Throttle Position Switch
Page: Previous  1, 2
syncrodoka
syncrodoka is offline
PostPosted: Sat Feb 13, 2010 3:32 pm    Post subject: Reply with quote
BTW- The bus depot website is a good resource to enter part numbers and find their applications.
drivenachodrive
drivenachodrive is offline
PostPosted: Fri Aug 27, 2010 3:05 pm    Post subject: Reply with quote
Here I went and didn't listen to the Bentley manual and I tampered with the setting of the idle stop screw. Is there some way to get it back to factory settings? How many turns out was it? Dah! Now everything's screwed up. I'd like to know how to get it back to factory settings so I can adjust the TPS the correct way. Thoughts?
View user's profile Send private message Visit poster's website Facebook Twitter Classifieds Feedback
whip618
whip618 is offline
PostPosted: Fri Aug 27, 2010 7:38 pm    Post subject: Reply with quote
bwv2, if you are using a throttle body with lots of miles on it then turn the throttle stop screw out until there is a small gap say .010, the turn the stop screw in until it just touches the ear on the throttle body that it rests aginst then turn the stop screw in another half turn. If you have a rebuilt throttle body like van -cafe sells than you can set the stop screw to a quarter turn.
Do not use a feeler gage because there is usually a dimple worn into the stop ear and a feeler gage will give you a false reading.
The half turn adjustment is mainly to give the throttle plate a little free play and to keep the throttle plate from binding in the bore of the throttle body when the the two mounting screws are cranked down. the body will actually distort from the torque on the screws.
Phil
Life is simple....either you're qualified or you're not.
USSVI.......Pride Runs Deep
USSVI Life member and Holland Club member
Samba Member No. 3307
mikls63rag
mikls63rag is offline
PostPosted: Tue Nov 30, 2010 4:37 pm    Post subject: Reply with quote
Yesterday I replaced the temp 2 sensor. Today I adjusted the Throttle Valve switch and replaced the 02 sensor. Gona fire it up, let it warm up and see what happens next.
UPDATE:
Started right up like always, took it around the block a couple of times let it sit and idle up to 15 min and was gona leave the drive way...bucked and died. Started right up 2 more times because it kept dieing. Didn't even bother trying to start it back up the last time...it didn't want to start so I just came in side very frustrated!
http://s103.photobucket.com/albums/m144/Mikls63rag...-36-04.mp4
Michael
63' Rag
65' Bug
13' Passat S
kjono09
kjono09 is offline
PostPosted: Tue Feb 09, 2016 11:00 am    Post subject: Re: Throttle Position Switch Reply with quote
What happened, I have a 1.9L 84 with the a high idle condition.
84 Retro-Westy GW 2.2L (Vincent)
67 Bug 2007cc (WBX in progress) (Davey)
Submariner
mikls63rag
PostPosted: Tue Feb 09, 2016 3:43 pm    Post subject: Re: Throttle Position Switch Reply with quote
Ok, this was several yrs ago. I turned out to be the distributor. I ordered a fresh one, pu ti tin and never had another problem like that again.
Check the grounds are making a good connection.
Michael
63' Rag
65' Bug
13' Passat S
shagginwagon83
shagginwagon83 is online now
PostPosted: Tue Apr 03, 2018 7:53 am    Post subject: Re: Throttle Position Switch Reply with quote
I wonder if this applies to 83.5-85 model
Brandon
Instagram @joannthevan
Steve M.
Steve M. is offline
PostPosted: Tue Apr 03, 2018 1:18 pm    Post subject: Re: Throttle Position Switch Reply with quote
Since these are old and corroded/rusted Allen head screws on the Throttle Position Screws the Allen keys with the rounded ends on them most likely will act like they are stripped.
You want to use Allen keys without the rounded ends so that it seats fully down into the head.
Also, Van-Cafe has new Adjustment Screws to replace old worn out ones.
erikgundy98
erikgundy98 is offline
PostPosted: Tue Apr 03, 2018 4:09 pm    Post subject: Re: Throttle Position Switch Reply with quote
I recommend you take off the whole throttle body and switch, then look at what is happening when you turn the screws. I thought mine was stripped too- until I understood that one of them is to change the position of the switch, and it was moved as much as it could go- hence the Allen screw not wanting to move anymore when I turned it. Clean it up, might save you some change and headache Smile
'90 Multivan Westfalia
Page: Previous  1, 2
Page 2 of 2
