Chris dubosq Samba Member
Posted: Wed May 04, 2016 6:39 pm Post subject: Re: Brake Bleeding |
Yup brakes adjusted |
Drewmon Samba Member
Posted: Thu May 05, 2016 5:18 am Post subject: Re: Brake Bleeding |
Eric&Barb wrote: |
Drewmon wrote: |
More bleeding? |
Air in the system will result in pedal getting higher and higher the more times you pump it. Then when you let off the pedal for more than a few seconds, the pedal the next time you push down on it, will be again be at same low spot. Plus the pedal will have a squishy feel to it.
With properly bled brake system you should notice the slightest increase between the first and second pump, but after that should be same height pedal. Slight change is due to the flex lines swelling a tiny amount with the increased pressure inside. Pedal will have a rock hard feel to it.
Which of the above describes your situation? |
Sounds like the first one... Air in the system. Thats what I figured. Time to build a pressure bleeder.
Yes, all the blakes are adjusted, (all 4 corners are disks) |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24670 Location: Olympia Wash Rinse & Repeat
Posted: Thu May 05, 2016 6:59 am Post subject: Re: Brake Bleeding |
Drewmon wrote: |
Helps to not pound on the pedal which can cause smaller harder to bleed air bubbles. With dual MC you should bleed the front axle first. _________________ In Stereo, Where Available! |
Jem5649 Samba Member
Joined: August 29, 2014 Posts: 106 Location: Denver, CO
Posted: Sun Aug 14, 2016 3:01 pm Post subject: Re: Brake Bleeding |
Hi guys, I have a 65 Baja that I just put new wheel cylinders and pads on. I went to bleed the brakes, but with all the bleeder valves closed, I can't seem to "build pressure" without pulling the parking brake. Any thoughts? I am using DOT 3.
Thanks! _________________ I am a rock climber, not very mechanical...
1980 air cooled Westy named Beer... Yes you read that right! |
Posted: Sun Aug 14, 2016 3:34 pm Post subject: Re: Brake Bleeding |
Jem5649 wrote: |
Thanks! |
Dual circuit or single? _________________ In Stereo, Where Available! |
Posted: Sun Aug 14, 2016 3:52 pm Post subject: Re: Brake Bleeding |
Honestly I don't know. How can I tell? I have not had to mess with a master brake cylinder before.
I can build pressure with the E brake pulled if that answers that question at all. _________________ I am a rock climber, not very mechanical...
Posted: Sun Aug 14, 2016 4:20 pm Post subject: Re: Brake Bleeding |
Jem5649 wrote: |
I can build pressure with the E brake pulled if that answers that question at all. |
Single circuit has one single hose from brake fluid reservoir to top of the master cylinder.
Dual circuit has two hoses..... _________________ In Stereo, Where Available! |
Posted: Sun Aug 14, 2016 4:23 pm Post subject: Re: Brake Bleeding |
It is single circuit, no leaks in the system. _________________ I am a rock climber, not very mechanical...
Posted: Sun Aug 14, 2016 4:28 pm Post subject: Re: Brake Bleeding |
Did you adjust the brake shoes for a bit of drag from each? _________________ In Stereo, Where Available! |
Posted: Sun Aug 14, 2016 4:35 pm Post subject: Re: Brake Bleeding |
Yup _________________ I am a rock climber, not very mechanical...
Posted: Sun Aug 14, 2016 4:40 pm Post subject: Re: Brake Bleeding |
Are you first bleeding the wheel on rear axle farthest away from the MC? _________________ In Stereo, Where Available! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31268 Location: Hot Arizona
Posted: Sun Aug 14, 2016 6:17 pm Post subject: Re: Brake Bleeding |
Jem5649 wrote: |
When the E-brake is pulled, that's like manually moving the rear brake shoes (you don't have pads) closer to the drums. So that indicates to me that you do NOT have the brakes adjusted tight enough or correctly enough. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Mon Aug 15, 2016 2:43 pm Post subject: Re: Brake Bleeding |
It turned out I had a bleed valve a little open I didn't know about... Facepalm... _________________ I am a rock climber, not very mechanical...
Posted: Mon Aug 15, 2016 2:47 pm Post subject: Re: Brake Bleeding |
Jem5649 wrote: |
It turned out I had a bleed valve a little open I didn't know about... Facepalm... |
Main thing is you found it!! Thanks for the update! _________________ In Stereo, Where Available! |
xzener Samba Member
Posted: Tue Jan 09, 2018 7:03 pm Post subject: Re: Brake Bleeding |
I'm just trying to flush the lines... Do the shoes need to be adjusted for this. Wasn't planning on de-airing just yet. Just want to get fresh fluid into the system. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Tue Jan 09, 2018 9:12 pm Post subject: Re: Brake Bleeding |
If you want to push out fluid, you do not want to be wasting your effort moving back and forth the brake wheel pistons and shoes instead. _________________ In Stereo, Where Available! |
xzener Samba Member
Posted: Tue Jan 09, 2018 9:42 pm Post subject: Re: Brake Bleeding |
I don't follow... I thought gravity would simply move the fluid, but even pressing the brake pedal doesn't get the fluid moving. I have a reservoir on top of my dual circuit MC. So I thought jacking up the front would help getting the fluid to the rear... But no joy. _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
Posted: Wed Jan 10, 2018 9:24 am Post subject: Re: Brake Bleeding |
Do you have a copy of the VW Official Service Manual? If so which one? _________________ In Stereo, Where Available! |
Zundfolge1432 Samba Member
Posted: Wed Jan 10, 2018 9:56 am Post subject: Re: Brake Bleeding |
Eric&Barb wrote: |
Do you have a copy of the VW Official Service Manual? If so which one? |
Badges? We don’t need no stinking badges |
Art Augustensen Banned
Joined: December 30, 2017 Posts: 15 Location: Orleans mass
Posted: Mon Mar 19, 2018 8:51 am Post subject: Re: Brake Bleeding |
Does anyone know of a repair shop that will rebuild a 1967 bug master cylinder.
Thanks Art |
