail hose segment" myself today... so for all you guys (like me) that didn't "save an old one to measure the new ones" (I cut mine and tossed 'em)
I eyeballed it to be double the length of the fuel rail nipple or 1.75" (45mm). _________________ '85 GL, 1.9, 4spd (Sold, we'll miss it)
'89 Carat, Bordeaux Red, 4spd 2.1 |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17153 Location: Retired South Florida
Posted: Fri Jan 11, 2019 10:00 am Post subject: Re: Injector Hoses |
I am replacing the fuel lines on a Syncro. I've read a few threads and every time some one logs in as a new vanagon owner within 3 posts someone always says "replace your fuel lines".
I'm trying to decide how much fuel line I will need to reseal a syncro wbx fuel system from the pump to the injectors and back to the sender. I can guestimate, but was wondering if someone documented how much fuel line is actually required to reline a 2wd and a syncro. Thank you. _________________ ☮️ |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
Posted: Fri Jan 11, 2019 11:58 am Post subject: Re: Injector Hoses |
Thanks Dave, no total? Figured as often as it comes someone might have totaled it out. For the syncro, I measured roughly 13 feet. I just held a tape measure along the existing hoses. Thanks again.
Edit, my Malware bytes blocks the link you provided. Something about a Trojan detected. _________________ ☮️ |
Gruppe B Samba Member
Posted: Fri Jan 11, 2019 12:04 pm Post subject: Re: Injector Hoses |
from bensplace.com
You will need about 10 to 12 feet of 5/16 FI hoses to cover the engine bay area, if you decide to do the fuel pump to firewall plastic junction line, you will need an extra 6 feet. About 20 x 5/16 FI clamps are also needed.
http://www.benplace.com/fuel_line.htm |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7756 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Jan 11, 2019 12:06 pm Post subject: Re: Injector Hoses |
^^^ Syncro...???
Not the same...just sayin.
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
termuehlen Samba Member
Joined: May 02, 2012 Posts: 994 Location: Redwood City
Posted: Fri Jan 11, 2019 12:25 pm Post subject: Re: Injector Hoses |
MarkWard wrote: |
I'm trying to decide how much fuel line I will need to reseal a syncro wbx fuel system from the pump to the injectors and back to the sender. I can guestimate, but was wondering if someone documented how much fuel line is actually required to reline a 2wd and a syncro. Thank you. |
Hi Mark:
At the risk of setting off a samba nuclear explosion, there are some people here who have documented the original syncro fuel lines to be extremely durable...
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20 _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
Posted: Fri Jan 11, 2019 12:55 pm Post subject: Re: Injector Hoses |
I'm converting a 2wd to syncro. So now is the time to replace the hoses. I was just surprised as often that it comes up, I couldn't find a total in the essentials list. Of course I waited to the last minute to check. Thanks _________________ ☮️ |
SteveMc Samba Member
Joined: December 19, 2013 Posts: 210 Location: Alberta, Canada
MarkWard wrote: |
As per GoWesty's kit, 15 feet. https://www.gowesty.com/product/fuel-delivery/4393/engine-fuel-line-replacement-kit?v= _________________ 1986 Transporter Single Cab Syncro |
Posted: Fri Jan 11, 2019 1:17 pm Post subject: Re: Injector Hoses |
Have a 15 foot section on the way. Thank you _________________ ☮️ |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4789 Location: Bemidji, MN
Posted: Fri Jan 11, 2019 1:57 pm Post subject: Re: Injector Hoses |
i like to route the new fuel line OVER the intake runners...
- it is substantially cooler, the hose doesn't bake as much
- easier to keep an eye on the condition, leaks, chaffing
- easier to reach the T port for measurements
the lines i removed on my 87 snapped in two when i held each end of the old removed hose and brought the ends together. not formed a crack but snapped clean like spaghetti. _________________ -dan
www.thefixitworkshop.com |
