mad97321 Samba Member
Posted: Thu Dec 13, 2007 11:10 pm Post subject: Distributor shaft felt sleeve question |
Hi,
I couldn't find an answer to this question by searching. I am rebuilding my distributor for my engine (stock 1970 type 3 with FI distributor - vw-311-905-205AB), and it has a sleeve of felt stuff (like the kind that goes under the rotor on the top of the shaft) in the tube of the distributor body between the shaft bushings. I assume it holds oil up against the shaft or something. The stuff is kind of brittle and I am wondering if I should remove it, replace it (any good sources for it?), or leave it. Any ideas? Thanks in advance for your help.
M.D. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Fri Dec 14, 2007 7:14 am Post subject: |
Send me a PM with your mailing address and I can send you a replacement. _________________ Glenn
Member #1009
#BlueSquare |
heimlich VWNOS.com
Joined: November 20, 2016 Posts: 6616 Location: Houston, Texas
Posted: Thu Jun 15, 2017 8:43 pm Post subject: Re: Distributor shaft felt sleeve question |
Does anyone know what this piece is called and what it is made from? I need to find a replacement. |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Sat Jun 17, 2017 11:12 pm Post subject: Re: Distributor shaft felt sleeve question |
kawfee wrote: |
You can make it out of the felt pads that go on the bottom of chair/stool legs (cut & shape to size). Available at your local Lowes and/or Home Depot. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sun Jun 18, 2017 8:46 pm Post subject: Re: Distributor shaft felt sleeve question |
The wool felt is typically a non wear item. If the distributor is extra dirty or has been exposed to the open air for a long period it might need replacement. It doesn't have a name since it rarely gets paid attention too. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
heimlich VWNOS.com
Posted: Thu Jun 22, 2017 3:44 pm Post subject: Re: Distributor shaft felt sleeve question |
Are the specs for this available such as hardness/firmness, fiber content, etc?
I was thinking of getting this:
https://www.mcmaster.com/#8770K9
Will that work correctly? |
UK Luke 72 Samba Member
Joined: September 07, 2011 Posts: 2867 Location: Little Britain
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21519 Location: Oklahoma City
Posted: Thu Jun 22, 2017 5:46 pm Post subject: Re: Distributor shaft felt sleeve question |
kawfee wrote: |
No!...I would not use that. The temp rating of 200F is too low. Its not uncommon for distributors on long highway runs to be upwards to 250F. That felt is Rayon. While it starts as a cellulose product...it is polymerized. Its now largely a plastic.
While the wool felt only lists 200F...it will not melt, soften or compact and when its soaked with oil it has a higher temp range
Look under hard felt. You want something in the 55-60 durometer range
The S2-20 material in 1/4" will work fine. a 12" x 12" sheet is $23.02. You can punch out several hundred wicks from that sheet.
You can usually also buy 100% wool felt from JO-Ann Fabrics. It really does not matter how hard it is....as long as its not so hard that oil cannot seep through it when saturated...and it has to have enough compaction to stay put in the bore.
You can probably just get a snippet sample of 100% wool felt at the fabric store for free. Ray |
Glenn Mr. 010
Posted: Thu Jun 22, 2017 6:46 pm Post subject: Re: Distributor shaft felt sleeve question |
UK Luke 72 wrote: |
Why not just offer Glenn some $$$ for them? He's said up there he has them! |
Why does he have to do everything the hard way.
This is just some of them I have.
Member #1009
#BlueSquare |
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Thu Jun 22, 2017 6:51 pm Post subject: Re: Distributor shaft felt sleeve question |
He's not looking for the felt buttons, he's looking for the felt that goes inside the shaft. Little rectangle like 1x3 or so. I'm also looking for this replacement.
OP:
Glenn hooked me up some of the felt buttons cheap, and got them to me quick if you need those as well. |
heimlich VWNOS.com
Posted: Thu Jun 22, 2017 7:02 pm Post subject: Re: Distributor shaft felt sleeve question |
UK Luke 72 wrote: |
That was 10 years ago. |
Glenn Mr. 010
Pruneman99 wrote: |
He's not looking for the felt buttons, he's looking for the felt that goes inside the shaft. Little rectangle like 1x3 or so. I'm also looking for this replacement. |
D'oh
Member #1009
#BlueSquare |
heimlich VWNOS.com
Posted: Thu Jun 22, 2017 7:16 pm Post subject: Re: Distributor shaft felt sleeve question |
Glenn wrote: |
I guess I could just buy a distributor already built. That would be easy, expensive, and not much fun. |
Glenn Mr. 010
Glenn Mr. 010
Posted: Thu Jun 22, 2017 7:24 pm Post subject: Re: Distributor shaft felt sleeve question |
kawfee wrote: |
Glenn wrote: |
If you buy it from the right person, it will be done right and work like new. If you buy it from the wrong person... flip a coin. I've rebuild many that were "rebuilt" by someone else.
I do rebuilds for a dozen restoration shops including VW, Porsche and Mercedes Benz. These shops know it's its better to sub out the work to a specialty shop than to do it themselves.
There's more to taking it apart, cleaning and putting it back together. _________________ Glenn
Member #1009
#BlueSquare |
heimlich VWNOS.com
Posted: Thu Jun 22, 2017 7:25 pm Post subject: Re: Distributor shaft felt sleeve question |
Glenn wrote: |
kawfee wrote: |
Glenn wrote: |
There's more to taking it apart, cleaning and putting it back together. |
Yes, you keep saying that. It's time to learn. |
Glenn Mr. 010
Posted: Thu Jun 22, 2017 7:28 pm Post subject: Re: Distributor shaft felt sleeve question |
kawfee wrote: |
Lets just hope your transmission doesn't need a rebuild. _________________ Glenn
Member #1009
#BlueSquare |
heimlich VWNOS.com
Posted: Thu Jun 22, 2017 7:42 pm Post subject: Re: Distributor shaft felt sleeve question |
Glenn wrote: |
kawfee wrote: |
Lets just hope your transmission doesn't need a rebuild. |
I hope it does. I don't know if I am ready to buy the tools to rebuild a transmission. I suppose when that time comes, it comes. |
heimlich VWNOS.com
Posted: Thu Jun 22, 2017 8:41 pm Post subject: Re: Distributor shaft felt sleeve question |
Oooh la la. I love it when I see a Bosch number. |
David_nc_72std Samba Member
Joined: August 22, 2015 Posts: 841 Location: Winston-Salem, NC
Posted: Thu Jun 22, 2017 9:00 pm Post subject: Re: Distributor shaft felt sleeve question |
Can someone that has one give the actual dimensions of the new Bosch felt pad?
Interesting to see a discussion of this part. At the beginning of the year I asked one of the people who routinely advertises rebuilt distributors what material to use for a replacement, and their response was that it wasn't needed. Guess I need to find some suitable felt and take the distributor back apart.
Is the felt installed in a v-shape, so it presses up against the rotating shaft, or rolled up into a tubular shape? I seem to recall it having a crease, like it was folded, but the pieces were crumpling so badly it was hard to tell. |
